  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 408.1k Views 39 Watching
  • rapzakR rapzak
    I have added som support, where the gateway can upload data to emoncms, transparant to other functions (not fully testet):
    in gatewayutil add this in top of file, after the ARDUINO check:
    #define EMONCMS
    #ifdef EMONCMS
    static WiFiClient emon_client;
    const char* emon_host = "emoncms.org";
    const int emon_httpPort = 80;
    const int emon_addr_offset = 10;
    Change this function to:
    //  if (mGetCommand(message) == C_PRESENTATION && inclusionMode) {
    //	gw.rxBlink(3);
    //   } else {
    //	gw.rxBlink(1);
       // Pass along the message from sensors to serial line
       serial(PSTR("%d;%d;%d;%d;%d;%s\n"),message.sender, message.sensor, mGetCommand(message), mGetAck(message), message.type, message.getString(convBuf));
    #ifdef EMONCMS
         if (!emon_client.connect(emon_host, emon_httpPort)) {
          Serial.println("emoncms connection failed");
          emon_client.print(String("GET /emoncms/input/post.json?&node="+ String(message.sender+emon_addr_offset)+"&json={"+String(message.sensor)+":"+message.getString(convBuf)+"}&apikey=XXXXXXXXXXXXXXXXXXXXXXXXXXXX\r\n"));
          Serial.println(String("GET /emoncms/input/post.json?&node="+ String(message.sender+emon_addr_offset)+"&json={"+String(message.sensor)+":"+message.getString(convBuf)+"}&apikey=XXXXXXXXXXXXXXXXXXXXXXXXXXXX\r\n"));
    It will upload data with NODE ID and Sensor ID from the network, with an offset of emon_addr_offset...
    /Rapzak
    RobbanR
    RobbanR
    Robban
    #define EMONCMS
    #ifdef EMONCMS
    //	gw.rxBlink(3);
    //   } else {
    //	gw.rxBlink(1);
    #ifdef EMONCMS
    /Rapzak
    Are there any one that can help me implement this in the dev version? Have a nodemcu 1-0 and got errors uploading the 1.5 version so i cant use that. Tried to fix it but ended up with the dev version.
    • B
      B
      bkenobi
      Can anyone provide the correct wiring for NodeMCU (ESP-12E) to RFM69HW? I have seen several different guides that show connections for RFM69, but there are several different patterns and none have worked so far. Perhaps I didn't get it right, but this is what I've seen and tried:
      someburner/esp-rfm69
      RFM69->	ESP-12E
      MISO	GPIO12
      MOSI	GPIO13
      SCK		GPIO14
      CS/SS	GPIO15
      DIO0	GPIO5
      VCC		3V3
      GND		GND
      ANA		<antenna>
      halburd/NodeMCU-Gateway
      RFM69->	NodeMCU
      NSS		GPIO2 (J2P5)
      SCK		SCK (J1P9)
      MISO	MISO (J1P8)
      MOSI	MOSI (J1P6)
      DIO0	SS (J1P7)
      VCC		3V3
      GND		GND
      ANA		<antenna>
      I've also determined that the following should also be correct, though again, they all don't match.
      RFM69	ESP-12E	WEMOS D1	NodeMCUv3
      MISO	GPIO12	D6/D12		D6
      MOSI	GPIO13	D7/D11		D7
      SCK		GPIO14	D5/D13		D5
      CS/SS	GPIO15	D10			D8
      DIO0	GPIO5	D3/D15		D1
      I've also tried to figure out how to use the nRF24L0+ wiring, but that doesn't quite match either. If someone could simply post a working config, I could get some traction on my project.
      • B
        B
        bkenobi
        Looking at the different charts, I've located some errors (I think).
        Looking at someburner's setup, it looks like he is opting to use software SPI rather than hardware as the ESP pins for SPI are not on GPIO12-15.
        Looking at halburd's code, it appears that he's opted to use GPIO2 for slave select and connect the actual SS to DIO0. I'm not clear why this is done, but it seems odd.
        I lost the reference to the last chart. It also uses GPIO's for SPI rather than the built-in hardware SPI. The guide in this sketch is only documented for nRF24L01+, so it doesn't match exactly. But, it also uses GPIO 4, 12, 13, 14, 15. It seems odd to use those rather than the SPI pins.
        • Mark SwiftM
          Mark SwiftM
          Mark Swift
          I tried to get the ESP8266 gateway working for 2 weeks but kept getting st=fail at various times. Switching to a serial gateway fixed it straight away? Is this a known issue? Is it perhaps related to having the ESP8266 and the nRF24L01's so close together? BTW, I tied both the normal gateway and the MQTT gateway without much success. The who time I thought it was a radio issue :-/
          This was all running on a NodeMCU v1.0.
