716 Posts 111 Posters 703.1k Views 93 Watching
  • scooter217S scooter217
    what size terminal blocks do you buy? I bought some and they are the wrong size.
    Samuel235
    #120
    @scooter217, from a quick inspection of the .brd file and a look around the internet for the datasheets it would seem that sundberg has allowed for any screw terminal block that uses a 5mm pin pitch. So you would need a 3 terminal 5mm pin pitch screw terminal. Please allow @sundberg84 some time to reply to ensure I am correct.
    MySensors 2.1.1
    • sundberg84S
      sundberg84S
      @scooter217 : http://www.ebay.com/sch/sis.html?_nkw=20pcs+KF301-2P+2+Pin+Plug-in+Screw+Terminal+Block+Connector+5.08mm+Pitch&_id=181759858196&&_trksid=p2057872.m2749.l2658
      scooter217S 1 Reply Last reply
      • sundberg84S sundberg84
        scooter217S
        scooter217S
        scooter217
        @sundberg84 Thank you, just ordered some from ebay!
          Matt
          wrote on last edited by Matt
          #123
          Hi Sundberg.
          First of all thanks for what you have done here, and hi from New Zealand.
          I have a problem though, sorry to be a hassle.
          I assembled my first board tonight and I dont get 3.3v across the NRF. It starts at 0.07V then falls down to 0 on my cheap meter. Same on the MYSX1.4 connector at 3.3 and gnd. Am getting 3.3 on the mini as well as VCC and GND on the MYSX area so the regulator is working. May be a short? Or a bad solder? Although they look good to me.... If so what solder joints should I redo? Any other ideas?
          Also, Ive traced back the VCC from the NRF and I cant see where it connects to a power source, either the battery in or the boost converter?
          Matt
          • M Matt
            Hi Sundberg.
            Matt
            sundberg84S
            sundberg84S
            @Matt Hi Matt - tnx.
            Try to measure here: whats your reading?
            if its 3.3v its your radio thats has some error... this is prettu much the last point before radio. Also measure VCC/GND under the pcb and not on top, what does it say?
            Sounds like a short or bad solder...
              Matt
              @sundberg84
              Ah crikey I think Im being thick, I just put a jumper across BAT connectors after tracing the lines and reading the manual, am now getting 2.8 at the NRF. Sorry for being a numpty. Still not picking up on my gateway, time to go to bed but will get the serial monitor running tomorrow....
              Thanks for the quick reply.
              • ValleV
                ValleV
                Valle
                Finally got my boards. In color: Yellow.
                If I would skip the Booster is the esiest thing to just wire Vi - Vo?
                • N
                  N
                  nunver
                  I have a question about using this board as a gateway. Pinout of Mini Pro and Nano are almost identical. I built an adapter board to plug in a Nano into this board. Pin by pin control shows it is OK. I checked connectivity with MYSController. The gateway boots up. When I turn on my battery powered sensor, it asks for ID, the gateway "supposedly" sends it. I watch this from the messages. The sensor does not register. It asks four more times, the gateway responds four times. But sensor could not be ID'd and of course registered.
                  I am thinking either reception problem on sensor side, or transmission problem on gateway side? Could it be a power problem related with design of the board? Is there any way to identify?
                  • sundberg84S
                    sundberg84S
                    @Valle - yes you can just put a wire between left and right pin - but it wont work for a long time (the pro mini will die when battery goes below 3v i think).
                    @nunver - I have never used this board as gateway. What does your controller say, does it apply an ID for the request?
                    ValleV N 2 Replies Last reply
                      ValleV
                      ValleV
                      Valle
                      @sundberg84
                      I'm using mfalkvidds Plant monitoring
                      mfalkvidd said:
                      So I will try without Booster. But for other sensors I will use booster.
                      • ValleV Valle
                        @sundberg84
                        sundberg84S
                        sundberg84S
                        Sounds good - let us know how it works out for you. 2,34V is for a genuine Arduino so you know - I dont think a clone manages that... also the last energy (from 1,9 to 2,34v) is not used even though the radio could handle it if you used a booster.
                        • Boots33B
                          Boots33B
                          Boots33
                          Thanks @sundberg84 for this little board. I have just completed a sensor to monitor the state of our 12v house solar power supply.
                          It uses an ACS712 Hall Effect Current Sensor Module to keep track of amps in and out of the battery. A voltage sensor to check battery levels and two DS18b20 temp sensors to monitor battery temp and ambient area temp. It reports back to our Domoticz server.
                            N
                            N
                            nunver
                            @sundberg84 yes it gives an ID of 1, but somehow sensor keeps asking four more times. At the end of the cycle, no ID is set. So no sensor shown.
                            • N nunver
                              sundberg84S
                              sundberg84S
                              What does the log node say - find parent?
                              This sounds like either software issue or most probably radio range/power issue,
                              • A
                                Affe
                                Hello, I'm just finished with 3 cards and test . I read on mysensor.org I'll connect NRF24L01+ Radio whit decoupling capacitor of 47µF and on your card whit 4,7µF
                                What is the difference?
                                • A Affe
                                  #135
                                  @Affe in practice, there is usually no difference. 4.7uF is enough, but 47uF doesn't hurt.
                                  • Nca78N
                                    I just ordered from DirtyPCB.
                                    Thank you very much for this board which will obviously save me a lot of time with the radio connection.
                                    I'm planning to use the boards for :
                                    • as door+temp/humidity sensors for my children's bedrooms, not for the "security"/"safety" aspect but to manage AC more efficiently
                                    • as window sensors for all windows in my appartment coupled with a rain sensor on the balcony, so I can ring an alarm/flash something/sens sms if it starts to rain and one of the windows is left opened. I'm in a tropical country and windows are opened most of the time, with the sudden and strong rains and winds we have sometime it can really be ugly :)
                                    Power will most probably come from button cells and I will cut the right part of the PCB to fit in small and very cheap plastic boxes I find in shops here. I'm just waiting to see if the test sensor I have put on my entry door survives long enough with a CR2032.
                                    • R
                                      R
                                      Rasenheizung
                                      Could you give me the size when the pcb is fully soldered as battery sensor?
                                      • sundberg84S
                                        sundberg84S
                                        @Nca78 - sounds great, let me know how it works out for you! Good luck!
                                        @Rasenheizung - 50x50cm fully soldered. The dept is about 35mm (Batteryholder + PCB + Components)
                                        • sundberg84S
                                          sundberg84S
                                          #139
                                          So - I have a question for the community about boosters. I had a 3.3v Arduino running with my PCB. The radio is connected directly to the battery and the rest through a booster. I experienced alot of st:fails.
                                          I tested adding a 0.1uF cap on the booster from OUT to GND and the st:fails became st:ok, even though the radio does not get its power from this booster.
                                          Im sure the boosters are in different qualities and renders alot of noice - but could it effect the radio - through the arduino?
                                          If this continues Im going to add the possibility to add this cap on my PCB. (Or maybe its possible to use 0.1uF cap by the voltage divider...)
                                          Any feedback ?
                                          alexsh1A 1 Reply Last reply
