  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 408.1k Views 39 Watching
  • YveauxY
    @robosensor said:
    2.0.0 is much more stable and I never seen any reboots/resets.
    That sounds promising! I'll have to give the 2.0.0 core a try myself then.
    • P
      P
      patrick schaerer
      wrote on last edited by patrick schaerer
      #237
      Thanks for your work!
      I made my wifigateway today and added variables for a static IP Adress.
      I also tried to add an DHT11 to the wifi gateway, but it didn't work. I cannot include those sensors because I need to startup while inclusion and this would restart the gateway.
      Mabe someone has an Idea how to add a sensor to the wifi gateway. edit: I found this thread on the forum ... http://forum.mysensors.org/topic/1387/sensors-on-gateway
       * Version 1.0 - Henrik EKblad
       * Contribution by Ivo Pullens (ESP8266 support)
       * The EthernetGateway sends data received from sensors to the WiFi link.
       * VERA CONFIGURATION:
       * LED purposes:
       * The ESP8266 however requires different wiring:
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4
       * CSN/CS     GPIO15
       * SCK        GPIO14
       * MISO       GPIO12
       * MOSI       GPIO13
        * Inclusion mode button:
      #define NO_PORTB_PINCHANGES
      #include <MySigningNone.h>
      #include <MyTransportNRF24.h>
      #include <MyTransportRFM69.h>
      #include <EEPROM.h>
      #include <MyHwESP8266.h>
      #include <ESP8266WiFi.h>
      #include <MyParserSerial.h>
      #include <stdarg.h>
      #include "GatewayUtil.h"
      const char *ssid =  "yourSSID";    // cannot be longer than 32 characters!
      const char *pass =  "yourPassword"; //
      IPAddress local_ip(192,168,0,6);
      IPAddress dns_address(192,168,0,1);
      IPAddress gateway_ip(192,168,0,1);
      IPAddress subnet(255,255,255,0);
      //Code for DHT Temp and Hum
      /*#include <DHT.h>
      #define CHILD_ID_HUM 9
      #define CHILD_ID_TEMP 10
      #define HUMIDITY_SENSOR_DIGITAL_PIN 1
      long intervall = 300000; //read Temp and Hum every 5 minutes
      long last_millis = -300000;
      DHT dht;
      float lastTemp;
      float lastHum;
      boolean metric = true;
      //End of Temp and Hum */
      #define INCLUSION_MODE_PIN  5 // Digital pin used for inclusion mode button
      #define RADIO_CE_PIN        4   // radio chip enable
      #define RADIO_SPI_SS_PIN    15  // radio SPI serial select
      #ifdef WITH_LEDS_BLINKING
      #define RADIO_ERROR_LED_PIN 7  // Error led pin
      #define RADIO_TX_LED_PIN    9  // the PCB, on board LED
      //MyTransportRFM69 transport;
      #ifdef MY_SIGNING_FEATURE
      MySigningNone signer;
      // Hardware profile
      MyHwESP8266 hw;
      MySensor gw(transport, hw
          , signer
        , RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN
      #define IP_PORT 5003         // The port you want to open
      #define MAX_SRV_CLIENTS 5    // how many clients should be able to telnet to this ESP8266
      // a R/W server on the port
      static WiFiServer server(IP_PORT);
      static WiFiClient clients[MAX_SRV_CLIENTS];
      static bool clientsConnected[MAX_SRV_CLIENTS];
      static inputBuffer inputString[MAX_SRV_CLIENTS];
      #define ARRAY_SIZE(x)  (sizeof(x)/sizeof(x[0]))
      void output(const char *fmt, ... )
        char serialBuffer[MAX_SEND_LENGTH];
        va_list args;
        va_start (args, fmt );
        va_end (args);
        Serial.print(serialBuffer);
        for (uint8_t i = 0; i < ARRAY_SIZE(clients); i++)
          if (clients[i] && clients[i].connected())
      //       Serial.print("Client "); Serial.print(i); Serial.println(" write");
             clients[i].write((uint8_t*)serialBuffer, strlen(serialBuffer));
        // Setup console
        hw_init();
        Serial.println(); Serial.println();
        Serial.println("ESP8266 MySensors Gateway");
        Serial.print("Connecting to "); Serial.println(ssid);
        (void)WiFi.begin(ssid, pass);
        while (WiFi.status() != WL_CONNECTED)
          delay(500);
          Serial.print(".");
        Serial.println("Connected!");
        Serial.print("IP: "); Serial.println(WiFi.localIP());
        Serial.flush();
        (void)WiFi.config(local_ip, dns_address, gateway_ip, subnet);
          delay(500);
          Serial.print(".");
        Serial.flush();
        server.begin();
        server.setNoDelay(true);
       /* //Code for Temp and Hum
        checkInclusionFinished();
        // Go over list of clients and stop any that are no longer connected.
