  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 121.6k Views 58 Watching
  • n1ck1355N
    n1ck1355N
    n1ck1355
    @tekka : do you have any clue whats wrong with my setup?
    tekkaT 1 Reply Last reply
    • DrJeffD
      DrJeffD
      DrJeff
      Does the gateway need the OTA firmware (flashed) written to it as well as the Nodes?
      • n1ck1355N n1ck1355
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        #42
        @n1ck1355 yes, probably there is a timing issue with serial uploads. Need to review the STK500 code. Can you confirm that OTA FW updates work fine?
        • DrJeffD DrJeff
          tekkaT
          tekkaT
          tekka
          @DrJeff No, only the nodes
          DrJeffD 1 Reply Last reply
          • tekkaT tekka
            DrJeffD
            DrJeffD
            DrJeff
            @tekka Cool thanks, can I use Arduino as ISP to program bootloader?
            • DrJeffD DrJeff
              tekkaT
              tekkaT
              tekka
              @DrJeff Yep :)
              • tekkaT tekka
                @DrJeff Yep :)
                DrJeffD
                DrJeffD
                DrJeff
                @tekka , Time to try Thanks! :)
                • n1ck1355N
                  n1ck1355N
                  n1ck1355
                  @tekka yes ota fw updates works. Tried it with the Time fw
                  • n1ck1355N
                    n1ck1355N
                    n1ck1355
                    wrote on last edited by n1ck1355
                    #48
                    @tekka i musst revert my previous post...
                    I've OTA uploaded the sketch from my first post:
                      Serial.begin(57600);
                      Serial.println("Setup Start");
                    and i connected the board over Serial with my computer. After uploading the sketch i did not noticed any output on the serial monitor in the Arduino IDE. Also checked the transfer rate.
                    However the time reporter firmware works fine.
                    • siklosiS
                      siklosiS
                      siklosi
                      Is there a way to send ota firmware to node using some cli (python or...) script? I'm using MySensors with domoticz on RPi and when flashing new firmware I usually disconnect gw from rpi plug it into notebook and send fw using MYSController. If I could just disable gw in domoticz and send fw using some script it would be great until (if) domoticz gets support for ota fw.
                      • rollercontainerR
                        rollercontainerR
                        rollercontainer
                        wrote on last edited by rollercontainer
                        #50
                        I've just tried two 3,3V Pro Minis. Flashed the 8MHz MYSBootloader without problems (Nano as ISP). After that I connected the FTDI Adapter and programmed Blink and ReadAnalogVoltage examples without error. Both didn't worked on both Pro Minis. With original Bootloaders, they work.
                        Where is my fault?
                        • rollercontainerR rollercontainer
                          Where is my fault?
                          tekkaT
                          tekkaT
                          tekka
                          #51
                          @rollercontainer You have to provide additional information such as logs, etc. for troubleshooting
                          • Thar0lT
                            Thar0lT
                            Thar0l
                            @tekka Serial not working after uploading MYSbootloader v1.3pre. ArduinoProMini 5v16Mhz. Is it normal?
                            • Thar0lT Thar0l
                              tekkaT
                              tekkaT
                              tekka
                              @Алексей-Гусаров please provide additional information such as config and logs.
                              Thar0lT 1 Reply Last reply
                              • tekkaT tekka
                                Thar0lT
                                Thar0lT
                                Thar0l
                                wrote on last edited by Thar0l
                                #54
                                @tekka
                                boards.txt:
                                ######## settings for ext XTAL 16Mhz, EESAVE, BOD1V8, no lock
                                proMYSBL16.name=ATmega328 external 16Mhz with MYSBootloader
                                proMYSBL16.upload.tool=avrdude
                                proMYSBL16.upload.protocol=arduino
                                proMYSBL16.upload.maximum_size=30720
                                proMYSBL16.upload.maximum_data_size=2048
                                proMYSBL16.upload.speed=115200
                                proMYSBL16.bootloader.tool=avrdude
                                proMYSBL16.bootloader.low_fuses=0xFF
                                proMYSBL16.bootloader.high_fuses=0xD2
                                proMYSBL16.bootloader.extended_fuses=0x06
                                proMYSBL16.bootloader.unlock_bits=0x3F
                                proMYSBL16.bootloader.lock_bits=0x3F
                                proMYSBL16.bootloader.file=MySensors/MYSBootloaderV13pre.hex
                                proMYSBL16.build.mcu=atmega328p
                                proMYSBL16.build.f_cpu=16000000L
                                proMYSBL16.build.board=AVR_UNO
                                proMYSBL16.build.core=arduino
                                proMYSBL16.build.variant=standard
                                ######## settings for 8Mhz internal clock, EESAVE, BOD1V8, no lock
