  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 212.9k Views 36 Watching
  • mfalkviddM
    I'm unfortunately at about the same level as you. I can compile stuff and do basic troubleshooting, but merging the dev branch with the gateway code is way out of my league.
    micahM 1 Reply Last reply
      micahM
      micahM
      micah
      There is no way you are at 3.275% knowledge like me... I've seen many of your posts on here and you are at least a 4.532%... lol.... no honestly I've liked your posts and you seem very knowledgeable. You've got to be at least a 84.5% ;)
      • Sander StolkS
        Sander StolkS
        Sander Stolk
        Can somebody tell me how to change the channel after compiling and using the Gateway for a couple of days?
        Changing the channel in MyConfig.h in the dir Raspberry doesnt bother even after a reboot.
        Still 0x4c channel / 76 when I run the PiSerialGateway program.
        alexsh1A 1 Reply Last reply
        • Sander StolkS Sander Stolk
          alexsh1A
          alexsh1A
          alexsh1
          Did you recompile the code after changing the channel?
          Sander StolkS 1 Reply Last reply
          • alexsh1A alexsh1
            Sander StolkS
            Sander StolkS
            Sander Stolk
            wrote on last edited by Sander Stolk
            #92
            @alexsh1 I did this after changeing the channel in MyConfig.h: make all && sudo make install
            Rebooted after that but no luck
            • mfalkviddM
              That should be sufficient but you could see if running make clean before make all helps.
                Sander StolkS
                Sander StolkS
                Sander Stolk
                #94
                @mfalkvidd I did the make clean and the make install and rebooted.
                Still 0x4c eq. 76
                Using username "pi".
                Server refused our key
                pi@192.168.1.14's password:
                ______                      _   _
                |  _  \                    | | (_)
                | | | |___  _ __ ___   ___ | |_ _  ___ ____
                | | | / _ \| '_ ` _ \ / _ \| __| |/ __|_  /
                | |/ / (_) | | | | | | (_) | |_| | (__ / /
                |___/ \___/|_| |_| |_|\___/ \__|_|\___/___|
                Last login: Sat Apr  9 18:41:17 2016 from 192.168.1.34
                Monday, 11 April 2016, 12:10:24 pm CEST
                Linux 4.1.18-v7+ armv7l GNU/Linux
                Uptime.............: 1 days, 17h29m13s
                Memory.............: 520336kB (Free) / 948056kB (Total)
                Load Averages......: 0.00, 0.01, 0.05 (1, 5, 15 min)
                Running Processes..: 97
                IP Addresses.......: 192.168.1.14
                pi@Domoticz3:~$ cd Raspberry/
                pi@Domoticz3:~/Raspberry$ cat MyConfig.h
                 The MySensors library adds a new layer on top of the RF24 library.
                 It handles radio network routing, relaying and ids.
                 Created by Henrik Ekblad <henrik.ekblad@gmail.com>
                 12/10/14 - Ported to Raspberry Pi by OUJABER Mohamed <m.oujaber@gmail.com>
                #ifndef MyConfig_h
                #define MyConfig_h
                 * Configure Sensor Network
                #define RF24_CHANNEL       111             //RF channel for the sensor net, 0-127
                #define RF24_DATARATE      RF24_250KBPS   //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
                #define RF24_PA_LEVEL      RF24_PA_MAX    //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
                #define RF24_PA_LEVEL_GW   RF24_PA_MAX  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401+ in your gateway.
                #define BASE_RADIO_ID      ((uint64_t)0xA8A8E1FC00LL) // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
                // MySensors online examples defaults
                #define DEFAULT_CE_PIN 9
                #define DEFAULT_CS_PIN 10
                 * Enable/Disable debug logging
                #define DEBUG
                #ifdef __Raspberry_Pi
                        #define vsnprintf_P vsnprintf
                        #define snprintf_P snprintf
                        #define PSTR(x) (x)
                        #define printf_P printf
                        #define strlen_P strlen
                pi@Domoticz3:~/Raspberry$ make clean
                rm -rf MyGateway MySensor MyMessage PiEEPROM PiGateway PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o PiGatewaySerial.o
                pi@Domoticz3:~/Raspberry$ make all
                g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                g++ -c -o MySensor.o MySensor.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                g++ -c -o MyMessage.o MyMessage.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                g++ -c -o PiEEPROM.o PiEEPROM.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                g++ -c -o PiGateway.o PiGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                g++ -o PiGateway MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm
                g++ -c -o PiGatewaySerial.o PiGatewaySerial.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                g++ -o PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGatewaySerial.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm -lutil
                pi@Domoticz3:~/Raspberry$ sudo reboot
                Broadcast message from pi@Domoticz3 on pts/1 (Mon 2016-04-11 12:12:17 CEST):
                The system is going down for reboot NOW!