          Mark
          YveauxY 2 Replies Last reply
          • Mark SwiftM Mark Swift
            Mark
            @Mark-Swift Did you follow the connection in the ESP build guide?
            Did you make any changes to the sketch? Which MySensors version did you use and which ESP Arduino version?
            Just asking all these questions so we can be of better help.
            Mark SwiftM 1 Reply Last reply
            • YveauxY Yveaux
              Mark SwiftM
              Mark SwiftM
              Mark Swift
              @Yveaux I believe so, the nNF24L01 is connected to a NodeMCU (I've tried feeding the radio off both the onboard 3.3v and via VIN and a 1117 3.3v regulator (I have caps across the radio GND / VCC).
              No changes were made to the sketch - I'm using the latest development build (also on the nodes). I've tried with all of the ESP Arduino board versions, doesn't seem to change anything?
                Mark
                Now I read over your post again I get the impression that it sometimes works, and sometimes you get st=fail. Is this correct?
                • Mark SwiftM
                  Mark SwiftM
                  Mark Swift
                  wrote on last edited by Mark Swift
                  #272
                  Example - I'm sat here right now with one of my nodes and the gateway connected to my Macbook via USB.
                  When using the serial gateway I get =ok after each item no problem; in fact I can't make it fail.
                  When using the ESP8266 MQTT gateway I get:
                  Starting repeater (RNNRA-, 2.0.0-beta)
                  Radio init successful.
                  send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,st=ok:R+M+L+T+D+Rpt
                  send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                  send: 3-3-0-0 s=1,c=0,t=1,pt=0,l=0,sg=0,st=ok:
                  send: 3-3-0-0 s=2,c=0,t=1,pt=0,l=0,sg=0,st=ok:
                  send: 3-3-0-0 s=3,c=0,t=16,pt=0,l=0,sg=0,st=fail:
                  send: 3-3-0-0 s=4,c=0,t=15,pt=0,l=0,sg=0,st=ok:
                  send: 3-3-0-0 s=10,c=0,t=1,pt=0,l=0,sg=0,st=fail:
                  send: 3-3-0-0 s=11,c=0,t=1,pt=0,l=0,sg=0,st=ok:
                  send: 3-3-0-0 s=12,c=0,t=23,pt=0,l=0,sg=0,st=fail:
                  send: 3-3-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                  send: 3-3-0-0 s=255,c=0,t=18,pt=0,l=10,sg=0,st=fail:2.0.0-beta
                  send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                  Init complete, id=3, parent=0, distance=1
                  Moisture Sensor: 0
                  send: 3-3-0-0 s=1,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
                  Rain Sensor: 0
                  send: 3-3-0-0 s=2,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
                  LUX: 54612
                  send: 3-3-0-0 s=3,c=1,t=37,pt=3,l=2,sg=0,st=ok:54612
                  Distance: 0 cm
                  send: 3-3-0-0 s=4,c=1,t=13,pt=2,l=2,sg=0,st=ok:0
                  No rain or moisture detected, landroid is not waiting: Status(0)
                  Landroid is free to go and is now waiting on the schedule: Status(0)
                  Landroid is home charging!
                  Sending landroidHome (1) status to gateway: send: 3-3-0-0 s=10,c=1,t=16,pt=1,l=1,sg=0,st=ok:1
                  Sending landroidWaitingTriggered (0) status to gateway: send: 3-3-0-0 s=11,c=1,t=16,pt=1,l=1,sg=0,st=ok:0
                  Sending timeElapsed (0) status to gateway: send: 3-3-0-0 s=12,c=1,t=48,pt=2,l=2,sg=0,st=fail:0
                  Using the serial gateway on a nano (Not connected to anything, just the nano and nRF24L01) I get:
                  send: 3-3-0-0 s=3,c=0,t=16,pt=0,l=0,sg=0,st=ok:
                  send: 3-3-0-0 s=10,c=0,t=1,pt=0,l=0,sg=0,st=ok:
                  send: 3-3-0-0 s=12,c=0,t=23,pt=0,l=0,sg=0,st=ok:
                  send: 3-3-0-0 s=255,c=0,t=18,pt=0,l=10,sg=0,st=ok:2.0.0-beta
                  Moisture Sensor: 0
                  Rain Sensor: 0
                  LUX: 54612
                  Distance: 69 cm
                  send: 3-3-0-0 s=4,c=1,t=13,pt=2,l=2,sg=0,st=ok:69
                  Landroid is out cutting the grass!
