  3. push buttons / only 1 state
5 Posts 2 Posters 1.4k Views 2 Watching
  • CrankyCoderC Offline
    CrankyCoder
    Ok, so I am still very very new to this. I made what I am trying to do work, but I am curious if I just fudged it or if there is a "proper" way to go about it.
    I have a basic sensor setup. I am testing it right now by having 1 momentary push button. I got everything working all the way through to my openhab setup. However, when i push the button the state 1 is sent. Perfect. But as soon as I let go it sends 0. Now, I understand why it would. Makes total sense. But in this case, I only want something to happen when I press the button. Not when I release.
    Not sure if there is a better way to go about it, but I did this.
    if (value != oldValue) {
         // Send in the new value
         if (value==HIGH){
         oldValue = value;
    I just wrapped the send with an If statement to only run the gw.send when it's high.
    Is there a better way to do this?
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • CrankyCoderC CrankyCoder
           if (value==HIGH){
           oldValue = value;
      @Jason-Brunk the code you have now could be reduced to
           if (value==HIGH){
               gw.send(msg.set(1));
           oldValue = value;
      So the sensor will only send high when the button is pressed, and will never send anything else. I don't think that's what you want.
      I think you want something like this:
      boolean state;
      boolean oldvalue;
      void loop(){
          value=digitalRead(PIN);
          if (value != oldvalue) {
              if (value == HIGH) {
                  state = ! state; // switch state every time the button is down
                  gw.send(msg.set(state));
              oldvalue = value;
              gw.wait(100); // debounce
      I wrote this code on my ipad so it has not been checked for correct syntax but you should be able to get the idea.
        CrankyCoder
        I do want it to only send when it's high. Just didn't know if there was a way from the framework to do that or if just modding the code in some fashion like I did was the right way to go.
        www.CrankyCoder.net
        MySensors: 2.3
        • mfalkviddM Offline
          Ok, then your code is fine. I would remove the HIGH ? part and just send 1, to make the code clearer, but it will work anyway.
            CrankyCoder
            Thank you. New to mysensors still so I didn't know if there was a "framework" method :)
            thanks again!
            www.CrankyCoder.net
            MySensors: 2.3
            11.9k
            113.3k
