  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 214.4k Views 36 Watching
    I'm unfortunately at about the same level as you. I can compile stuff and do basic troubleshooting, but merging the dev branch with the gateway code is way out of my league.
    micahM
    micahM
    micah
    There is no way you are at 3.275% knowledge like me... I've seen many of your posts on here and you are at least a 4.532%... lol.... no honestly I've liked your posts and you seem very knowledgeable. You've got to be at least a 84.5% ;)
    • Sander StolkS
      Sander StolkS
      Sander Stolk
      Can somebody tell me how to change the channel after compiling and using the Gateway for a couple of days?
      Changing the channel in MyConfig.h in the dir Raspberry doesnt bother even after a reboot.
      Still 0x4c channel / 76 when I run the PiSerialGateway program.
      alexsh1A 1 Reply Last reply
      • Sander StolkS Sander Stolk
        alexsh1A
        alexsh1A
        alexsh1
        Did you recompile the code after changing the channel?
        Sander StolkS 1 Reply Last reply
        • alexsh1A alexsh1
          Sander StolkS
          Sander StolkS
          Sander Stolk
          wrote on last edited by Sander Stolk
          #92
          @alexsh1 I did this after changeing the channel in MyConfig.h: make all && sudo make install
          Rebooted after that but no luck
          • mfalkviddM
            That should be sufficient but you could see if running make clean before make all helps.
              Sander StolkS
              Sander StolkS
              Sander Stolk
              #94
              @mfalkvidd I did the make clean and the make install and rebooted.
              Still 0x4c eq. 76
              Using username "pi".
              Server refused our key
              pi@192.168.1.14's password:
              ______                      _   _
              |  _  \                    | | (_)
              | | | |___  _ __ ___   ___ | |_ _  ___ ____
              | | | / _ \| '_ ` _ \ / _ \| __| |/ __|_  /
              | |/ / (_) | | | | | | (_) | |_| | (__ / /
              |___/ \___/|_| |_| |_|\___/ \__|_|\___/___|
              Last login: Sat Apr  9 18:41:17 2016 from 192.168.1.34
              Monday, 11 April 2016, 12:10:24 pm CEST
              Linux 4.1.18-v7+ armv7l GNU/Linux
              Uptime.............: 1 days, 17h29m13s
              Memory.............: 520336kB (Free) / 948056kB (Total)
              Load Averages......: 0.00, 0.01, 0.05 (1, 5, 15 min)
              Running Processes..: 97
              IP Addresses.......: 192.168.1.14
              pi@Domoticz3:~$ cd Raspberry/
              pi@Domoticz3:~/Raspberry$ cat MyConfig.h
               The MySensors library adds a new layer on top of the RF24 library.
               It handles radio network routing, relaying and ids.
               Created by Henrik Ekblad <henrik.ekblad@gmail.com>
               12/10/14 - Ported to Raspberry Pi by OUJABER Mohamed <m.oujaber@gmail.com>
              #ifndef MyConfig_h
              #define MyConfig_h
               * Configure Sensor Network
              #define RF24_CHANNEL       111             //RF channel for the sensor net, 0-127
              #define RF24_DATARATE      RF24_250KBPS   //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
              #define RF24_PA_LEVEL      RF24_PA_MAX    //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
              #define RF24_PA_LEVEL_GW   RF24_PA_MAX  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401+ in your gateway.
              #define BASE_RADIO_ID      ((uint64_t)0xA8A8E1FC00LL) // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
              // MySensors online examples defaults
              #define DEFAULT_CE_PIN 9
              #define DEFAULT_CS_PIN 10
               * Enable/Disable debug logging
              #define DEBUG
              #ifdef __Raspberry_Pi
                      #define vsnprintf_P vsnprintf
                      #define snprintf_P snprintf
                      #define PSTR(x) (x)
                      #define printf_P printf
                      #define strlen_P strlen
              pi@Domoticz3:~/Raspberry$ make clean
              rm -rf MyGateway MySensor MyMessage PiEEPROM PiGateway PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o PiGatewaySerial.o
              pi@Domoticz3:~/Raspberry$ make all
              g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
              g++ -c -o MySensor.o MySensor.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
              g++ -c -o MyMessage.o MyMessage.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
              g++ -c -o PiEEPROM.o PiEEPROM.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
              g++ -c -o PiGateway.o PiGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
              g++ -o PiGateway MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm
              g++ -c -o PiGatewaySerial.o PiGatewaySerial.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
              g++ -o PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGatewaySerial.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm -lutil
              pi@Domoticz3:~/Raspberry$ sudo reboot
              Broadcast message from pi@Domoticz3 on pts/1 (Mon 2016-04-11 12:12:17 CEST):
              The system is going down for reboot NOW!