        // If the server has a new client connection it will be assigned to a free slot.
        bool allSlotsOccupied = true;
          if (!clients[i].connected())
            if (clientsConnected[i])
              Serial.print("Client "); Serial.print(i); Serial.println(" disconnected");
              clients[i].stop();
            //check if there are any new clients
            if (server.hasClient())
              clients[i] = server.available();
              inputString[i].idx = 0;
              Serial.print("Client "); Serial.print(i); Serial.println(" connected");
              output(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
          bool connected = clients[i].connected();
          clientsConnected[i] = connected;
          allSlotsOccupied &= connected;
        if (allSlotsOccupied && server.hasClient())
          //no free/disconnected spot so reject
          Serial.println("No free slot available");
          WiFiClient c = server.available();
          c.stop();
        // Loop over clients connect and read available data
          while(clients[i].connected() && clients[i].available())
            char inChar = clients[i].read();
            if ( inputString[i].idx < MAX_RECEIVE_LENGTH - 1 )
              // if newline then command is complete
              if (inChar == '\n')
                // a command was issued by the client
                // we will now try to send it to the actuator
                inputString[i].string[inputString[i].idx] = 0;
                // echo the string to the serial port
                Serial.print("Client "); Serial.print(i); Serial.print(": "); Serial.println(inputString[i].string);
                parseAndSend(gw, inputString[i].string);
                // clear the string:
                // Finished with this client's message. Next loop() we'll see if there's more to read.
               // add it to the inputString:
               inputString[i].string[inputString[i].idx++] = inChar;
              Serial.print("Client "); Serial.print(i); Serial.println(": Message too long");
        if (millis() >= last_millis + intervall) {
          if (isnan(temperature)) {
            lastTemp = temperature;
          if (!metric) {
          Serial.print("T: ");
        if (isnan(humidity)) {
            lastHum = humidity;
            Serial.print("H: ");
            Serial.println(humidity);
        last_millis = millis();
      • A
        Alex B Goode
        Any chance to achieve some success using ESP-01 or I really have to buy ESP-07/12?
        I just have some ESP-01 modules already and I wonder if I can use them
        • A Alex B Goode
          @Alex-B-Goode the Spi bus is not available on the esp01 header, so you won't be able to connect the radio then...
            But I guess you could use it as a sensor node (mqtt/ethernet).
            • YveauxY Yveaux
              sdndba
              It's late (early morning) I did not want to read over all the last three months posts so my question... is there a solution for this problem? I just downloaded the latest library and found the NodeMCU will reboot when a node initializes. Data below. Just point me to the solution if you would please. Thanks very much.
