  3. gw.sleep on battery powered magnet door switch
42 Posts 13 Posters 17.3k Views 16 Watching
  • ChakkieC Chakkie
    @AWI Thanks this clear thinks up but at the same time also confusing too.
    So "-2" activates both 0 and 1 on pin 2 or pin 3 as you mentioned earlier. I always though it represents a pin number.
    AWIA
    AWIA
    AWI
    @Chakkie The function digitalPinToInterrupt(pin) translates the pin number to the attached interrupt like "-2" does but in a reliable and more understandable way.
    ChakkieC 1 Reply Last reply
    • AWIA AWI
      ChakkieC
      ChakkieC
      Chakkie
      @AWI thanks. this looks like more promising.
      Raspberry Pi 2
      Domoticz
      RFXCOM
      ZWAVE Aeon stick
      Coming soon Arduino mysensors GW
      • mfalkviddM
        Pull request done for the development version: https://github.com/mysensors/Arduino/pull/441
        • siodS
          siodS
          siod
          I would like to build the same but I am still very confused now. Could you upload some pictures so I can make myself an image of how you wirde things together?
          Also I don´t really understand what happens here: gw.sleep(BUTTON_PIN_Deur - 2, CHANGE, BUTTON_PIN_Post - 2, CHANGE, 86400000);
          still learning...
          AWIA 1 Reply Last reply
          • siodS siod
            AWIA
            AWIA
            AWI
            wrote on last edited by AWI
            @siod If you are using a "standard" Atmega328 (pro-mini, etc.) don't make it hard for yourself. This processor has two external interrupts (0 & 1) connected to pins 2 & 3. Taking your line of code gw.sleep(BUTTON_PIN_Deur - 2, CHANGE, BUTTON_PIN_Post - 2, CHANGE, 86400000); the arguments are respectively:
            1. Use interrupt "0" (connected to pin 2 is BUTTON_PIN_Deur)
            2. Have is fired on change (i.e Rising and Falling)
            3. Use interrupt "1" (connected to pin 3 is BUTTON_PIN_Post)
            4. Have is fired on change (i.e Rising and Falling)
            5. Wake after every 86400000 ms (24 hrs) if no interrupt fired. To be safe you should use 86400000UL (the UL indicating that it is an Unsigned long type)
            siodS 1 Reply Last reply
            • AWIA AWI
              siodS
              siodS
              siod
              @AWI
              Ok thx for explanation, but that means he is using 2 reed switches, right (interrupt at pin2 and int pin3)?
              still learning...
              • siodS siod
                @AWI
                AWIA
                AWIA
                AWI
                @siod I guess so. But don't ask me why. One should be sufficient to detect if the door is open :smile:
                In addition (and for what it is worth). If you use a real low power circuit you can save around a factor 3 on battery lifetime when you get rid of the timed wakeup. The arduino sleeps a lot better when it doesn't have to look at the alarm clock every few ms :zzz:
                siodS ChakkieC 2 Replies Last reply
                • AWIA AWI
                  siodS
                  siodS
                  siod
                  @AWI
                  yes, makes sense, but how should you do this wihout the wakeup ? I guess this is just the disadvantage one must accept...
                  still learning...
                  • siodS siod
                    @AWI
                    AWIA
                    AWIA
                    AWI
                    @siod The wakeup function can be disabled by setting the timer values to 0 (or omitting it). There is no purpose in the sketch above for what I can see. If you want to have a kind of "hey I am still alive"/heartbeat feature you need to do a little more (e.g. sending battery level)
                    172pilot1 1 Reply Last reply
                    • AWIA AWI
                      172pilot1
                      172pilot1
                      172pilot
                      @AWI I was going to ask about that.. I dont see any reason to wake up every 24 hours just to go back to sleep again.. I assume the radio doesn't have any reason to send a keepalive or anything? So, you can omit that number, and it will sleep until interrupted? That's cool..
                      -Steve
                      • 172pilot1 172pilot
                        -Steve
                        AWIA
                        AWIA
                        AWI
                        @172pilot yes, no reason to wake up. Especially if there is a regular wake-up from interrupt to let the controller know it it is alive
                        • AWIA AWI
                          ChakkieC
                          ChakkieC
                          Chakkie
                          wrote on last edited by Chakkie
                          #27
                          @AWI
                          Thanks for the info. I thought you always have to add the sleep time to the gw.sleep. I will disable the a wake timer by removing the 86400000.
                          @siod I use one switch for the letterbox and one for the door.
                          Raspberry Pi 2
                          Domoticz
                          RFXCOM
                          ZWAVE Aeon stick
                          • siodS
                            siodS
                            siod
                            well, as you can see, if you don´t know the libraries exactly you accept things as they are or as they seem to be. I wasn´t aware that you can just set the wakeup function to 0. So this said I would like to thank you @AWI for your patience and your willingness of explaining also the most obvious things! :thumbsup:
                            still learning...
                            • T
                              treb0r
                              The sketch works with both reeds switches (2 windows) but how to integreate it with DS18B20 temp sensor? I also power it with battery, so I would like to check the temp eg every 5min and if it is changed then send the new value to the controler. How to wake up arduino only if any window is opened or temp is changed (after 5 min)
                              treb0r
                              dynamiteD 172pilot1 2 Replies Last reply
                              • T treb0r
                                treb0r
                                dynamiteD
                                dynamiteD
                                dynamite
                                @treb0r You can either wake up on the interrupt or on a time period:
                                bool sleep(int interrupt, int mode, unsigned long ms=0);
                                interrupt - Interrupt that should trigger the wakeup.
