  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 121.6k Views 58 Watching
  • F
    F
    Fabien
    So after few test, wrks fine with I_PRESENTATION request and using smartSleep (with interrupts too).
    • n1ck1355N
      n1ck1355N
      n1ck1355
      @tekka : do you have any clue whats wrong with my setup?
      tekkaT 1 Reply Last reply
      • DrJeffD
        DrJeffD
        DrJeff
        Does the gateway need the OTA firmware (flashed) written to it as well as the Nodes?
        • n1ck1355N n1ck1355
          tekkaT
          tekkaT
          tekka
          wrote on last edited by tekka
          #42
          @n1ck1355 yes, probably there is a timing issue with serial uploads. Need to review the STK500 code. Can you confirm that OTA FW updates work fine?
          • DrJeffD DrJeff
            tekkaT
            tekkaT
            tekka
            @DrJeff No, only the nodes
            DrJeffD 1 Reply Last reply
            • tekkaT tekka
              DrJeffD
              DrJeffD
              DrJeff
              @tekka Cool thanks, can I use Arduino as ISP to program bootloader?
              • DrJeffD DrJeff
                tekkaT
                tekkaT
                tekka
                @DrJeff Yep :)
                • tekkaT tekka
                  @DrJeff Yep :)
                  DrJeffD
                  DrJeffD
                  DrJeff
                  @tekka , Time to try Thanks! :)
                  • n1ck1355N
                    n1ck1355N
                    n1ck1355
                    @tekka yes ota fw updates works. Tried it with the Time fw
                    • n1ck1355N
                      n1ck1355N
                      n1ck1355
                      wrote on last edited by n1ck1355
                      #48
                      @tekka i musst revert my previous post...
                      I've OTA uploaded the sketch from my first post:
                        Serial.begin(57600);
                        Serial.println("Setup Start");
                      and i connected the board over Serial with my computer. After uploading the sketch i did not noticed any output on the serial monitor in the Arduino IDE. Also checked the transfer rate.
                      However the time reporter firmware works fine.
                      • siklosiS
                        siklosiS
                        siklosi
                        Is there a way to send ota firmware to node using some cli (python or...) script? I'm using MySensors with domoticz on RPi and when flashing new firmware I usually disconnect gw from rpi plug it into notebook and send fw using MYSController. If I could just disable gw in domoticz and send fw using some script it would be great until (if) domoticz gets support for ota fw.
                        • rollercontainerR
                          rollercontainerR
                          rollercontainer
                          wrote on last edited by rollercontainer
                          #50
                          I've just tried two 3,3V Pro Minis. Flashed the 8MHz MYSBootloader without problems (Nano as ISP). After that I connected the FTDI Adapter and programmed Blink and ReadAnalogVoltage examples without error. Both didn't worked on both Pro Minis. With original Bootloaders, they work.
                          Where is my fault?
                          • rollercontainerR rollercontainer
                            Where is my fault?
                            tekkaT
                            tekkaT
                            tekka
                            #51
                            @rollercontainer You have to provide additional information such as logs, etc. for troubleshooting
                            • Thar0lT
                              Thar0lT
                              Thar0l
                              @tekka Serial not working after uploading MYSbootloader v1.3pre. ArduinoProMini 5v16Mhz. Is it normal?
                              • Thar0lT Thar0l
                                tekkaT
                                tekkaT
                                tekka
                                @Алексей-Гусаров please provide additional information such as config and logs.
