  3. NRF24L01+PA+LNA power consumption
53 Posts 9 Posters 33.3k Views 9 Watching
  • OitzuO Oitzu
    @Jokgi hard to say to which module excatly it belongs.. would need to track the traces on the pcb to be 100% sure.
    Isn't CE pulled down by the MCU while not transmitting or receiving? I do not have really any problems with the module going power down.
    @parachutesj Well i got most problems with this sort of module, if you have the one pictured.
    They tended to not run at all without adding a grounded shield, add the LC-Filer and maked sure to run the signals with 3.3V.
    JokgiJ
    JokgiJ
    Jokgi
    @Jokgi @ all. Sorry I was not specific. I should have added Range measurements with and without the foil.
    • OitzuO
      OitzuO
      Oitzu
      @Jokgi it may be true that the ground filling seems to be quite good, but it seems like it needs also be shielded.
      Without the shielding the module is influenced by its own signals and external signals.
      There are also modules out there that have actually a shield added: http://www.aliexpress.com/item/Shielding-Case-10pcs-lot-nRF24L01-PA-LNA-wireless-communication-modules-with-antenna-2-4GHz-2Mbps-1000m/851058052.html
      But i have not tested them yet.
      By quantitative numbers you mean range?
      On max transmitting power i don't got even 5meters because the PA TX seems to overload the RX and ack will never be received.
      With the shielding i got arround 1000 meters free line of sight.
      • OitzuO Oitzu
        parachutesjP
        parachutesjP
        parachutesj
        wrote on last edited by parachutesj
        @Oitzu
        I got the new ones in the mail today. those are the shielded ones from IC station (http://www.icstation.com/22dbm-100mw-nrf24l01ppalna-wireless-transmission-module-p-4677.html)
        but even here when measuring current it never goes higher than 31mA
        I am going nuts. I mean I should be happy about the low power consumption but I think I haven't set them up correctly and not getting the full power.
        Again, I set in MyConfig.h
        #define RF24_PA_LEVEL_GW   RF24_PA_MAX
        and my constructor:
        MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL);
        I am measuring with a Fluke 87V and just making sure also took another one reading similar values.
        I ran the VCC through my multimeter - any ideas?
        • OitzuO
          OitzuO
          Oitzu
          @parachutesj i'm reading pretty much the same values on my multimeter, so nothing to worry about. ;)
          parachutesjP 1 Reply Last reply
          • OitzuO Oitzu
            parachutesjP
            parachutesjP
            parachutesj
            @Oitzu I just thougt that others reported 115mA and more.
            However the module with the shielding says 100mW that would make at 3.3v exactly 30.3 mA... So actually yes, all correct
            JokgiJ 1 Reply Last reply
            • JokgiJ
              JokgiJ
              Jokgi
              @Oitzu Thanks for the follow up. Yes, the CE line is a input to the nRF24L01P. In the schematic sent yesterday it showed the CE line connected to the RXEN of the RFX2401c. Both are inputs.
              • parachutesjP parachutesj
                JokgiJ
                JokgiJ
                Jokgi
                @parachutesj Unless you have the transmitter in constant carrier mode you cannot successfully measure the current with a standard multi-meter. If you want to know if the radio is transmitting and you have a good scope then look at the VDD_PA line.
                • OitzuO
                  OitzuO
                  Oitzu
                  @parachutesj as Jokgi said, you can't measure correctly the current of the modules with just a multimeter, you are losing peaks in the process.
                  Did you tried yet how far the shielded versions of the module reach? Would be great to have some sort of comparision. :+1:
                  • OitzuO Oitzu
                    parachutesjP
                    parachutesjP
                    parachutesj
                    @Oitzu
                    I do not have the equipment to measure the reach, I just noticed that some spots in the house seem to be covered which haven't been before. However this might be just because of different antenna placement.
                    • AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      #23
                      To demonstrate what happens I made some measurements on the NRF24L01+PA+LNA power consumption. The nano in the setup runs a simple sketch which sends one value every 100ms and sleeps in between (RF24_PA_MAX).
                      First is the setup with a standard nRF24L01+ (working clone ;-) ) The current meter measures the current in the power line of the radio (before the regulator to avoid side effects) and has an internal resistance of 3.4 Ohm. The measured current is a kind of random average sample and shows around 4 mA.
