  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 213.0k Views 36 Watching
  • mfalkviddM
    That should be sufficient but you could see if running make clean before make all helps.
    Sander StolkS 1 Reply Last reply
      Sander StolkS
      Sander StolkS
      Sander Stolk
      wrote on last edited by Sander Stolk
      #94
      @mfalkvidd I did the make clean and the make install and rebooted.
      Still 0x4c eq. 76
      Using username "pi".
      Server refused our key
      pi@192.168.1.14's password:
      ______                      _   _
      |  _  \                    | | (_)
      | | | |___  _ __ ___   ___ | |_ _  ___ ____
      | | | / _ \| '_ ` _ \ / _ \| __| |/ __|_  /
      | |/ / (_) | | | | | | (_) | |_| | (__ / /
      |___/ \___/|_| |_| |_|\___/ \__|_|\___/___|
      Last login: Sat Apr  9 18:41:17 2016 from 192.168.1.34
      Monday, 11 April 2016, 12:10:24 pm CEST
      Linux 4.1.18-v7+ armv7l GNU/Linux
      Uptime.............: 1 days, 17h29m13s
      Memory.............: 520336kB (Free) / 948056kB (Total)
      Load Averages......: 0.00, 0.01, 0.05 (1, 5, 15 min)
      Running Processes..: 97
      IP Addresses.......: 192.168.1.14
      pi@Domoticz3:~$ cd Raspberry/
      pi@Domoticz3:~/Raspberry$ cat MyConfig.h
       The MySensors library adds a new layer on top of the RF24 library.
       It handles radio network routing, relaying and ids.
       Created by Henrik Ekblad <henrik.ekblad@gmail.com>
       12/10/14 - Ported to Raspberry Pi by OUJABER Mohamed <m.oujaber@gmail.com>
      #ifndef MyConfig_h
      #define MyConfig_h
       * Configure Sensor Network
      #define RF24_CHANNEL       111             //RF channel for the sensor net, 0-127
      #define RF24_DATARATE      RF24_250KBPS   //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
      #define RF24_PA_LEVEL      RF24_PA_MAX    //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
      #define RF24_PA_LEVEL_GW   RF24_PA_MAX  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401+ in your gateway.
      #define BASE_RADIO_ID      ((uint64_t)0xA8A8E1FC00LL) // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
      // MySensors online examples defaults
      #define DEFAULT_CE_PIN 9
      #define DEFAULT_CS_PIN 10
       * Enable/Disable debug logging
      #define DEBUG
      #ifdef __Raspberry_Pi
              #define vsnprintf_P vsnprintf
              #define snprintf_P snprintf
              #define PSTR(x) (x)
              #define printf_P printf
              #define strlen_P strlen
      pi@Domoticz3:~/Raspberry$ make clean
      rm -rf MyGateway MySensor MyMessage PiEEPROM PiGateway PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o PiGatewaySerial.o
      pi@Domoticz3:~/Raspberry$ make all
      g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
      g++ -c -o MySensor.o MySensor.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
      g++ -c -o MyMessage.o MyMessage.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
      g++ -c -o PiEEPROM.o PiEEPROM.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
      g++ -c -o PiGateway.o PiGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
      g++ -o PiGateway MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm
      g++ -c -o PiGatewaySerial.o PiGatewaySerial.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
      g++ -o PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGatewaySerial.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm -lutil
      pi@Domoticz3:~/Raspberry$ sudo reboot
      Broadcast message from pi@Domoticz3 on pts/1 (Mon 2016-04-11 12:12:17 CEST):
      The system is going down for reboot NOW!
      ______                      _   _
      |  _  \                    | | (_)
      Last login: Mon Apr 11 12:10:24 2016 from 192.168.1.34
      Monday, 11 April 2016, 12:12:45 pm CEST
      Uptime.............: 0 days, 00h00m25s
      Memory.............: 770952kB (Free) / 948056kB (Total)
      Load Averages......: 0.59, 0.16, 0.05 (1, 5, 15 min)
      Running Processes..: 100
      pi@Domoticz3:~$ ls
      bash_scripts  domoticz  Dropbox-Uploader  Raspberry  RF24
      pi@Domoticz3:~$ sudo /etc/init.d/PiGatewaySerial start
      [ ok ] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.service.
      pi@Domoticz3:~$ sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
      ln: failed to create symbolic link ‘/dev/ttyUSB20’: File exists
      pi@Domoticz3:~$ sudo /usr/local/sbin/PiGatewaySerial
      Starting PiGatewaySerial...