                                proMYSBL8.upload.tool=avrdude
                                proMYSBL8.upload.speed=57600
                                proMYSBL8.bootloader.high_fuses=0xD2
                                proMYSBL8.bootloader.file=MySensors/MYSBootloaderV13pre.hex
                                proMYSBL8.build.board=AVR_UNO
                                proMYSBL8.build.core=arduino
                                MyConfig.h:
                                #ifdef MY_DISABLED_SERIAL
                                #undef MY_DEBUG
                                #ifndef MY_BAUD_RATE
                                #define MY_BAUD_RATE 115200
                                //#define MY_RADIO_NRF24
                                //#define MY_RS485
                                #ifndef MY_NODE_ID
                                #define MY_NODE_ID AUTO
                                #ifndef MY_PARENT_NODE_ID
                                #ifndef MY_OTA_FLASH_SS
                                #define MY_OTA_FLASH_SS 8
                                #ifndef MY_OTA_FLASH_JDECID
                                //#define MY_LEDS_BLINKING_FEATURE
                                //#define MY_DEFAULT_ERR_LED x
                                //#define MY_DEFAULT_TX_LED x
                                //#define MY_DEFAULT_RX_LED x
                                		#define MY_INCLUSION_MODE_BUTTON_PIN 3
                                //#define MY_SIGNING_ATSHA204
                                //#define MY_SIGNING_SOFT
                                #ifndef MY_RS485_BAUD_RATE
                                #ifndef MY_RF24_CE_PIN
                                		#define MY_RF24_CE_PIN 4
                                		#define MY_RF24_CE_PIN 27
                                		#define MY_RF24_CE_PIN 9
                                #ifndef MY_RF24_CS_PIN
                                		#define MY_RF24_CS_PIN 15
                                		#define MY_RF24_CS_PIN 3
                                		#define MY_RF24_CS_PIN 10
                                #ifndef MY_RF24_PA_LEVEL
                                #ifndef MY_RF24_CHANNEL
                                #define MY_RF24_CHANNEL	76
                                #ifndef MY_RF24_DATARATE
                                #ifndef MY_RF24_BASE_RADIO_ID
                                #define MY_RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
                                //#define MY_SOFTSPI
                                #ifndef MY_SOFT_SPI_SCK_PIN
                                #ifndef MY_SOFT_SPI_MISO_PIN
                                #ifndef MY_SOFT_SPI_MOSI_PIN
                                #ifndef MY_RFM69_FREQUENCY
                                //#define MY_IS_RFM69HW
                                #ifdef MY_IS_RFM69HW
                                	#define MY_RFM69HW true
                                	#define MY_RFM69HW false
                                #ifndef MY_RFM69_NETWORKID
                                #ifndef MY_RF69_IRQ_PIN
                                #ifndef MY_RF69_SPI_CS
                                #ifndef MY_RF69_IRQ_NUM
                                //#define MY_GATEWAY_W5100
                                //#define MY_GATEWAY_ENC28J60
                                //#define MY_GATEWAY_ESP8266
                                #ifndef MY_PORT
                                #define MY_PORT 5003
                                //#define MY_USE_UDP
                                #ifndef MY_MAC_ADDRESS
                                #ifndef MY_NODE_UNLOCK_PIN
                                #define MY_NODE_UNLOCK_PIN 14
                                In node scetch:
                                I have no logs from node because serial isn't working at all. Which logs should I attach?
                                • Thar0lT Thar0l
                                  @tekka
                                  boards.txt:
                                  MyConfig.h:
                                  #undef MY_DEBUG
                                  //#define MY_RS485
                                  #ifndef MY_NODE_ID
                                  #ifndef MY_PORT
                                  In node scetch:
                                  tekkaT
                                  tekkaT
                                  tekka
                                  #55
                                  @Алексей-Гусаров I'll look into that. Seems like bootloader is not handing over to the sketch (corroborates previous reports). Can you post the OTA log (from e.g. MYSController)?
                                  • tekkaT tekka
                                    Thar0lT
                                    Thar0lT
                                    Thar0l
                                    @tekka I'm using mycotroller.org instead of myscontroller. It writes that "firmware update initiated" and nothing happens.
                                    tekkaT J 2 Replies Last reply
                                    • Thar0lT Thar0l
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @Алексей-Гусаров Then I highly suggest to run MYSController to log OTA traffic for troubleshooting...
                                      • tekkaT tekka
                                        Thar0lT
                                        Thar0lT
                                        Thar0l
                                        @tekka OK, I'll try to do it tomorrow.
                                        • Thar0lT Thar0l
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @Алексей-Гусаров :+1:
                                          J 1 Reply Last reply