              ______                      _   _
              |  _  \                    | | (_)
              Last login: Mon Apr 11 12:10:24 2016 from 192.168.1.34
              Monday, 11 April 2016, 12:12:45 pm CEST
              Uptime.............: 0 days, 00h00m25s
              Memory.............: 770952kB (Free) / 948056kB (Total)
              Load Averages......: 0.59, 0.16, 0.05 (1, 5, 15 min)
              Running Processes..: 100
              pi@Domoticz3:~$ ls
              bash_scripts  domoticz  Dropbox-Uploader  Raspberry  RF24
              pi@Domoticz3:~$ sudo /etc/init.d/PiGatewaySerial start
              [ ok ] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.service.
              pi@Domoticz3:~$ sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
              ln: failed to create symbolic link ‘/dev/ttyUSB20’: File exists
              pi@Domoticz3:~$ sudo /usr/local/sbin/PiGatewaySerial
              Starting PiGatewaySerial...
              Protocol version - 1.4
              Created PTY '/dev/pts/2'
              Gateway tty: /dev/ttyMySensorsGateway
              ================ SPI Configuration ================
              CSN Pin          = CE0 (PI Hardware Driven)
              CE Pin           = Custom GPIO25
              Clock Speed      = 8 Mhz
              ================ NRF Configuration ================
              STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
              RX_ADDR_P0-1     = 0xa8a8e
              RX_ADDR_P2-5     = 0xff 0xc4
              TX_ADDR          = 0xa8a8e1fc07
              RX_PW_P0-6       = 0x20 0x20 0x20 0x00 0x00 0x00
              EN_AA            = 0x3b
              EN_RXADDR        = 0x06
              RF_CH            = 0x4c
              RF_SETUP         = 0x23
              CONFIG           = 0x0e
              DYNPD/FEATURE    = 0x3f 0x06
              Data Rate        = 250KBPS
              Model            = nRF24L01+
              CRC Length       = 16 bits
              PA Power         = PA_LOW
              read: 5-5-5 s=5,c=5,t=5,pt=0,l=0:
              version mismatch
              ^CReceived SIGINT
              Exiting...
              pi@Domoticz3:~$
              mfalkviddM J 2 Replies Last reply
                Still 0x4c eq. 76
                ______                      _   _
                |  _  \                    | | (_)
                #ifndef MyConfig_h
                #define MyConfig_h
                #define DEBUG
                        #define PSTR(x) (x)
                ______                      _   _
                |  _  \                    | | (_)
                pi@Domoticz3:~$ ls
                Clock Speed      = 8 Mhz
                EN_AA            = 0x3b
                EN_RXADDR        = 0x06
                RF_CH            = 0x4c
                RF_SETUP         = 0x23
                CONFIG           = 0x0e
                Data Rate        = 250KBPS
                Model            = nRF24L01+
                PA Power         = PA_LOW
                version mismatch
                ^CReceived SIGINT
                Exiting...
                pi@Domoticz3:~$
                @Sander-Stolk I don't see a new make install in your output. Did you miss that or is the output just not included?
                make all compiles the code. The result is a binary file in the Raspberry folder
                make install copies the binary (and some scripts I think) from the Raspberry folder to the system folders.
                • Sander StolkS
                  Sander StolkS
                  Sander Stolk
                  Ok here's the deal to change the channel or other settings:
                  cd Raspberry
                  make clean
                  make all
                  sudo make install
                  Done!
                  • Tore André RosanderT
                    Tore André Rosander
                    wrote on last edited by Tore André Rosander
                    #97
                    Does anyone know what this error is about?
                    RPi2, NRF24l01, OSMC (Debian jessie), Domoticz v3.5051.
                    osmc@osmc:~/Raspberry$ sudo make install
                    Installing PiGatewaySerial to /usr/local/sbin
                    Installing PiGateway to /usr/local/sbin
                    Installing initscripts to /etc/init.d
                    Installing syslog config to /etc/rsyslog.d
                    Failed to restart rsyslog.service: Unit rsyslog.service failed to load: No such file or directory.
                    Makefile:79: recipe for target 'install-initscripts' failed
                    make: *** [install-initscripts] Error 6
                    I can run the gateway even with the error, i can also add it to Domoticz and send/receive data.
                    But after a few minutes i get a massive error in domoticz saying "(24) Too many files open" on every logentry and my domoticz loose connection to the Logitech mediaserver, remote Kodi hardware, mqtt server etc.
                    osmc@osmc:~/Raspberry$ sudo ./PiGatewaySerial
                    Clock Speed      = 8 Mhz
                    RX_ADDR_P0-1     = 0xa8a8e1fc00 0xa8a8e1fc00
                    RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
                    TX_ADDR          = 0xa8a8e1fc02
                    EN_AA            = 0x3b
                    EN_RXADDR        = 0x06
                    RF_CH            = 0x4c
                    RF_SETUP         = 0x23
                    CONFIG           = 0x0e
                    Data Rate        = 250KBPS
                    Model            = nRF24L01+
                    PA Power         = PA_LOW
                    • C
                      C
                      cingolanifede
                      Hi, is signing supported using this library? thanks.