      Protocol version - 1.4
      Created PTY '/dev/pts/2'
      Gateway tty: /dev/ttyMySensorsGateway
      ================ SPI Configuration ================
      CSN Pin          = CE0 (PI Hardware Driven)
      CE Pin           = Custom GPIO25
      Clock Speed      = 8 Mhz
      ================ NRF Configuration ================
      STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
      RX_ADDR_P0-1     = 0xa8a8e
      RX_ADDR_P2-5     = 0xff 0xc4
      TX_ADDR          = 0xa8a8e1fc07
      RX_PW_P0-6       = 0x20 0x20 0x20 0x00 0x00 0x00
      EN_AA            = 0x3b
      EN_RXADDR        = 0x06
      RF_CH            = 0x4c
      RF_SETUP         = 0x23
      CONFIG           = 0x0e
      DYNPD/FEATURE    = 0x3f 0x06
      Data Rate        = 250KBPS
      Model            = nRF24L01+
      CRC Length       = 16 bits
      PA Power         = PA_LOW
      read: 5-5-5 s=5,c=5,t=5,pt=0,l=0:
      version mismatch
      ^CReceived SIGINT
      Exiting...
      pi@Domoticz3:~$
      mfalkviddM J 2 Replies Last reply
      • Sander StolkS Sander Stolk
        Still 0x4c eq. 76
        ______                      _   _
        |  _  \                    | | (_)
        #ifndef MyConfig_h
        #define MyConfig_h
        #define DEBUG
                #define PSTR(x) (x)
        ______                      _   _
        |  _  \                    | | (_)
        pi@Domoticz3:~$ ls
        Clock Speed      = 8 Mhz
        EN_AA            = 0x3b
        EN_RXADDR        = 0x06
        RF_CH            = 0x4c
        RF_SETUP         = 0x23
        CONFIG           = 0x0e
        Data Rate        = 250KBPS
        Model            = nRF24L01+
        PA Power         = PA_LOW
        version mismatch
        ^CReceived SIGINT
        Exiting...
        pi@Domoticz3:~$
        @Sander-Stolk I don't see a new make install in your output. Did you miss that or is the output just not included?
        make all compiles the code. The result is a binary file in the Raspberry folder
        make install copies the binary (and some scripts I think) from the Raspberry folder to the system folders.
        • Sander StolkS
          Sander StolkS
          Sander Stolk
          Ok here's the deal to change the channel or other settings:
          cd Raspberry
          make clean
          make all
          sudo make install
          Done!
          • Tore André RosanderT
            Tore André Rosander
            wrote on last edited by Tore André Rosander
            #97
            Does anyone know what this error is about?
            RPi2, NRF24l01, OSMC (Debian jessie), Domoticz v3.5051.
            osmc@osmc:~/Raspberry$ sudo make install
            Installing PiGatewaySerial to /usr/local/sbin
            Installing PiGateway to /usr/local/sbin
            Installing initscripts to /etc/init.d
            Installing syslog config to /etc/rsyslog.d
            Failed to restart rsyslog.service: Unit rsyslog.service failed to load: No such file or directory.
            Makefile:79: recipe for target 'install-initscripts' failed
            make: *** [install-initscripts] Error 6
            I can run the gateway even with the error, i can also add it to Domoticz and send/receive data.
            But after a few minutes i get a massive error in domoticz saying "(24) Too many files open" on every logentry and my domoticz loose connection to the Logitech mediaserver, remote Kodi hardware, mqtt server etc.
            osmc@osmc:~/Raspberry$ sudo ./PiGatewaySerial
            Clock Speed      = 8 Mhz
            RX_ADDR_P0-1     = 0xa8a8e1fc00 0xa8a8e1fc00
            RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
            TX_ADDR          = 0xa8a8e1fc02
            EN_AA            = 0x3b
            EN_RXADDR        = 0x06
            RF_CH            = 0x4c
            RF_SETUP         = 0x23
            CONFIG           = 0x0e
            Data Rate        = 250KBPS
            Model            = nRF24L01+
            PA Power         = PA_LOW
            • C
              C
              cingolanifede
              Hi, is signing supported using this library? thanks.
              • C cingolanifede
                @cingolanifede the Raspberry Pi gateway does not support signing.
                • B
                  B
                  BikeDan
                  I'm looking for some help in getting "PiGatewaySerial" running properly. I am having no issue running "PiGateway" and receiving all data from a counter node I'm using for testing. When I try to run "PiGatewaySerial", only intermittent data appears. For this example, I have my counter sending increasing integers at 1 second intervals, and receives fewer than 1 in 25 through the "PiGatewaySerial" script. I previously had this working reliably on a RPi2, reading in the tty output and logging it to a file. Now, I cannot repeat that on either that device, nor the current RPi B+ I'm working with. I'm sure there's some basic setting that I'm missing, but I can't seem to figure it out. Thanks!
                  An example of "PiGateway" correctly receiving all messages:
                  pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGateway
                  Starting Gateway...