                      0_1464463953266_upload-0a19ffdd-3807-4724-9fd1-c809b69bff96
                      Now look at the waveform of the same current on the scope. I circled the radio send current. The level of pulse is around 70mV which translates to ~20mA (0.07 V/ 3.4 Ohm)
                      0_1464464509368_upload-399190d7-d122-4ebe-b88b-a2b4352eb726
                      Second is the setup with a the nRF24L01+PA+LNA(working clone ;-) )
                      0_1464464861402_upload-ea2156f5-3315-47a3-9568-62d1aa6b7687
                      and the waveform on the scope.. around 700mV translates to ~200mA (0.7V/ 3.4.Ohm) 10 times as much and no comparison to the (random average sample) reading on the current meter of ~22mA (a Fluke meter does not change this ;-))
                      0_1464465244455_upload-12912f74-4dfb-467a-9ae9-c0990c26eb50
                      • Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        @Oitzu said:
                        https://www.squirrel-labs.net/wp/wp-content/uploads/2015/02/nRFa.jpg
                        Guys,
                        I also use the base module to connect my NRF24 radios, I recently received 2 of the shielded PA+LNB modules but don't see much difference using them. The issue I have is that I need to hold the module for it to be reliable :( Once I let go, the transmission slows and becomes unreliable (I experienced the same with the unshielded modules).
                        Is the base module okay to use wit the PA+LNB modules, I was concerned that someone said the module cannot use 5v control lines?
                        AWIA 1 Reply Last reply
                        • Mark SwiftM Mark Swift
                          Guys,
                          AWIA
                          AWIA
                          AWI
                          #25
                          @Mark-Swift The "base plate" gives you a solid 3.3v for the radio and sufficient decouple/ bypass capacitors. i recognized there is a lot of variety in all kinds of radiio's even if these look similar. That's the reason I built this meter.
                          For shielding make sure you connect the shield to ground. A lot has been published on performance of these modules.
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            I'm using these modules, I presume the base unit is compatible? I was confused when I read above that the PA modules may need a 3v control line.
                            I'm really frustrated that none of my modules work unless I physically hold them, even the shielded ones above!
                            AWIA parachutesjP 2 Replies Last reply
                              AWIA
                              AWIA
                              AWI
                              @Mark-Swift High frequency transmission is a kind of dark science... ;-) I had the same experience you had with the 'expensive' shileded modules. The best performance upto now I have with my own shielding on the PA modules (plastic and aluminum tape/foil) powered by the adapter board and connected to a stable 5v supply.
                              • OitzuO
                                OitzuO
                                Oitzu
                                @Mark-Swift and @AWI i never worked with the adapter board, but doesn't shift the adapter board also the signal levels down?
                                @Mark-Swift need to hold the module is often a sign for non solid shielding or the shield is not grounded.
                                Out of courosity what power supply are you using in front of the adapter board?
                                Mark SwiftM AWIA 2 Replies Last reply
                                • OitzuO Oitzu
                                  Mark SwiftM
                                  Mark SwiftM
                                  Mark Swift
                                  @Oitzu I presume the shielded modules from IC station would be spot on with regards shielding?
                                  Right now I have my base module connected the 5v line of my Uno...?
                                  • OitzuO Oitzu
                                    AWIA
                                    AWIA
                                    AWI
                                    #30
                                    @Oitzu nothing fancy on the adapter board other than a LDO and decoupling (and a LED).
                                    0_1464695559079_upload-015c7695-c390-4466-aee0-6d242f64defe
                                    be aware that the schematic is for the 10p version of the nRf24
                                    • OitzuO
                                      OitzuO
                                      Oitzu
                                      @Mark-Swift well.. maybe you should give the module a little bit more current. :)
                                      I don't know which regulator the Uno uses but i would assume that it don't deliver enough current.
                                      About the grounding.. better be sure, take your multimeter and check if the shielding has continuity to GND.
                                      @AWI ah okay... well.. i'm still unsure if and which modules need the lower 3.3V level on CE.
                                      It just happens that i only use 3.3V arduinos.. and the raspberry pi, which also has 3.3V logic.
                                        parachutesjP
                                        parachutesjP
                                        parachutesj
                                        @Mark-Swift
                                        I received two of them a few days ago and both work very well. I soldered a cap onto it as suggested and pointing the antenna straight up (aligned with Z axis)
                                        One is just powered by an original Uno and the other via liniar power regulator. Not saying that this is enough, just in my case it is stable since Friday (3-4 days)
                                        Mark SwiftM 1 Reply Last reply
                                          @Mark-Swift
                                          Mark SwiftM
                                          Mark SwiftM
                                          Mark Swift
                                          @parachutesj
                                          Strange, how are you driving them, what volt control line, 5v?
                                          12.5k
