716 Posts 111 Posters 717.2k Views 93 Watching
  • sundberg84S sundberg84
    @Matt Hi Matt - tnx.
    Try to measure here: whats your reading?
    if its 3.3v its your radio thats has some error... this is prettu much the last point before radio. Also measure VCC/GND under the pcb and not on top, what does it say?
    Sounds like a short or bad solder...
    Matt
    @sundberg84
    Ah crikey I think Im being thick, I just put a jumper across BAT connectors after tracing the lines and reading the manual, am now getting 2.8 at the NRF. Sorry for being a numpty. Still not picking up on my gateway, time to go to bed but will get the serial monitor running tomorrow....
    Thanks for the quick reply.
    • ValleV
      ValleV
      Valle
      Finally got my boards. In color: Yellow.
      If I would skip the Booster is the esiest thing to just wire Vi - Vo?
      • N
        N
        nunver
        I have a question about using this board as a gateway. Pinout of Mini Pro and Nano are almost identical. I built an adapter board to plug in a Nano into this board. Pin by pin control shows it is OK. I checked connectivity with MYSController. The gateway boots up. When I turn on my battery powered sensor, it asks for ID, the gateway "supposedly" sends it. I watch this from the messages. The sensor does not register. It asks four more times, the gateway responds four times. But sensor could not be ID'd and of course registered.
        I am thinking either reception problem on sensor side, or transmission problem on gateway side? Could it be a power problem related with design of the board? Is there any way to identify?
        • sundberg84S
          sundberg84S
          @Valle - yes you can just put a wire between left and right pin - but it wont work for a long time (the pro mini will die when battery goes below 3v i think).
          @nunver - I have never used this board as gateway. What does your controller say, does it apply an ID for the request?
          ValleV N 2 Replies Last reply
            ValleV
            ValleV
            Valle
            @sundberg84
            I'm using mfalkvidds Plant monitoring
            mfalkvidd said:
            So I will try without Booster. But for other sensors I will use booster.
            • ValleV Valle
              @sundberg84
              sundberg84S
              sundberg84S
              Sounds good - let us know how it works out for you. 2,34V is for a genuine Arduino so you know - I dont think a clone manages that... also the last energy (from 1,9 to 2,34v) is not used even though the radio could handle it if you used a booster.
              • Boots33B
                Boots33B
                Boots33
                Thanks @sundberg84 for this little board. I have just completed a sensor to monitor the state of our 12v house solar power supply.
                It uses an ACS712 Hall Effect Current Sensor Module to keep track of amps in and out of the battery. A voltage sensor to check battery levels and two DS18b20 temp sensors to monitor battery temp and ambient area temp. It reports back to our Domoticz server.
                  N
                  N
                  nunver
                  @sundberg84 yes it gives an ID of 1, but somehow sensor keeps asking four more times. At the end of the cycle, no ID is set. So no sensor shown.
                  • N nunver
                    sundberg84S
                    sundberg84S
                    What does the log node say - find parent?
                    This sounds like either software issue or most probably radio range/power issue,
                    • A
                      Affe
                      Hello, I'm just finished with 3 cards and test . I read on mysensor.org I'll connect NRF24L01+ Radio whit decoupling capacitor of 47µF and on your card whit 4,7µF
                      What is the difference?
                      • A Affe
                        #135
                        @Affe in practice, there is usually no difference. 4.7uF is enough, but 47uF doesn't hurt.
                        • Nca78N
                          I just ordered from DirtyPCB.
                          Thank you very much for this board which will obviously save me a lot of time with the radio connection.
                          I'm planning to use the boards for :
                          • as door+temp/humidity sensors for my children's bedrooms, not for the "security"/"safety" aspect but to manage AC more efficiently
                          • as window sensors for all windows in my appartment coupled with a rain sensor on the balcony, so I can ring an alarm/flash something/sens sms if it starts to rain and one of the windows is left opened. I'm in a tropical country and windows are opened most of the time, with the sudden and strong rains and winds we have sometime it can really be ugly :)
                          Power will most probably come from button cells and I will cut the right part of the PCB to fit in small and very cheap plastic boxes I find in shops here. I'm just waiting to see if the test sensor I have put on my entry door survives long enough with a CR2032.