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.54
              3;1;1;0;0;21.54
              0;0;3;0;9;read: 3-3-0 s=2,c=1,t=38,pt=7,l=5,sg=0:3.44
              3;2;1;0;38;3.44
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.76
              3;1;1;0;0;21.76
              3;2;1;0;38;3.44
              0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.11
              1;1;1;0;0;21.11
              0;0;3;0;9;read: 1-1-0 s=2,c=1,t=38,pt=7,l=5,sg=0:3.44
              1;2;1;0;38;3.44
              3;1;1;0;0;21.76
              3;2;1;0;38;3.44
              0;0;3;0;9;read: 0-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
              0;255;0;0;17;1.5.1
              0;0;3;0;9;read: 0-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
              Exception (28):
              epc1=0x40203911 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
              ctx: cont
              sp: 3ffefe50 end: 3fff00e0 offset: 01a0
              stack>>>
              3ffefff0: 3ffeef14 3ffeee8b 3ffeee84 402037d5
              3fff0000: 000000ff 00000003 00000006 00000001
              3fff0010: 00000001 00000000 3ffeeed8 00000030
              3fff0020: 00000000 3fffdc20 3ffef0ac 00000030
              3fff0030: 00000003 00000001 00000001 00000000
              3fff0040: 00000000 00000000 000000ff 00000023
              3fff0050: 00000006 40209ee1 3ffeee64 3ffeee64
              3fff0060: 00000000 00000000 3ffeee84 3ffeee84
              3fff0070: 3fffdc20 00000000 3ffef0a4 40202582
              3fff0080: 402020cc 3ffeee64 3fff1720 402051e6
              3fff0090: 00000000 00ffffff 0100000a 3ffef0ac
              3fff00a0: 00000000 00000000 00000016 40101941
              3fff00b0: 40205499 1100000a 00000000 3ffef0ac
              3fff00c0: 3fffdc20 00000000 3ffef0a4 402054c1
              3fff00d0: 00000000 00000000 3ffef0c0 40100114
              <<<stack<<<
              wdt reset
              tail 0
              chksum 0x42
              csum 0x42
              ~ld
              Connecting to TESTNETWORK
              ....Connected!
              IP: 10.0.0.17
              0;0;3;0;9;read: 0-0-0 s=6,c=0,t=13,pt=0,l=0,sg=0:
              0;6;0;0;13;
              0;0;3;0;9;read: 0-0-0 s=1,c=1,t=16,pt=2,l=2,sg=0:0
              0;1;1;0;16;0
              0;0;3;0;9;read: 0-0-0 s=4,c=1,t=2,pt=2,l=2,sg=0:0
              0;4;1;0;2;0
              0;0;3;0;9;read: 0-0-0 s=5,c=1,t=2,pt=2,l=2,sg=0:0
              0;5;1;0;2;0
              3;1;1;0;0;21.76
              3;2;1;0;38;3.44
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.97
              3;1;1;0;0;21.97
              3;2;1;0;38;3.44
              • E
                E
                emc2
                @Yveaux
                Is there any specific reason on why CE is plugged on D2?
                I'm asking as I want to add a BME280 sensor directly on my gateway and by default the I2C bus is on D2/D1. It can be changed to any pin with Wire.begin(SDA,SCL) so it is not a major problem, but for user friendliness it would be nicer id CE was plugged on D9 or eventually D4 or D3.
                If there is no specific reason can I change MyConfig.h line 329 to #define MY_RF24_CE_PIN 3 safely?
                Thanks again for this gateway!
                • E emc2
                  @Yveaux
                  Not that I know of.
                  • E
                    E
                    emc2
                    Switching it to D9 and adding #define MY_RF24_CE_PIN 3 directly to the program worked indeed.
                    Now everything seems to work either by moving the I2C bus or the CE. It may be nice to officially free up the I2C port on the next versions of the library by default? It could be easier than to modify each I2C sensor or even display libraries individually.
                    I will let it run a little while and if I don't see any major problem I will try to put the code in a new topic. Thanks for your fast answer @Yveaux !
                    • rapzakR
                      rapzakR
                      rapzak
                      wrote on last edited by rapzak
                      #245
                      I have added som support, where the gateway can upload data to emoncms, transparant to other functions (not fully testet):
                      in gatewayutil add this in top of file, after the ARDUINO check:
                      #define EMONCMS
                      #ifdef EMONCMS
                      static WiFiClient emon_client;
                      const char* emon_host = "emoncms.org";
                      const int emon_httpPort = 80;
                      const int emon_addr_offset = 10;
                      Change this function to:
                      //  if (mGetCommand(message) == C_PRESENTATION && inclusionMode) {
                      //	gw.rxBlink(3);
                      //   } else {
                      //	gw.rxBlink(1);
                         // Pass along the message from sensors to serial line
                         serial(PSTR("%d;%d;%d;%d;%d;%s\n"),message.sender, message.sensor, mGetCommand(message), mGetAck(message), message.type, message.getString(convBuf));
                      #ifdef EMONCMS
                           if (!emon_client.connect(emon_host, emon_httpPort)) {
                            Serial.println("emoncms connection failed");
                            emon_client.print(String("GET /emoncms/input/post.json?&node="+ String(message.sender+emon_addr_offset)+"&json={"+String(message.sensor)+":"+message.getString(convBuf)+"}&apikey=XXXXXXXXXXXXXXXXXXXXXXXXXXXX\r\n"));
                            Serial.println(String("GET /emoncms/input/post.json?&node="+ String(message.sender+emon_addr_offset)+"&json={"+String(message.sensor)+":"+message.getString(convBuf)+"}&apikey=XXXXXXXXXXXXXXXXXXXXXXXXXXXX\r\n"));
                      It will upload data with NODE ID and Sensor ID from the network, with an offset of emon_addr_offset...