                                mode - RISING, FALLING, CHANGE
                                ms - Number of milliseconds to sleep (or 0 to sleep forever).
                                The sleep method returns true if wake up was triggered by pin change and false means timer woke it up.
                                • T treb0r
                                  treb0r
                                  172pilot1
                                  172pilot1
                                  172pilot
                                  @treb0r the problem is, you need to wake up the arduino to tell the temp sensor to take a new reading, so the best you can do is to trigger on the interrupts for the Windows and then use the timer to wake up and take the temperature reading, and then you'll have to compare to your saved value to decide whether it has been 5 degrees or not, so you can't completely sleep until that happens..
                                  • siodS
                                    siodS
                                    siod
                                    wrote on last edited by siod
                                    #32
                                    Hi guys,
                                    unfortunately I have to answer again to this topic because I don´t get my nodes work longer then up to two weeks. I guess it is still a sleep function problem and the problem persits though I am usin ver 2.0 now. Please have a look at my code, any hint is very appreciated!!
                                    I have attached 2 reed switches which should trigger a wakeup and one Hum/Temp Sensor is attached, too. I would like the device to send temp/hum measurements every 15 minutes, what works, but only for a few days or so. Then I also send battery level, that´s all.
                                    I have 3 devices up and running right now, they all fail once in while...
                                    // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geöffnet/geschlossen wird.
                                    // Define Node ID
                                    #define MY_NODE_ID 200
                                    //Batterysensor
                                    int oldBatteryPcnt = 0;
                                    #define CHILD_ID_BATT 7
                                    //Kontaktschalter
                                    //#include <Bounce2.h>
                                    int oldValueReed1=-1;
                                    int oldValueReed2=-1;
                                    //Tempsensor
                                    #include <SparkFunHTU21D.h>
                                    #define CHILD_ID_HUM 3
                                    #define CHILD_ID_TEMP 4
                                    //tempsensor
                                    HTU21D myHumidity;
                                    float lastTemp;
                                    float lastHum;
                                    //boolean metric = true;
                                    //Messages
                                    //Battery
                                    // Kontaktschalter
                                    //TempMessage
                                    void presentation(){
                                      sendSketchInfo("Schlafzimmer Messstation", "2.0");
                                      present(CHILD1_ID, S_DOOR);
                                      present(CHILD2_ID, S_DOOR);
                                      //Tempsensor
                                      present(CHILD_ID_HUM, S_HUM);
                                      //Battery
                                    //Setup
                                      //Serial.begin(9600);
                                      Serial.println("Hello!");
                                      //Batterysensor
                                       analogReference(INTERNAL1V1);
                                       analogReference(INTERNAL);
                                    //Tempsensor
                                      myHumidity.begin();
                                      Serial.println("...done!");
                                    // Setup Kontaktschalter 1
                                      pinMode(BUTTON1_PIN,INPUT);
                                        // Activate internal pull-up
                                    // Setup Kontaktschalter 2
                                      pinMode(BUTTON2_PIN,INPUT);
                                    //Starte den Loop
                                      //Batterysensor
                                      // get the battery Voltage
                                      delay(1000);
                                       #ifdef DEBUG
                                       #ifdef DEBUG
                                       Serial.print(batteryV);
                                       Serial.println(" V");
                                       Serial.print(batteryPcnt);
                                       Serial.println(" %");
                                         // Power up radio after sleep
                                         send(msgbatt.set(batteryPcnt));
                                         oldBatteryPcnt = batteryPcnt;
                                      //Kontakstschalter 1
                                      sleep(10);
                                      // Get the update value
                                         // Send in the new value
                                         send(msgReed1.set(valueReed1==HIGH ? 1 : 0));
                                         oldValueReed1 = valueReed1;
                                      //Kontakstschalter 2
                                         send(msgReed2.set(valueReed2==HIGH ? 1 : 0));
                                         oldValueReed2 = valueReed2;
                                     //Tempsensor
                                      if (isnan(temp)) {
                                        lastTemp = temp;
                                        send(msgTemp.set(temp, 1));
                                        Serial.print("T: ");
                                        Serial.println(temp);
                                      if (isnan(humd)) {
                                      } else if (humd != lastHum) {
                                          lastHum = humd;
                                          send(msgHum.set(humd, 1));
                                          Serial.print("H: ");
                                          Serial.println(humd);
                                     Serial.println("Sleep...");
                                    still learning...
                                    • slingS
                                      slingS
                                      sling
                                      @siod
                                      I'm assuming your batteries are empty when you say fail ?
                                      I built 5 of these last week for my dads place.
                                      I set internal pullups to LOW and soldered a 3,3MOhm resistor between VCC and Pin2.
                                      I'm seeing around 30µA when sleeping on two fresh AA batteries.
                                      With internal pullups that would be around 1ma and that would indeed drain the batteries quite fast.
                                      • siodS
                                        siodS
                                        siod
                                        no Sir, batteries are still at around 90% charged.
                                        still learning...
                                        • N
                                          N
                                          Nicklas Starkel
                                          @siod , I had the same problem.
                                          I actually ordered a original NRF 24 mini and this seemed to solve some of my problems.
                                          i think another problem I'm having is that my batteries has a huge self discharge (old 3.7v 18650)
                                          On a side note.. I'm with @sling .
                                          Loose the pullups and set them LOW´.
                                          I have a 1MOhm resistor between VCC and PIN 2 and PIN 3 (also 2 switches).
                                          Using the pullup HIGH draws around 130uA versus LOW it draws between 7 to 10uA!
                                          Nca78N 1 Reply Last reply
                                          12.5k
