  3. Arduinon startup complete request strange behaviour (python)
12 Posts 2 Posters 3.1k Views 1 Watching
  • marceltrapmanM Offline
    marceltrapman
    When the gateway is started up it sends a message 'Arduino startup complete' (at least that is what I see).
    But instead of using the 'normal' 5 field format I receive the below with 8 fields.
    Obviously this is wrong and it looks like one or two request are mixed up (possibly a request for a radioId together with the startup message)...
    Any idea how this can happen (using python and serial connection)...
    2014-04-29 01:16:36 MySensors Debug Receiving command 255;255;4;0;0;4;11;Arduino startup complete.
    Fulltime Servoy Developer
    hekH 1 Reply Last reply
      hekH Offline
      hekH Offline
      @marceltrapman
      Strange.
      serial(PSTR("0;0;%d;%d;Arduino startup complete.\n"),  M_INTERNAL, I_LOG_MESSAGE);
      This is the only thing i can find being printed during Gateway begin.
        marceltrapman
        @hek is it in any way possible that messages get scrambled on the gateway when they cross each other?
          hekH Offline
          hekH Offline
          @marceltrapman
          No, i don't really see how this could happen. Do you have any idea what other message it could have gotten mixed up with?
          What happens if you turn of debug-printing does it disappear?
            marceltrapman
            This happened with and without debug printing.
            The funny thing is that it appeared 'out of the blue', showed up a couple of restarts and it looks like it disappeared again with the last restart.
            I will keep an eye on it since I will need a lot of restarts before I am ready with the plugin ")
              marceltrapman
              wrote on last edited by marceltrapman
              OK, this time it is completely clear to me but I don't know why yet.
              Receiving command 1;2;2;2;0;0;4;11;Arduino startup complete.
              Two sensor/gateway messages were concatenated.
              The first a relay device 'reporting for duty', asking for the registered state of itself 1;2;2;2;
              And following the gateway reporting for duty: 0;0;4;11;Adruino startup complete
              Strange though that the gateway presentation comes after the sensor presentation...
                hekH Offline
                hekH Offline
                @marceltrapman
                Are you really "breaking" the commands on newline character on the phyton side? Please post your code ;)
                  marceltrapman
                  See below, the answer is yes. I do a readline() and it breaks on '\n' by default and MySensors does the same.
                  BTW I added the flush() after sending my previous post as well as removing all sleeping code from the sensor.
                  I will start playing with this because I suspect one of these two (or both) solved the issue.
                  I now see Receiving command 0;0;4;11;Arduino startup complete. before anything else :)
                  EDIT: false alarm. A new upload of the sketch and a restart made the issue appear again :(
                      try:
                          request = self.connection.readline()
                      except:
                          self.debugLog("Unexpected error:", sys.exc_info()[0])
                          request = None
                      finally:
                          self.connection.flush()
                          if request:
                              request = request.strip("\n\r")
                              self.debugLog("Receiving command %s" % request)
                        try:
                        except:
                            request = None
                        finally:
                            if request:
                    hekH Offline
                    hekH Offline
                    @marceltrapman
                    Should you really flush after calling readline()?
                      marceltrapman
                      Nope, this was a 'if it does not help it will not hurt'.
                      I am going to remove it.
                      • hekH Offline
                        hekH Offline
                        Hard to say,
                        It surely looks like readline() gives back more that one line to me.
                        I'm no phyton expert. But where is request-variable declared? Is it cleared between runs?
                          marceltrapman
                          Yes, all variables are cleared before I re-use them which is completely obsolete even because they are defined in the method and the method is called from within a/the loop.
                          I will ask the Indigo gurus about this...
                          113.2k