                  Sending landroidHome (0) status to gateway: send: 3-3-0-0 s=10,c=1,t=16,pt=1,l=1,sg=0,st=ok:0
                  Sending timeElapsed (0) status to gateway: send: 3-3-0-0 s=12,c=1,t=48,pt=2,l=2,sg=0,st=ok:0
                    Moisture Sensor: 0
                    Rain Sensor: 0
                    LUX: 54612
                    Distance: 0 cm
                    Moisture Sensor: 0
                    Rain Sensor: 0
                    LUX: 54612
                    Distance: 69 cm
                    @Mark-Swift It does work sometimes, so that rules out a lot of possible problems!
                    How do you power the NodeMCU & rest of the hardware?
                    Both NodeMCU & nRF are very sensitive to low/noisy supplies.
                    • YveauxY Yveaux
                      Mark SwiftM
                      Mark SwiftM
                      Mark Swift
                      @Yveaux I power the NodeMCU from either my Macbook Retina, or from a decent USB wall plug, tbh, it seems to make little difference which I use. I presume everyone else is powering them via the USB also?
                      I've also tried a spare NodeMCU and a bunch of radios. In fact, I've been trying to get this working for 3 weeks, it's literally going to cause a divorce soon :-/
                        @Mark-Swift The log mentions Moisture Sensor, Rain Sensor, LUX, Distance.
                        Are these real sensor connected (and yes, how) or virtual?
                        • Mark SwiftM
                          Mark SwiftM
                          Mark Swift
                          @Yveaux real sensors connected to my robot mower garage node...
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            @Yveaux Node code is here for reference:
                            http://pastebin.com/mxkLq1Rp
                              @Mark-Swift To be frank: I don't know.
                              I'm quite sure it has nothing to do with the ESP port, or software in general.
                              You could try different orientation of the nRF, or move it closer to the sensor(s).
                              Are you using an amplified nRF24 btw?
                              • Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                @Yveaux That's a shame, I'd really like to solve this. I've tried the radios orientated different ways but it makes little difference. Not using a PA+LNB, I was but gave up on it as I thought it was the issue (Now realise it wasn't).
                                Strange that I only see these issues with the ESP, and as soon as I switch to a Nano running the serial gateway they're gone.
                                  @Mark-Swift I always use my sniffer in this case to see what's going on on air, but I don't know if your marriage will survive another sniffer build :innocent:
                                  • Mark SwiftM
                                    Mark SwiftM
                                    Mark Swift
                                    #281
                                    @Yveaux I doubt it will, seems I'm destined to build a serial gateway, crap, I've invested so much time in this and tried everything!
                                    • Mark SwiftM
                                      Mark SwiftM
                                      Mark Swift
                                      #282
                                      @Yveaux How about this, for a laugh I just tried rolling the ESP8266 gateway back to v1.5 (master).
                                      Guess what? It works every time with no fails (communicating with my 2.0.0 beta node). So the issue lies with the latest development version somewhere, any ideas?
                                      Insane, I just took the gateway down the other end of the house and not one fail, wow! So okay, what was changed in version 2.0.0?
                                      UPDATE: After more investigation, the reason it was working is because v1.5 only has a straight forward gateway version, and until now I've been using the MQTT client. It seems the gateway versions work fine, but the MQTT client version create the fails!
                                      UPDATE 2: Okay, I can reproduce the fails with the gateway too, let me try and explain. When the gateway is not connected to anything (for example Domoticz) I get OK all of the time, no fails whatsoever. If I connect to Domoticz, I start to get fails against certain child sensors (it's always the same!). I presume it's sketch related, or even the amount of node updates I'm sending? As I believe the fails are the same I'm seeing with the MQTT client.
                                      UPDATE 3: Nearly 3 weeks in and I've just figured out what has been causing me all this pain. I've always commented out the default 9600 serial baud define on the ESP8266 sketches. It seems this combined with the 200ms TCP delay has been causing me my issues when connecting to my Windows 7 machine. S$%&*!
                                        @Mark-Swift Well, look on it from the bright side: your marriage is saved now :bowtie:
                                        There have been more reports from issues with connections to external servers (e.g. MQTT, Domotiocz) that take too long.
                                        Maybe we should pull @hek in as he wrote the MQTT client for ESP.
                                          What adjustments do you propose to the MQTT sketch/driver?
                                          12.5k