                          • R
                            R
                            Rasenheizung
                            Could you give me the size when the pcb is fully soldered as battery sensor?
                            • sundberg84S
                              sundberg84S
                              @Nca78 - sounds great, let me know how it works out for you! Good luck!
                              @Rasenheizung - 50x50cm fully soldered. The dept is about 35mm (Batteryholder + PCB + Components)
                              • sundberg84S
                                sundberg84S
                                #139
                                So - I have a question for the community about boosters. I had a 3.3v Arduino running with my PCB. The radio is connected directly to the battery and the rest through a booster. I experienced alot of st:fails.
                                I tested adding a 0.1uF cap on the booster from OUT to GND and the st:fails became st:ok, even though the radio does not get its power from this booster.
                                Im sure the boosters are in different qualities and renders alot of noice - but could it effect the radio - through the arduino?
                                If this continues Im going to add the possibility to add this cap on my PCB. (Or maybe its possible to use 0.1uF cap by the voltage divider...)
                                Any feedback ?
                                alexsh1A 1 Reply Last reply
                                  Any feedback ?
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @sundberg84 typically, I try to add the lc-filter to the booster as some of them are very noisy. This is very simple - 3.3µH Axial lead inducter and a large 220µF capacitor (I use the SMD version). This helps to smooth any ripple effect.
                                    Samuel235
                                    Any sort of manipulation, including regulators and boosters, added to any module i would always attempt to filter and smooth the input AND the output of the devices. The noise from the boosters would technically be reaching your radio from those traces. I'm not sure if a diode would stop it from feeding back to the radio, but either way if it did i would still prefer to smooth and filter the power instead of stopping it coming backwards.
                                    MySensors 2.1.1
                                      #142
                                      @sundberg84
                                      it could be multiple things..
                                      But as alexsh1 said you can try to fix it with filtering.
                                      You can usea capa + an inductor or a ferrite bead too (a bit different), or a small resistor too can work like a snubber in fact. Generally 0-2ohms<100ohms, but the smaller the better depending of the capa too because it could generate drop out voltage. So for ferrite, it's the same, it's better to use a low ferrite res.
                                      But then, with filtering come some compromise regarding the booster efficiency and the load etc... Use formula and calc or the scope or iterate to choose the better compromise. But that should fix it mostly.
                                      There are two main strategy:
                                      • you filter each power input of concerned ics,
                                      • or you filter at powersupply (booster) output because lack of footprint on pcb.
                                      Note :
                                      • it's better for filtering to use small multilayer ceramic capa. low esr, low esl when you can, but again there can be some compromise in this.
                                      • shielded inductor on the booster module is better
                                      • if high esr and esl capacitor used at booster input, then you can have noise back into the batterie, and then propagate elsewhere. If it's your case, and can't fix it at power supply input, try to filter at your radio vcc input with another res for instance and a capa
                                      • there is also the ground loop, having a strong gnd, is better. this is one point why it's useful to use gnd pour plane on your pcb.
                                      • etc...
                                      I hope this will help you a bit ;)
                                      • Nca78N
                                        Boards received from DirtyPCB, they look gorgeous in white, too bad I have to put those ugly blue nrf and promini boards on top of it :P
                                        I received exactly 10, they are looking good except the silkscreen 1/2mm too much on the left for some of the boards
                                        • Nca78N
                                          @sundberg84 sorry to bother you but maybe you have an idea.
                                          I soldered components as in the picture below (looking so much cleaner than with all the cables...), I am using a 3.3V pro mini.
                                          Before soldering I tested the pro mini and the nrf24 together, connected with cables, and simulated the reed switch with some wires: everything was fine and I was receiving the open/close messages in domoticz.
                                          I soldered the components as below but I only got some "radio init failed" when connected to my PC, power coming to the GND/VCC on top of the arduino.
                                          As I put the jumper on "reg" to bypass the regulator, my understanding is that in this case the raw/power/vcc are all connected together, am I wrong ?
                                          Another subject, I suffered to cut the right part of the PCB with a cutter, would it be possible to add some slots along the black line to reduce a bit the length we have to cut ?
                                          S sundberg84S 2 Replies Last reply
                                          12.5k