                      /Rapzak
                      RobbanR 1 Reply Last reply
                        #246
                        hi.
                        Has someone already thought about using websockets with wifiGW ??? before I start to reinvent the wheel!
                        I have already made some tests with websockets but it was not with mysensors. it was not big tests too but I was able to have an html5 client with js. it was a simple test like blink led+serial monitor, receive/sending serial things. very simple!
                        I did this because I would like to have sort of display on my phone even if there are no controller. and I don't want to use spiffs and webserver. I prefer to have the stuff on client side and esp8266 acting as a simple websocket server. More lightweight I think, to handle something more complex if needed...For the client, then it could be html+boostrap or something more hybrid. I am not expert at this but I should be able to make some poc..but I don't want to waste my time if it already exists! I have lot of other projects so I don't know how long it could take, and maybe someone is faster on this, so it depends..but it's a feature I would like to have in future and I will make it when needed :)
                        So what do you think ??? dumb idea?
                          wrote on last edited by hek
                          #247
                          Yeah, thought about it the other day and found this.
                          https://github.com/Links2004/arduinoWebSockets
                          Would have been fun to create something cloud.mysensors.org where people could share sensor data (and of course make it embeddable on the forum). Creating a websocket gateway-variant would probably be my first choice if I decide going down that path.
                          It also seems to support wss which is kind of nice.
                            #248
                            @hek : cool so you think it could be useful too.
                            yes I use this lib, nice features and simple to use.
                            so, even if someone has already done something, maybe I will dig a little for fun, time to time...
                              I haven't done anything yet. The old head is just constantly spinning ideas you know ;)
                              So please go ahead and see if you can create a MyGatewayTransportWebsocket.cpp
                              • ErrKE
                                ErrKE
                                ErrK
                                @scalz @hek you can look at socket.io if you are thinking of using websockets.
                                hekH scalzS 2 Replies Last reply
                                • ErrKE ErrK
                                  @ErrK said:
                                  socket.io
                                  Yep, use it on my dayjob. Allows downgrade to polling which (I guess) the Arduino library doesn't support. Might be better to use raw websocket on the server side in this case.
                                  ErrKE 1 Reply Last reply
                                  • ErrKE ErrK
                                    #252
                                    @ErrK : yes I saw it too. but here a discussion about socket.io with esp websockets https://github.com/Links2004/arduinoWebSockets/issues/42
                                    very interesting ;)
                                    • scalzS scalz
                                      very interesting ;)
                                      @scalz @hek a local server on the ESP serving gateway status overview (connected clients, routing table, sensors presented by clients, data etc) would be a very nice addition to any gateway IMHO.
                                      The ESP has enough power/flash to implement this.
                                        @ErrK said:
                                        socket.io
                                        ErrKE
                                        ErrKE
                                        ErrK
                                        @hek: Yes, it has fallbacks to use other protocols. I think there is a setting if you don't want to use all the default protocols.
                                        @scalz: interesting discussion. It looks like the best way shuld be to only use the websockets :)
                                          #255
                                          @Yveaux: exactly what I was thinking ;) for monitoring :) and it could be fun to be able to show something on the phone without a controller (for instance when I visit my not geek friends, it looks more simple if something on the phone instead of setting up a controller).
                                          I started to look at dev branch last night but was too tired.... I visualize where are the changes to do, but maybe not all, I will ask you if I have some problems ;) A cool thing in websocket lib is broadcasting client is already implemented in it.
                                          12.5k
