push buttons / only 1 state
Ok, so I am still very very new to this. I made what I am trying to do work, but I am curious if I just fudged it or if there is a "proper" way to go about it.
I have a basic sensor setup. I am testing it right now by having 1 momentary push button. I got everything working all the way through to my openhab setup. However, when i push the button the state 1 is sent. Perfect. But as soon as I let go it sends 0. Now, I understand why it would. Makes total sense. But in this case, I only want something to happen when I press the button. Not when I release.
Not sure if there is a better way to go about it, but I did this.
if (value != oldValue) { // Send in the new value if (value==HIGH){ gw.send(msg.set(value==HIGH ? 1 : 0)); } oldValue = value; }I just wrapped the send with an If statement to only run the gw.send when it's high.
Is there a better way to do this?
@Jason-Brunk the code you have now could be reduced to
if (value != oldValue) { if (value==HIGH){ gw.send(msg.set(1)); } oldValue = value; }So the sensor will only send high when the button is pressed, and will never send anything else. I don't think that's what you want.
I think you want something like this:
boolean state; boolean oldvalue; void loop(){ value=digitalRead(PIN); if (value != oldvalue) { if (value == HIGH) { state = ! state; // switch state every time the button is down gw.send(msg.set(state)); } oldvalue = value; gw.wait(100); // debounce } }I wrote this code on my ipad so it has not been checked for correct syntax but you should be able to get the idea.
I do want it to only send when it's high. Just didn't know if there was a way from the framework to do that or if just modding the code in some fashion like I did was the right way to go.
Thank you. New to mysensors still so I didn't know if there was a "framework" method :)
thanks again!
