  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 212.9k Views 36 Watching
  • Sander StolkS Sander Stolk
    Can somebody tell me how to change the channel after compiling and using the Gateway for a couple of days?
    Changing the channel in MyConfig.h in the dir Raspberry doesnt bother even after a reboot.
    Still 0x4c channel / 76 when I run the PiSerialGateway program.
    alexsh1A
    alexsh1A
    alexsh1
    Did you recompile the code after changing the channel?
    Sander StolkS 1 Reply Last reply
    • alexsh1A alexsh1
      Sander StolkS
      Sander StolkS
      Sander Stolk
      wrote on last edited by Sander Stolk
      #92
      @alexsh1 I did this after changeing the channel in MyConfig.h: make all && sudo make install
      Rebooted after that but no luck
      • mfalkviddM
        That should be sufficient but you could see if running make clean before make all helps.
          Sander StolkS
          Sander StolkS
          Sander Stolk
          #94
          @mfalkvidd I did the make clean and the make install and rebooted.
          Still 0x4c eq. 76
          Using username "pi".
          Server refused our key
          pi@192.168.1.14's password:
          ______                      _   _
          |  _  \                    | | (_)
          | | | |___  _ __ ___   ___ | |_ _  ___ ____
          | | | / _ \| '_ ` _ \ / _ \| __| |/ __|_  /
          | |/ / (_) | | | | | | (_) | |_| | (__ / /
          |___/ \___/|_| |_| |_|\___/ \__|_|\___/___|
          Last login: Sat Apr  9 18:41:17 2016 from 192.168.1.34
          Monday, 11 April 2016, 12:10:24 pm CEST
          Linux 4.1.18-v7+ armv7l GNU/Linux
          Uptime.............: 1 days, 17h29m13s
          Memory.............: 520336kB (Free) / 948056kB (Total)
          Load Averages......: 0.00, 0.01, 0.05 (1, 5, 15 min)
          Running Processes..: 97
          IP Addresses.......: 192.168.1.14
          pi@Domoticz3:~$ cd Raspberry/
          pi@Domoticz3:~/Raspberry$ cat MyConfig.h
           The MySensors library adds a new layer on top of the RF24 library.
           It handles radio network routing, relaying and ids.
           Created by Henrik Ekblad <henrik.ekblad@gmail.com>
           12/10/14 - Ported to Raspberry Pi by OUJABER Mohamed <m.oujaber@gmail.com>
          #ifndef MyConfig_h
          #define MyConfig_h
           * Configure Sensor Network
          #define RF24_CHANNEL       111             //RF channel for the sensor net, 0-127
          #define RF24_DATARATE      RF24_250KBPS   //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
          #define RF24_PA_LEVEL      RF24_PA_MAX    //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
          #define RF24_PA_LEVEL_GW   RF24_PA_MAX  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401+ in your gateway.
          #define BASE_RADIO_ID      ((uint64_t)0xA8A8E1FC00LL) // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
          // MySensors online examples defaults
          #define DEFAULT_CE_PIN 9
          #define DEFAULT_CS_PIN 10
           * Enable/Disable debug logging
          #define DEBUG
          #ifdef __Raspberry_Pi
                  #define vsnprintf_P vsnprintf
                  #define snprintf_P snprintf
                  #define PSTR(x) (x)
                  #define printf_P printf
                  #define strlen_P strlen
          pi@Domoticz3:~/Raspberry$ make clean
          rm -rf MyGateway MySensor MyMessage PiEEPROM PiGateway PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o PiGatewaySerial.o
          pi@Domoticz3:~/Raspberry$ make all
          g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
          g++ -c -o MySensor.o MySensor.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
          g++ -c -o MyMessage.o MyMessage.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
          g++ -c -o PiEEPROM.o PiEEPROM.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
          g++ -c -o PiGateway.o PiGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
          g++ -o PiGateway MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm
          g++ -c -o PiGatewaySerial.o PiGatewaySerial.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
          g++ -o PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGatewaySerial.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm -lutil
          pi@Domoticz3:~/Raspberry$ sudo reboot
          Broadcast message from pi@Domoticz3 on pts/1 (Mon 2016-04-11 12:12:17 CEST):
          The system is going down for reboot NOW!
          ______                      _   _
          |  _  \                    | | (_)
          Last login: Mon Apr 11 12:10:24 2016 from 192.168.1.34
          Monday, 11 April 2016, 12:12:45 pm CEST
          Uptime.............: 0 days, 00h00m25s
          Memory.............: 770952kB (Free) / 948056kB (Total)
          Load Averages......: 0.59, 0.16, 0.05 (1, 5, 15 min)
          Running Processes..: 100
          pi@Domoticz3:~$ ls
          bash_scripts  domoticz  Dropbox-Uploader  Raspberry  RF24
          pi@Domoticz3:~$ sudo /etc/init.d/PiGatewaySerial start
          [ ok ] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.service.
          pi@Domoticz3:~$ sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
          ln: failed to create symbolic link ‘/dev/ttyUSB20’: File exists
          pi@Domoticz3:~$ sudo /usr/local/sbin/PiGatewaySerial
          Starting PiGatewaySerial...