                ______                      _   _
                |  _  \                    | | (_)
                Last login: Mon Apr 11 12:10:24 2016 from 192.168.1.34
                Monday, 11 April 2016, 12:12:45 pm CEST
                Uptime.............: 0 days, 00h00m25s
                Memory.............: 770952kB (Free) / 948056kB (Total)
                Load Averages......: 0.59, 0.16, 0.05 (1, 5, 15 min)
                Running Processes..: 100
                pi@Domoticz3:~$ ls
                bash_scripts  domoticz  Dropbox-Uploader  Raspberry  RF24
                pi@Domoticz3:~$ sudo /etc/init.d/PiGatewaySerial start
                [ ok ] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.service.
                pi@Domoticz3:~$ sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                ln: failed to create symbolic link ‘/dev/ttyUSB20’: File exists
                pi@Domoticz3:~$ sudo /usr/local/sbin/PiGatewaySerial
                Starting PiGatewaySerial...
                Protocol version - 1.4
                Created PTY '/dev/pts/2'
                Gateway tty: /dev/ttyMySensorsGateway
                ================ SPI Configuration ================
                CSN Pin          = CE0 (PI Hardware Driven)
                CE Pin           = Custom GPIO25
                Clock Speed      = 8 Mhz
                ================ NRF Configuration ================
                STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                RX_ADDR_P0-1     = 0xa8a8e
                RX_ADDR_P2-5     = 0xff 0xc4
                TX_ADDR          = 0xa8a8e1fc07
                RX_PW_P0-6       = 0x20 0x20 0x20 0x00 0x00 0x00
                EN_AA            = 0x3b
                EN_RXADDR        = 0x06
                RF_CH            = 0x4c
                RF_SETUP         = 0x23
                CONFIG           = 0x0e
                DYNPD/FEATURE    = 0x3f 0x06
                Data Rate        = 250KBPS
                Model            = nRF24L01+
                CRC Length       = 16 bits
                PA Power         = PA_LOW
                read: 5-5-5 s=5,c=5,t=5,pt=0,l=0:
                version mismatch
                ^CReceived SIGINT
                Exiting...
                pi@Domoticz3:~$
                mfalkviddM J 2 Replies Last reply
                  Still 0x4c eq. 76
                  ______                      _   _
                  |  _  \                    | | (_)
                  #ifndef MyConfig_h
                  #define MyConfig_h
                  #define DEBUG
                          #define PSTR(x) (x)
                  ______                      _   _
                  |  _  \                    | | (_)
                  pi@Domoticz3:~$ ls
                  Clock Speed      = 8 Mhz
                  EN_AA            = 0x3b
                  EN_RXADDR        = 0x06
                  RF_CH            = 0x4c
                  RF_SETUP         = 0x23
                  CONFIG           = 0x0e
                  Data Rate        = 250KBPS
                  Model            = nRF24L01+
                  PA Power         = PA_LOW
                  version mismatch
                  ^CReceived SIGINT
                  Exiting...
                  pi@Domoticz3:~$
                  @Sander-Stolk I don't see a new make install in your output. Did you miss that or is the output just not included?
                  make all compiles the code. The result is a binary file in the Raspberry folder
                  make install copies the binary (and some scripts I think) from the Raspberry folder to the system folders.
                  • Sander StolkS
                    Sander StolkS
                    Sander Stolk
                    Ok here's the deal to change the channel or other settings:
                    cd Raspberry
                    make clean
                    make all
                    sudo make install
                    Done!
                    • Tore André RosanderT
                      Tore André Rosander
                      wrote on last edited by Tore André Rosander
                      #97
                      Does anyone know what this error is about?
                      RPi2, NRF24l01, OSMC (Debian jessie), Domoticz v3.5051.
                      osmc@osmc:~/Raspberry$ sudo make install
                      Installing PiGatewaySerial to /usr/local/sbin
                      Installing PiGateway to /usr/local/sbin
                      Installing initscripts to /etc/init.d
                      Installing syslog config to /etc/rsyslog.d
                      Failed to restart rsyslog.service: Unit rsyslog.service failed to load: No such file or directory.
                      Makefile:79: recipe for target 'install-initscripts' failed
                      make: *** [install-initscripts] Error 6
                      I can run the gateway even with the error, i can also add it to Domoticz and send/receive data.
                      But after a few minutes i get a massive error in domoticz saying "(24) Too many files open" on every logentry and my domoticz loose connection to the Logitech mediaserver, remote Kodi hardware, mqtt server etc.
                      osmc@osmc:~/Raspberry$ sudo ./PiGatewaySerial
                      Clock Speed      = 8 Mhz
                      RX_ADDR_P0-1     = 0xa8a8e1fc00 0xa8a8e1fc00
                      RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
                      TX_ADDR          = 0xa8a8e1fc02
                      EN_AA            = 0x3b
                      EN_RXADDR        = 0x06
                      RF_CH            = 0x4c
                      RF_SETUP         = 0x23
                      CONFIG           = 0x0e
                      Data Rate        = 250KBPS
                      Model            = nRF24L01+
                      PA Power         = PA_LOW
                      • C
                        C
                        cingolanifede
                        Hi, is signing supported using this library? thanks.
