  3. NRF24L01+PA+LNA power consumption
53 Posts 9 Posters 33.3k Views 9 Watching
  • AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    #23
    To demonstrate what happens I made some measurements on the NRF24L01+PA+LNA power consumption. The nano in the setup runs a simple sketch which sends one value every 100ms and sleeps in between (RF24_PA_MAX).
    First is the setup with a standard nRF24L01+ (working clone ;-) ) The current meter measures the current in the power line of the radio (before the regulator to avoid side effects) and has an internal resistance of 3.4 Ohm. The measured current is a kind of random average sample and shows around 4 mA.
    0_1464463953266_upload-0a19ffdd-3807-4724-9fd1-c809b69bff96
    Now look at the waveform of the same current on the scope. I circled the radio send current. The level of pulse is around 70mV which translates to ~20mA (0.07 V/ 3.4 Ohm)
    0_1464464509368_upload-399190d7-d122-4ebe-b88b-a2b4352eb726
    Second is the setup with a the nRF24L01+PA+LNA(working clone ;-) )
    0_1464464861402_upload-ea2156f5-3315-47a3-9568-62d1aa6b7687
    and the waveform on the scope.. around 700mV translates to ~200mA (0.7V/ 3.4.Ohm) 10 times as much and no comparison to the (random average sample) reading on the current meter of ~22mA (a Fluke meter does not change this ;-))
    0_1464465244455_upload-12912f74-4dfb-467a-9ae9-c0990c26eb50
    • Mark SwiftM
      Mark SwiftM
      Mark Swift
      @Oitzu said:
      https://www.squirrel-labs.net/wp/wp-content/uploads/2015/02/nRFa.jpg
      Guys,
      I also use the base module to connect my NRF24 radios, I recently received 2 of the shielded PA+LNB modules but don't see much difference using them. The issue I have is that I need to hold the module for it to be reliable :( Once I let go, the transmission slows and becomes unreliable (I experienced the same with the unshielded modules).
      Is the base module okay to use wit the PA+LNB modules, I was concerned that someone said the module cannot use 5v control lines?
      AWIA 1 Reply Last reply
      • Mark SwiftM Mark Swift
        Guys,
        AWIA
        AWIA
        AWI
        #25
        @Mark-Swift The "base plate" gives you a solid 3.3v for the radio and sufficient decouple/ bypass capacitors. i recognized there is a lot of variety in all kinds of radiio's even if these look similar. That's the reason I built this meter.
        For shielding make sure you connect the shield to ground. A lot has been published on performance of these modules.
        • Mark SwiftM
          Mark SwiftM
          Mark Swift
          I'm using these modules, I presume the base unit is compatible? I was confused when I read above that the PA modules may need a 3v control line.
          http://www.icstation.com/22dbm-100mw-nrf24l01ppalna-wireless-transmission-module-p-4677.html
          I'm really frustrated that none of my modules work unless I physically hold them, even the shielded ones above!
          AWIA parachutesjP 2 Replies Last reply
            AWIA
            AWIA
            AWI
            @Mark-Swift High frequency transmission is a kind of dark science... ;-) I had the same experience you had with the 'expensive' shileded modules. The best performance upto now I have with my own shielding on the PA modules (plastic and aluminum tape/foil) powered by the adapter board and connected to a stable 5v supply.
            • OitzuO
              OitzuO
              Oitzu
              @Mark-Swift and @AWI i never worked with the adapter board, but doesn't shift the adapter board also the signal levels down?
              @Mark-Swift need to hold the module is often a sign for non solid shielding or the shield is not grounded.
              Out of courosity what power supply are you using in front of the adapter board?
              Mark SwiftM AWIA 2 Replies Last reply
              • OitzuO Oitzu
                Mark SwiftM
                Mark SwiftM
                Mark Swift
                @Oitzu I presume the shielded modules from IC station would be spot on with regards shielding?
                Right now I have my base module connected the 5v line of my Uno...?
                • OitzuO Oitzu
                  AWIA
                  AWIA
                  AWI
                  #30
                  @Oitzu nothing fancy on the adapter board other than a LDO and decoupling (and a LED).