          Protocol version - 1.4
          Created PTY '/dev/pts/2'
          Gateway tty: /dev/ttyMySensorsGateway
          ================ SPI Configuration ================
          CSN Pin          = CE0 (PI Hardware Driven)
          CE Pin           = Custom GPIO25
          Clock Speed      = 8 Mhz
          ================ NRF Configuration ================
          STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
          RX_ADDR_P0-1     = 0xa8a8e
          RX_ADDR_P2-5     = 0xff 0xc4
          TX_ADDR          = 0xa8a8e1fc07
          RX_PW_P0-6       = 0x20 0x20 0x20 0x00 0x00 0x00
          EN_AA            = 0x3b
          EN_RXADDR        = 0x06
          RF_CH            = 0x4c
          RF_SETUP         = 0x23
          CONFIG           = 0x0e
          DYNPD/FEATURE    = 0x3f 0x06
          Data Rate        = 250KBPS
          Model            = nRF24L01+
          CRC Length       = 16 bits
          PA Power         = PA_LOW
          read: 5-5-5 s=5,c=5,t=5,pt=0,l=0:
          version mismatch
          ^CReceived SIGINT
          Exiting...
          pi@Domoticz3:~$
          mfalkviddM J 2 Replies Last reply
            Still 0x4c eq. 76
            ______                      _   _
            |  _  \                    | | (_)
            #ifndef MyConfig_h
            #define MyConfig_h
            #define DEBUG
                    #define PSTR(x) (x)
            ______                      _   _
            |  _  \                    | | (_)
            pi@Domoticz3:~$ ls
            Clock Speed      = 8 Mhz
            EN_AA            = 0x3b
            EN_RXADDR        = 0x06
            RF_CH            = 0x4c
            RF_SETUP         = 0x23
            CONFIG           = 0x0e
            Data Rate        = 250KBPS
            Model            = nRF24L01+
            PA Power         = PA_LOW
            version mismatch
            ^CReceived SIGINT
            Exiting...
            pi@Domoticz3:~$
            @Sander-Stolk I don't see a new make install in your output. Did you miss that or is the output just not included?
            make all compiles the code. The result is a binary file in the Raspberry folder
            make install copies the binary (and some scripts I think) from the Raspberry folder to the system folders.
            • Sander StolkS
              Sander StolkS
              Sander Stolk
              Ok here's the deal to change the channel or other settings:
              cd Raspberry
              make clean
              make all
              sudo make install
              Done!
              • Tore André RosanderT
                Tore André Rosander
                wrote on last edited by Tore André Rosander
                #97
                Does anyone know what this error is about?
                RPi2, NRF24l01, OSMC (Debian jessie), Domoticz v3.5051.
                osmc@osmc:~/Raspberry$ sudo make install
                Installing PiGatewaySerial to /usr/local/sbin
                Installing PiGateway to /usr/local/sbin
                Installing initscripts to /etc/init.d
                Installing syslog config to /etc/rsyslog.d
                Failed to restart rsyslog.service: Unit rsyslog.service failed to load: No such file or directory.
                Makefile:79: recipe for target 'install-initscripts' failed
                make: *** [install-initscripts] Error 6
                I can run the gateway even with the error, i can also add it to Domoticz and send/receive data.
                But after a few minutes i get a massive error in domoticz saying "(24) Too many files open" on every logentry and my domoticz loose connection to the Logitech mediaserver, remote Kodi hardware, mqtt server etc.
                osmc@osmc:~/Raspberry$ sudo ./PiGatewaySerial
                Clock Speed      = 8 Mhz
                RX_ADDR_P0-1     = 0xa8a8e1fc00 0xa8a8e1fc00
                RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
                TX_ADDR          = 0xa8a8e1fc02
                EN_AA            = 0x3b
                EN_RXADDR        = 0x06
                RF_CH            = 0x4c
                RF_SETUP         = 0x23
                CONFIG           = 0x0e
                Data Rate        = 250KBPS
                Model            = nRF24L01+
                PA Power         = PA_LOW
                • C
                  C
                  cingolanifede
                  Hi, is signing supported using this library? thanks.
                  • C cingolanifede
                    @cingolanifede the Raspberry Pi gateway does not support signing.