                      • C cingolanifede
                        @cingolanifede the Raspberry Pi gateway does not support signing.
                        • B
                          B
                          BikeDan
                          I'm looking for some help in getting "PiGatewaySerial" running properly. I am having no issue running "PiGateway" and receiving all data from a counter node I'm using for testing. When I try to run "PiGatewaySerial", only intermittent data appears. For this example, I have my counter sending increasing integers at 1 second intervals, and receives fewer than 1 in 25 through the "PiGatewaySerial" script. I previously had this working reliably on a RPi2, reading in the tty output and logging it to a file. Now, I cannot repeat that on either that device, nor the current RPi B+ I'm working with. I'm sure there's some basic setting that I'm missing, but I can't seem to figure it out. Thanks!
                          An example of "PiGateway" correctly receiving all messages:
                          pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGateway
                          Starting Gateway...
                          Clock Speed	 = 8 Mhz
                          TX_ADDR		 = 0xe7e7e7e7e7
                          EN_AA		 = 0x3b
                          EN_RXADDR	 = 0x06
                          RF_CH		 = 0x4c
                          RF_SETUP	 = 0x23
                          CONFIG		 = 0x0e
                          Data Rate	 = 250KBPS
                          Model		 = nRF24L01+
                          PA Power	 = PA_LOW
                          [CALLBACK]0;0;3;0;14;Gateway startup complete.
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:906
                          [CALLBACK]0;33;1;0;38;906
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:907
                          [CALLBACK]0;33;1;0;38;907
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:908
                          [CALLBACK]0;33;1;0;38;908
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:909
                          [CALLBACK]0;33;1;0;38;909
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:910
                          [CALLBACK]0;33;1;0;38;910
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:911
                          [CALLBACK]0;33;1;0;38;911
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:912
                          [CALLBACK]0;33;1;0;38;912
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:913
                          [CALLBACK]0;33;1;0;38;913
                          an example of "PiGatewaySerial" missing most messages:
                          pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGatewaySerial
                          Created PTY '/dev/pts/1'
                          Clock Speed	 = 8 Mhz
                          EN_AA		 = 0x3b
                          EN_RXADDR	 = 0x06
                          RF_CH		 = 0x4c
                          RF_SETUP	 = 0x23
                          CONFIG		 = 0x0e
                          Data Rate	 = 250KBPS
                          Model		 = nRF24L01+
                          PA Power	 = PA_LOW
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:301
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:302
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:303
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:328
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:353
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:378
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:403
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:428
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:454
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:479
                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:504
                          I'm running a RPi B+, NRF24l01+, on a clean install of Jessie, and using only a few percent of the CPU power.
                          • rmtuckerR
                            rmtuckerR
                            rmtucker
                            I have been thinking about giving this a try But:-
                            The Raspberry port is using protocol version 1.4.
                            Do the sensors also have to use version 1.4?
                            • rmtuckerR rmtucker
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @rmtucker
                              No, the sensors can be running 1.5 or 2.0-beta, the PI will run a 1.4 version.
                              The only thing not supported by the PiGateway is message signing.
                              But I have a mix of sensors in 1.5, 1.6-beta and 2.0-beta in my home network, so it certainly works.
                              rmtuckerR 1 Reply Last reply
                              • GertSandersG GertSanders
                                @rmtucker
                                rmtuckerR
                                rmtuckerR
                                rmtucker
                                @GertSanders
                                Is it best to start with a blank jessie image and manually install/compile domoticz or just use the domoticz sd image?
                                The latter would be the easiest for me because i am useless with the CLI but if the first method is best??
                                • AnticimexA
                                  AnticimexA
                                  Anticimex
                                  Adding support for signing on a pi gw should just be a matter of implementing random number generation and use software signing. With slight modification in the software signing backend as it assumes Arduino api:s for obtaining a seed for the rng.
                                    @GertSanders
                                    @rmtucker if you want to be able to run the very latest version of Domoticz, use the Debian image and compile Domoticz from git.
                                    I use the Domoticz image. The downside is that I need to wait for new "official" Domoticz builds before upgrading, but the upside is that getting up and running was very easy.
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      @mfalkvidd
                                      Actually ... I started with an official Domoticz build, and then I indicated in the settings that I wanted to update with the beta version. Since then I'm always on the latest beta (v5143 at the moment).
                                        @mfalkvidd
                                        @GertSanders cool. How often is the beta updated? Every build?
                                        • rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          Just set this up on my existing Raspberry pi B+ Domoticz server and it is working perfectly so i have managed to get rid of the uno Gateway.
                                          Thank you so much,I can now try and squeeze it all in the Raspi case and the job is finished.
                                          12.5k