                  Clock Speed	 = 8 Mhz
                  TX_ADDR		 = 0xe7e7e7e7e7
                  EN_AA		 = 0x3b
                  EN_RXADDR	 = 0x06
                  RF_CH		 = 0x4c
                  RF_SETUP	 = 0x23
                  CONFIG		 = 0x0e
                  Data Rate	 = 250KBPS
                  Model		 = nRF24L01+
                  PA Power	 = PA_LOW
                  [CALLBACK]0;0;3;0;14;Gateway startup complete.
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:906
                  [CALLBACK]0;33;1;0;38;906
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:907
                  [CALLBACK]0;33;1;0;38;907
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:908
                  [CALLBACK]0;33;1;0;38;908
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:909
                  [CALLBACK]0;33;1;0;38;909
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:910
                  [CALLBACK]0;33;1;0;38;910
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:911
                  [CALLBACK]0;33;1;0;38;911
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:912
                  [CALLBACK]0;33;1;0;38;912
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:913
                  [CALLBACK]0;33;1;0;38;913
                  an example of "PiGatewaySerial" missing most messages:
                  pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGatewaySerial
                  Created PTY '/dev/pts/1'
                  Clock Speed	 = 8 Mhz
                  EN_AA		 = 0x3b
                  EN_RXADDR	 = 0x06
                  RF_CH		 = 0x4c
                  RF_SETUP	 = 0x23
                  CONFIG		 = 0x0e
                  Data Rate	 = 250KBPS
                  Model		 = nRF24L01+
                  PA Power	 = PA_LOW
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:301
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:302
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:303
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:328
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:353
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:378
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:403
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:428
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:454
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:479
                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:504
                  I'm running a RPi B+, NRF24l01+, on a clean install of Jessie, and using only a few percent of the CPU power.
                  • rmtuckerR
                    rmtuckerR
                    rmtucker
                    I have been thinking about giving this a try But:-
                    The Raspberry port is using protocol version 1.4.
                    Do the sensors also have to use version 1.4?
                    • rmtuckerR rmtucker
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @rmtucker
                      No, the sensors can be running 1.5 or 2.0-beta, the PI will run a 1.4 version.
                      The only thing not supported by the PiGateway is message signing.
                      But I have a mix of sensors in 1.5, 1.6-beta and 2.0-beta in my home network, so it certainly works.
                      rmtuckerR 1 Reply Last reply
                      • GertSandersG GertSanders
                        @rmtucker
                        rmtuckerR
                        rmtuckerR
                        rmtucker
                        @GertSanders
                        Is it best to start with a blank jessie image and manually install/compile domoticz or just use the domoticz sd image?
                        The latter would be the easiest for me because i am useless with the CLI but if the first method is best??
                        • AnticimexA
                          AnticimexA
                          Anticimex
                          Adding support for signing on a pi gw should just be a matter of implementing random number generation and use software signing. With slight modification in the software signing backend as it assumes Arduino api:s for obtaining a seed for the rng.
                            @GertSanders
                            @rmtucker if you want to be able to run the very latest version of Domoticz, use the Debian image and compile Domoticz from git.
                            I use the Domoticz image. The downside is that I need to wait for new "official" Domoticz builds before upgrading, but the upside is that getting up and running was very easy.
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @mfalkvidd
                              Actually ... I started with an official Domoticz build, and then I indicated in the settings that I wanted to update with the beta version. Since then I'm always on the latest beta (v5143 at the moment).
                                @mfalkvidd
                                @GertSanders cool. How often is the beta updated? Every build?
                                • rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  Just set this up on my existing Raspberry pi B+ Domoticz server and it is working perfectly so i have managed to get rid of the uno Gateway.
                                  Thank you so much,I can now try and squeeze it all in the Raspi case and the job is finished.
                                  • rmtuckerR
                                    rmtuckerR
                                    rmtucker
                                    This is the cpu usage,the spike is me compiling the software as above.
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      @mfalkvidd
                                      Well, that seems to be the case. Sometimes I see daily updates, sometimes a week passes by without any changes. I selected the BETA channel for updates and since then I have seen new functionality come in on a regular basis. Not all of it is relevant to Mysensors of course, but none the less it's fun to see Domoticz is developed actively.
                                      W 1 Reply Last reply
                                        @mfalkvidd
                                        W
                                        W
                                        wergeld
                                        @GertSanders I have seen no issues in Domoticz stable with CPU usage. Thing just purrs along. Will have to check when I get home but i believe my system uptime is approaching 1 year. It "just works" as they say.
                                        I would like to upgrade to mysensors 2.0 library by it looks like the Pi repo has not being updated as often (last I checked, anyway).
                                        • W wergeld
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @wergeld
                                          Correct, the PI repo is basically unchanged. But it still is compatible with the 2.0-beta Mysensors library.