                    • B
                      B
                      BikeDan
                      I'm looking for some help in getting "PiGatewaySerial" running properly. I am having no issue running "PiGateway" and receiving all data from a counter node I'm using for testing. When I try to run "PiGatewaySerial", only intermittent data appears. For this example, I have my counter sending increasing integers at 1 second intervals, and receives fewer than 1 in 25 through the "PiGatewaySerial" script. I previously had this working reliably on a RPi2, reading in the tty output and logging it to a file. Now, I cannot repeat that on either that device, nor the current RPi B+ I'm working with. I'm sure there's some basic setting that I'm missing, but I can't seem to figure it out. Thanks!
                      An example of "PiGateway" correctly receiving all messages:
                      pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGateway
                      Starting Gateway...
                      Clock Speed	 = 8 Mhz
                      TX_ADDR		 = 0xe7e7e7e7e7
                      EN_AA		 = 0x3b
                      EN_RXADDR	 = 0x06
                      RF_CH		 = 0x4c
                      RF_SETUP	 = 0x23
                      CONFIG		 = 0x0e
                      Data Rate	 = 250KBPS
                      Model		 = nRF24L01+
                      PA Power	 = PA_LOW
                      [CALLBACK]0;0;3;0;14;Gateway startup complete.
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:906
                      [CALLBACK]0;33;1;0;38;906
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:907
                      [CALLBACK]0;33;1;0;38;907
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:908
                      [CALLBACK]0;33;1;0;38;908
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:909
                      [CALLBACK]0;33;1;0;38;909
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:910
                      [CALLBACK]0;33;1;0;38;910
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:911
                      [CALLBACK]0;33;1;0;38;911
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:912
                      [CALLBACK]0;33;1;0;38;912
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:913
                      [CALLBACK]0;33;1;0;38;913
                      an example of "PiGatewaySerial" missing most messages:
                      pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGatewaySerial
                      Created PTY '/dev/pts/1'
                      Clock Speed	 = 8 Mhz
                      EN_AA		 = 0x3b
                      EN_RXADDR	 = 0x06
                      RF_CH		 = 0x4c
                      RF_SETUP	 = 0x23
                      CONFIG		 = 0x0e
                      Data Rate	 = 250KBPS
                      Model		 = nRF24L01+
                      PA Power	 = PA_LOW
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:301
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:302
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:303
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:328
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:353
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:378
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:403
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:428
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:454
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:479
                      read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:504
                      I'm running a RPi B+, NRF24l01+, on a clean install of Jessie, and using only a few percent of the CPU power.
                      • rmtuckerR
                        rmtuckerR
                        rmtucker
                        I have been thinking about giving this a try But:-
                        The Raspberry port is using protocol version 1.4.
                        Do the sensors also have to use version 1.4?
                        • rmtuckerR rmtucker
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @rmtucker
                          No, the sensors can be running 1.5 or 2.0-beta, the PI will run a 1.4 version.
                          The only thing not supported by the PiGateway is message signing.
                          But I have a mix of sensors in 1.5, 1.6-beta and 2.0-beta in my home network, so it certainly works.
                          rmtuckerR 1 Reply Last reply
                          • GertSandersG GertSanders
                            @rmtucker
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            @GertSanders
                            Is it best to start with a blank jessie image and manually install/compile domoticz or just use the domoticz sd image?
                            The latter would be the easiest for me because i am useless with the CLI but if the first method is best??
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              Adding support for signing on a pi gw should just be a matter of implementing random number generation and use software signing. With slight modification in the software signing backend as it assumes Arduino api:s for obtaining a seed for the rng.
                                @GertSanders
                                @rmtucker if you want to be able to run the very latest version of Domoticz, use the Debian image and compile Domoticz from git.
                                I use the Domoticz image. The downside is that I need to wait for new "official" Domoticz builds before upgrading, but the upside is that getting up and running was very easy.
                                  GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @mfalkvidd
                                  Actually ... I started with an official Domoticz build, and then I indicated in the settings that I wanted to update with the beta version. Since then I'm always on the latest beta (v5143 at the moment).
                                    @mfalkvidd
                                    @GertSanders cool. How often is the beta updated? Every build?
                                    • rmtuckerR
                                      rmtuckerR
                                      rmtucker
                                      Just set this up on my existing Raspberry pi B+ Domoticz server and it is working perfectly so i have managed to get rid of the uno Gateway.
                                      Thank you so much,I can now try and squeeze it all in the Raspi case and the job is finished.
                                      • rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        This is the cpu usage,the spike is me compiling the software as above.
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @mfalkvidd
                                          Well, that seems to be the case. Sometimes I see daily updates, sometimes a week passes by without any changes. I selected the BETA channel for updates and since then I have seen new functionality come in on a regular basis. Not all of it is relevant to Mysensors of course, but none the less it's fun to see Domoticz is developed actively.
                                          W 1 Reply Last reply