                                Thar0lT 1 Reply Last reply
                                • tekkaT tekka
                                  Thar0lT
                                  Thar0lT
                                  Thar0l
                                  wrote on last edited by Thar0l
                                  #54
                                  @tekka
                                  boards.txt:
                                  ######## settings for ext XTAL 16Mhz, EESAVE, BOD1V8, no lock
                                  proMYSBL16.name=ATmega328 external 16Mhz with MYSBootloader
                                  proMYSBL16.upload.tool=avrdude
                                  proMYSBL16.upload.protocol=arduino
                                  proMYSBL16.upload.maximum_size=30720
                                  proMYSBL16.upload.maximum_data_size=2048
                                  proMYSBL16.upload.speed=115200
                                  proMYSBL16.bootloader.tool=avrdude
                                  proMYSBL16.bootloader.low_fuses=0xFF
                                  proMYSBL16.bootloader.high_fuses=0xD2
                                  proMYSBL16.bootloader.extended_fuses=0x06
                                  proMYSBL16.bootloader.unlock_bits=0x3F
                                  proMYSBL16.bootloader.lock_bits=0x3F
                                  proMYSBL16.bootloader.file=MySensors/MYSBootloaderV13pre.hex
                                  proMYSBL16.build.mcu=atmega328p
                                  proMYSBL16.build.f_cpu=16000000L
                                  proMYSBL16.build.board=AVR_UNO
                                  proMYSBL16.build.core=arduino
                                  proMYSBL16.build.variant=standard
                                  ######## settings for 8Mhz internal clock, EESAVE, BOD1V8, no lock
                                  proMYSBL8.upload.tool=avrdude
                                  proMYSBL8.upload.speed=57600
                                  proMYSBL8.bootloader.high_fuses=0xD2
                                  proMYSBL8.bootloader.file=MySensors/MYSBootloaderV13pre.hex
                                  proMYSBL8.build.board=AVR_UNO
                                  proMYSBL8.build.core=arduino
                                  MyConfig.h:
                                  #ifdef MY_DISABLED_SERIAL
                                  #undef MY_DEBUG
                                  #ifndef MY_BAUD_RATE
                                  #define MY_BAUD_RATE 115200
                                  //#define MY_RADIO_NRF24
                                  //#define MY_RS485
                                  #ifndef MY_NODE_ID
                                  #define MY_NODE_ID AUTO
                                  #ifndef MY_PARENT_NODE_ID
                                  #ifndef MY_OTA_FLASH_SS
                                  #define MY_OTA_FLASH_SS 8
                                  #ifndef MY_OTA_FLASH_JDECID
                                  //#define MY_LEDS_BLINKING_FEATURE
                                  //#define MY_DEFAULT_ERR_LED x
                                  //#define MY_DEFAULT_TX_LED x
                                  //#define MY_DEFAULT_RX_LED x
                                  		#define MY_INCLUSION_MODE_BUTTON_PIN 3
                                  //#define MY_SIGNING_ATSHA204
                                  //#define MY_SIGNING_SOFT
                                  #ifndef MY_RS485_BAUD_RATE
                                  #ifndef MY_RF24_CE_PIN
                                  		#define MY_RF24_CE_PIN 4
                                  		#define MY_RF24_CE_PIN 27
                                  		#define MY_RF24_CE_PIN 9
                                  #ifndef MY_RF24_CS_PIN
                                  		#define MY_RF24_CS_PIN 15
                                  		#define MY_RF24_CS_PIN 3
                                  		#define MY_RF24_CS_PIN 10
                                  #ifndef MY_RF24_PA_LEVEL
                                  #ifndef MY_RF24_CHANNEL
                                  #define MY_RF24_CHANNEL	76
                                  #ifndef MY_RF24_DATARATE
                                  #ifndef MY_RF24_BASE_RADIO_ID
                                  #define MY_RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
                                  //#define MY_SOFTSPI
                                  #ifndef MY_SOFT_SPI_SCK_PIN
                                  #ifndef MY_SOFT_SPI_MISO_PIN
                                  #ifndef MY_SOFT_SPI_MOSI_PIN
                                  #ifndef MY_RFM69_FREQUENCY
                                  //#define MY_IS_RFM69HW
                                  #ifdef MY_IS_RFM69HW
                                  	#define MY_RFM69HW true
                                  	#define MY_RFM69HW false
                                  #ifndef MY_RFM69_NETWORKID
                                  #ifndef MY_RF69_IRQ_PIN
                                  #ifndef MY_RF69_SPI_CS
                                  #ifndef MY_RF69_IRQ_NUM
                                  //#define MY_GATEWAY_W5100
                                  //#define MY_GATEWAY_ENC28J60
                                  //#define MY_GATEWAY_ESP8266
                                  #ifndef MY_PORT
                                  #define MY_PORT 5003
                                  //#define MY_USE_UDP
                                  #ifndef MY_MAC_ADDRESS
                                  #ifndef MY_NODE_UNLOCK_PIN
                                  #define MY_NODE_UNLOCK_PIN 14
                                  In node scetch:
                                  I have no logs from node because serial isn't working at all. Which logs should I attach?
                                  • Thar0lT Thar0l
                                    @tekka
                                    boards.txt:
                                    MyConfig.h:
                                    #undef MY_DEBUG
                                    //#define MY_RS485
                                    #ifndef MY_NODE_ID
                                    #ifndef MY_PORT
                                    In node scetch:
                                    tekkaT
                                    tekkaT
                                    tekka
                                    #55
                                    @Алексей-Гусаров I'll look into that. Seems like bootloader is not handing over to the sketch (corroborates previous reports). Can you post the OTA log (from e.g. MYSController)?
                                    • tekkaT tekka
                                      Thar0lT
                                      Thar0lT
                                      Thar0l
                                      @tekka I'm using mycotroller.org instead of myscontroller. It writes that "firmware update initiated" and nothing happens.
                                      tekkaT J 2 Replies Last reply
                                      • Thar0lT Thar0l
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Алексей-Гусаров Then I highly suggest to run MYSController to log OTA traffic for troubleshooting...
                                        • tekkaT tekka
                                          Thar0lT
                                          Thar0lT
                                          Thar0l
                                          @tekka OK, I'll try to do it tomorrow.
