  3. Looking to switch automation controller software
27 Posts 10 Posters 11.9k Views 8 Watching
  • D
    drock1985
    wrote on last edited by drock1985
    Hi @dbemowsk , welcome to MySensors.
    I don't think anything is currently written for the RS485 in regards to thermostat control. A quick Google did reveal there are modules available for Arduino that make the RS485 communication possible, so i'm sure writing a MySensors sketch/Node would be more that possible. Check out this link for an example.
    As for Controller software. I suggest shopping around. The easiest to start with would be Domoticz as most of the configuration (if not all) is GUI based via the Web Interface. A very close second would be Home-Assistant as they literally support almost all popular sensors/hardware/home components. It's a little bit more programming based, having configuration files written with YAML, but can be more rewarding.
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • dbemowskD
      dbemowskD
      Thanks @drock1985 . It has been a number of years since I created my thermostat plugin for Open Source Automation. I will have to see if I still have my code around somewhere for that. Maybe I can adapt it to the arduino. The hard part in it may be how I would adapt it to MySensors code.
      RS485 modules for arduino are cheap:
      http://www.ebay.com/itm/First-rate-MAX485-RS-485-Module-TTL-to-RS-485-module-for-Arduino-Raspberry-EFC-/291731314046?hash=item43ec8a957e:g:KegAAOSwnDxUp7o9
      • D
        drock1985
        Hi @dbemowsk
        I don't think it would be too hard to adapt the code over to MySensors. Check out the Library and Serial API pages to get an idea of how the messages can be constructed.
        As for making them talk to each other, there may already be someone doing this, or has done it in the past with an Arduino. it would be worth Googling for things like "Arduino thermostat (insert your brand/model here)" and see what comes up. If not, backwards engineering should be ok too (serial read maybe?)
        In any event good luck and have fun! If you ever get stuck, post in the forums and if you are new to Arduino in general, there are a lot of great tutorials on the internet/YouTube or my personal favourite, a course from a place like Udemy can be useful.
        My Projects
        2 Door Chime Sensor
        hekH 1 Reply Last reply
        • D drock1985
          Hi @dbemowsk
          Hey guys,
          https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewaySerialRS485/GatewaySerialRS485.ino
          https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyTransportRS485.cpp
          (background)
          https://forum.mysensors.org/topic/1947/rs485-rs232-serial-transport-class-for-mysensors-org
          • P
            P
            pjr
            @dbemowsk did you mean setup like this? controller <- usb -> GW <- rf -> "gateway node" <- rs485 -> thermostat network. If so, I have done it with my heat pump. I have "gateway node" that translates modbus to mysensors to/from my heat pump.
            AWIA 1 Reply Last reply
            • P pjr
              AWIA
              AWIA
              AWI
              @pjr sounds interesting, can you share some details?
              • dbemowskD
                dbemowskD
                @pjr that is exactly what I am talking about. The only thing on my RS485 network is my thermostat. As I mentioned before, I had written a plugin for a project called Open Source Automation that I worked on a few years back and will be trying to find that code. Can't remember if I did that one in Visual Basic or C#. If I did it in VB, it may take a bit to port it to arduino, but if I did it in C#, porting it shouldn't be that hard at all. I just need to bridge that gap.
                K 1 Reply Last reply
                • P
                  P
                  pjr
                  wrote on last edited by pjr
                  @AWI I'm kinda waiting that someone with more skills could implement this. Then I can finalize my functionality and a post project topic about it.
                  If someone wants to have current version of the source just pm me!
                  @dbemowsk what protocol your thermostat is "speaking"?
                  • dbemowskD
                    dbemowskD
                    The protocol as far as I know is specific to RCS hardware. I have never compared it to modus or anything, but it may be similar.
                    • dbemowskD dbemowsk
                      K
                      K
                      kimot
                      @dbemowsk You can use NODE RED as a translator between your hardware and protokol and then send translated messages to Domoticz ( for example). I think NODE RED + any sw controller is very powerfull combination.
                      • dbemowskD
                        dbemowskD
                        @kimot Does NODE RED have any kind of web interface for flows that are created? I am not seeing anything on their website.
                        • mfalkviddM
                          This is what node red looks like
                          From https://learn.adafruit.com/raspberry-pi-hosting-node-red/what-is-node-red
                          • dbemowskD
                            dbemowskD
                            @mfalkvidd I can see that being nice for the logic side, but what I was asking about when I mentioned a web interface was some nice easy way of looking up the status of devices from something like a floorplan or list view, and a way to control those devices manually if I see the need.
                            D K 2 Replies Last reply
                              drock1985
                              @dbemowsk
                              Domoticz. Domoticz offers floorplan setup (just upload a .jpg of the plan) and has manual switches you can set up. As well, the automation uses blocky - an easy to use GUI way of automating. Or LUA; if you are feeling brave.
                              My Projects
                              2 Door Chime Sensor
                                K
                                K
                                kimot
                                @dbemowsk I think, that for example Domoticz does not understood your RS485 thermostat. So you can recieve its message by serial node in NODE RED,
                                decode message and send it via HTTP to the Domnoticz. Or you are not happy with Domoticz graph style end limitation only 7 days for detail teperature storage. So you can first recieve data from sensor by NODE RED, store them to the file or database and then send them to the Domoticz. I wrote that NODE RED is good for cooperation with other sw controllers, witch do visualisation measured data.
                                • dbemowskD
                                  dbemowskD
                                  @kimot I see, you are only using NODE RED as a go between for Domoticz, not as the actual controller itself. Like a way to interface hardware that Domoticz doesn't normally recognize.
                                  • DidiD
                                    DidiD
                                    Didi
                                    Read this for a Nodered userinterface
                                    http://tech.scargill.net/node-red-ui/
                                    http://tech.scargill.net/more-node-red-ui/
                                    • F
                                      F
                                      Fabien
                                      node-red-ui is currently switching to node-red-dashboard and maintained by the core team.
                                      • DidiD
                                        DidiD
                                        Didi
                                        I don´t have noticed that.
                                        Here is the github link
                                        • dbemowskD
                                          dbemowskD
                                          So in the interest of keeping my current HA setup running while I get this set up and tested, I figured that this might be a place to use a new controller I got a while back. The controller is an Orange Pi. When a guy from work said he could get me one for $18 US, I couldn't say no. I have had it sitting around for a couple months now waiting to find a use for it. I think I found my use.
                                          The unit that I have is an Orange Pi PC which has a 1.6GHz quad coreprocessor with 1GB ram. A lot of choices for OS. Need to find me an 8GB class 10 MicroSD card (Might have one laying around). Then I want to find an automation software that is easy to install and use with this computer. Has anyone in here used an Orange Pi, and if so, what automation software have you used with it?