                  0_1464695559079_upload-015c7695-c390-4466-aee0-6d242f64defe
                  be aware that the schematic is for the 10p version of the nRf24
                  • OitzuO
                    OitzuO
                    Oitzu
                    @Mark-Swift well.. maybe you should give the module a little bit more current. :)
                    I don't know which regulator the Uno uses but i would assume that it don't deliver enough current.
                    About the grounding.. better be sure, take your multimeter and check if the shielding has continuity to GND.
                    @AWI ah okay... well.. i'm still unsure if and which modules need the lower 3.3V level on CE.
                    It just happens that i only use 3.3V arduinos.. and the raspberry pi, which also has 3.3V logic.
                      parachutesjP
                      parachutesjP
                      parachutesj
                      @Mark-Swift
                      I received two of them a few days ago and both work very well. I soldered a cap onto it as suggested and pointing the antenna straight up (aligned with Z axis)
                      One is just powered by an original Uno and the other via liniar power regulator. Not saying that this is enough, just in my case it is stable since Friday (3-4 days)
                      Mark SwiftM 1 Reply Last reply
                      • parachutesjP parachutesj
                        @Mark-Swift
                        Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        @parachutesj
                        Strange, how are you driving them, what volt control line, 5v?
                        parachutesjP 1 Reply Last reply
                          AWIA
                          AWIA
                          AWI
                          @Mark-Swift The ones you refer are shielded.. as far as I can see.
                          0_1464696145069_upload-6475afd2-f07a-496f-be95-a8f71187f6cd
                          So next level in debugging... how is you ground connected,. You can try to power the adapter plate from the supply of your UNO. The on board LM1117 should be able to accept upto 20V.
                            @parachutesj
                            parachutesjP
                            parachutesjP
                            parachutesj
                            @Mark-Swift
                            no 3.3V.
                            However as said, it is an original Uno. I have clones which deliver no clean or reliable signal. I measured it before but don't remember exactly but was quite off.
                              @Mark-Swift
                              no 3.3V.
                              Mark SwiftM
                              Mark SwiftM
                              Mark Swift
                              @parachutesj said:
                              @Mark-Swift
                              no 3.3V.
                              The Uno has 5v control lines doesn't it?
                                @parachutesj said:
                                @Mark-Swift
                                no 3.3V.
                                parachutesjP
                                parachutesjP
                                parachutesj
                                @Mark-Swift
                                the digital ports? AFAIK yes.
                                the radio VCC is connected to 3.3 (all to the pins as in the tutorial GND, VCC 3.3, D9-D13)
                                The other setup is via external power (ipad USB-Adapter) to a breadboard, VIN directly from 5V to the Arduino and another line via 3.3V regulator to the NRF24 radio. all other lines again directly connected to the arduino.
                                • AWIA AWI
                                  Mark SwiftM
                                  Mark SwiftM
                                  Mark Swift
                                  @AWI Ground is connected from the baseboard back to the Uno, along with the VCC. That's how I'm currently powering it, 5V from uno into the adaptor plate. All other control lines directly into the Uno.
                                  • OitzuO
                                    OitzuO
                                    Oitzu
                                    hackaday caught wind on the tinfoil method.
                                    http://hackaday.com/2016/05/31/fixing-the-terrible-range-of-your-cheap-nrf24l01-palna-module/
                                    Maybe there also some points hidden in the comments that would help?
                                    • Mark SwiftM
                                      Mark SwiftM
                                      Mark Swift
                                      I saw this on Hackaday, could we make this change in MySensors?
                                      "Don’t use polling over SPI to check if there is a received packet like most of the libs out there do. This increases the noise. Use the IRQ pin"
                                      @hek
                                        In the development branch we do use irq nowadays, if you define
                                        #define MY_RF24_IRQ_PIN xx
                                        It also de-queues messages from the NRF24 quickly, which reduces missed messages.
                                        Mark SwiftM GertSandersG 2 Replies Last reply
                                          Mark SwiftM
                                          Mark SwiftM
                                          Mark Swift
                                          @hek amazing, I never knew that.
                                          So all I would do is define this line in my sketch and connect up the IRQ line?
                                          I presume I can use this on both my gateway (ESP8266) and my nodes (Nano / Uno)?
                                          12.5k