                        • C cingolanifede
                          @cingolanifede the Raspberry Pi gateway does not support signing.
                          • B
                            B
                            BikeDan
                            I'm looking for some help in getting "PiGatewaySerial" running properly. I am having no issue running "PiGateway" and receiving all data from a counter node I'm using for testing. When I try to run "PiGatewaySerial", only intermittent data appears. For this example, I have my counter sending increasing integers at 1 second intervals, and receives fewer than 1 in 25 through the "PiGatewaySerial" script. I previously had this working reliably on a RPi2, reading in the tty output and logging it to a file. Now, I cannot repeat that on either that device, nor the current RPi B+ I'm working with. I'm sure there's some basic setting that I'm missing, but I can't seem to figure it out. Thanks!
                            An example of "PiGateway" correctly receiving all messages:
                            pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGateway
                            Starting Gateway...
                            Clock Speed	 = 8 Mhz
                            TX_ADDR		 = 0xe7e7e7e7e7
                            EN_AA		 = 0x3b
                            EN_RXADDR	 = 0x06
                            RF_CH		 = 0x4c
                            RF_SETUP	 = 0x23
                            CONFIG		 = 0x0e
                            Data Rate	 = 250KBPS
                            Model		 = nRF24L01+
                            PA Power	 = PA_LOW
                            [CALLBACK]0;0;3;0;14;Gateway startup complete.
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:906
                            [CALLBACK]0;33;1;0;38;906
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:907
                            [CALLBACK]0;33;1;0;38;907
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:908
                            [CALLBACK]0;33;1;0;38;908
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:909
                            [CALLBACK]0;33;1;0;38;909
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:910
                            [CALLBACK]0;33;1;0;38;910
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:911
                            [CALLBACK]0;33;1;0;38;911
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:912
                            [CALLBACK]0;33;1;0;38;912
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:913
                            [CALLBACK]0;33;1;0;38;913
                            an example of "PiGatewaySerial" missing most messages:
                            pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGatewaySerial
                            Created PTY '/dev/pts/1'
                            Clock Speed	 = 8 Mhz
                            EN_AA		 = 0x3b
                            EN_RXADDR	 = 0x06
                            RF_CH		 = 0x4c
                            RF_SETUP	 = 0x23
                            CONFIG		 = 0x0e
                            Data Rate	 = 250KBPS
                            Model		 = nRF24L01+
                            PA Power	 = PA_LOW
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:301
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:302
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:303
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:328
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:353
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:378
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:403
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:428
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:454
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:479
                            read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:504
                            I'm running a RPi B+, NRF24l01+, on a clean install of Jessie, and using only a few percent of the CPU power.
                            • rmtuckerR
                              rmtuckerR
                              rmtucker
                              I have been thinking about giving this a try But:-
                              The Raspberry port is using protocol version 1.4.
                              Do the sensors also have to use version 1.4?
                              • rmtuckerR rmtucker
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @rmtucker
                                No, the sensors can be running 1.5 or 2.0-beta, the PI will run a 1.4 version.
                                The only thing not supported by the PiGateway is message signing.
                                But I have a mix of sensors in 1.5, 1.6-beta and 2.0-beta in my home network, so it certainly works.
                                rmtuckerR 1 Reply Last reply
                                • GertSandersG GertSanders
                                  @rmtucker
                                  rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  @GertSanders
                                  Is it best to start with a blank jessie image and manually install/compile domoticz or just use the domoticz sd image?
                                  The latter would be the easiest for me because i am useless with the CLI but if the first method is best??
                                  • AnticimexA
                                    AnticimexA
                                    Anticimex
                                    Adding support for signing on a pi gw should just be a matter of implementing random number generation and use software signing. With slight modification in the software signing backend as it assumes Arduino api:s for obtaining a seed for the rng.
                                      @GertSanders
                                      @rmtucker if you want to be able to run the very latest version of Domoticz, use the Debian image and compile Domoticz from git.
                                      I use the Domoticz image. The downside is that I need to wait for new "official" Domoticz builds before upgrading, but the upside is that getting up and running was very easy.
                                        GertSandersG
                                        GertSandersG
                                        GertSanders
                                        @mfalkvidd
                                        Actually ... I started with an official Domoticz build, and then I indicated in the settings that I wanted to update with the beta version. Since then I'm always on the latest beta (v5143 at the moment).
                                          @mfalkvidd
                                          @GertSanders cool. How often is the beta updated? Every build?
