  3. implementing multiple sensors
83 Posts 28 Posters 99.2k Views 15 Watching
  • W
    W
    waynehead99
    Nobody wants to take a crack at this? I figured this to be a common combo and would really like to get it to work properly.
    • B
      B
      Bandra
      I'm coming close to finalising my multisensor sketch. I'll post code once I clean it up a little. I have a newborn at home, so if I forget to put code here then somebody please remind me in a little while :)
      • W waynehead99
        mikeones
        @waynehead99 Here is a sketch I run with DHT and motion support.
        #include <Sleep_n0m1.h>
        #include <EEPROM.h>
        #include <RF24.h>
        #include <Sensor.h>
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        Sensor gw;
        DHT dht;
        Sleep sleep;
        float lastTemp;
        float lastHum;
        boolean lastValue = false;
        boolean metric = false;
        #define CHILD_ID 2   // Id of the sensor child
        long previousMillis_T = 0;     // will store last time temp data sent
        unsigned long startTime_T;
        unsigned long sensorInterval = 30000; // change this to desired sensor read interval in milliseconds
          gw.begin();
          gw.sendSketchInfo("Motion Sensor and DHT", "1.0");
          gw.sendSensorPresentation(CHILD_ID, S_MOTION);
          gw.sendSensorPresentation(CHILD_ID_HUM, S_HUM);
          gw.sendSensorPresentation(CHILD_ID_TEMP, S_TEMP);
          metric = gw.isMetricSystem();
          startTime_T = millis();
          Serial.println("Setup complete");
          // Read digital motion value
          if (lastValue != tripped) {
        	gw.sendVariable(CHILD_ID, V_TRIPPED, tripped?"1":"0");  // Send tripped value to gw
        	lastValue=tripped;
        	//Serial.println(tripped);
          if (millis() - startTime_T >= sensorInterval) {
        	if (isnan(temperature)) {
        	} else if (temperature) {
        	  lastTemp = temperature;
        	  if (!metric) {
        	  gw.sendVariable(CHILD_ID_TEMP, V_TEMP, temperature, 1);
        		Serial.print("T: ");
        	//delay(dht.getMinimumSamplingPeriod());
        	if (isnan(humidity)) {
        	} else if (humidity) {
        		lastHum = humidity;
        		gw.sendVariable(CHILD_ID_HUM, V_HUM, humidity, 1);
        		Serial.print("H: ");
        		Serial.println(humidity);
          // Power down the radio.  Note that the radio will get powered back up
          // on the next write() call.
          delay(1000); //delay to allow serial to fully print before sleep
        • W
          W
          waynehead99
          Thanks that worked... and for my understanding... looks like your not really using interrupts at all? Looking at the code makes complete sense to me, and proves I was over thinking things on mine.
          Thanks again.
            mikeones
            The sensor is not running on battery power so I did not spend much time with the interrupt/sleep options.
            • T
              Tibus
              is it the same process with the new 1.4 library version?
              Could you please give us a exemple here or on github to have multiple sensor type on the same arduino with the new 1.4 library?
              if it's the same implementation, we could write multiple "gw.present(ID, XXXX);" and send a message for each child ID type?
              Thank's very much.
              • T
                Tibus
                Sorry, I found the new implementation in the "DallasTemperatureSensor" Example
                • mountainmanM
                  mountainmanM
                  mountainman
                  wrote on last edited by mountainman
                  #47
                  Here is a version I'm currently using that makes use of interrupts so might be more suitable for a battery driven DHT/Motion multi sensor. It also includes the battery monitoring. Any feedback or improvements would be appreciated.
                  #define CHILD_ID_MOTION 2   // Id of the sensor child
                  unsigned long SLEEP_TIME = F; // Sleep time between reports (in milliseconds)
                  int oldValue=-1;
                  DHT dht;
                  float lastTemp;
                  float lastHum;
                  int oldBatteryPcnt = 0;
                  int battLoop =0;
                  // Initialize motion message
                  MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
                  boolean pinTriggered=0;//waitTime is number of seconds to hol in while loop
                  long lastDebounceTime = 0;  // the last time the output pin was toggled
                  long debounceDelay = 50;    // the debounce time; increase if the output flickers
                    analogReference(INTERNAL);
                    gw.begin();
                    gw.sendSketchInfo("Motion Humidity w/ Batt", "1.0");
                    gw.present(CHILD_ID_MOTION, S_MOTION);
                    pinMode(DIGITAL_INPUT_SENSOR,INPUT);      // sets the motion sensor digital pin as input
                    digitalWrite(DIGITAL_INPUT_SENSOR,HIGH);   // Activate internal pull-up
                    check_batt();
                    if (pinTriggered)
                  	Serial.println(millis()-lastDebounceTime);
                  	boolean value = digitalRead(DIGITAL_INPUT_SENSOR);
                  	// If the switch changed, due to noise or pressing
                  	if (value != oldValue) {
                  		lastDebounceTime = millis();
                  		// Send in the new value
                  		battLoop++;
                  		oldValue = value;
                  		Serial.print("Mot: ");
                  		Serial.println(value);
                  	pinTriggered=0;
                  	else if (temperature != lastTemp)
                  	  if (!metric)
                  	  battLoop++;
                  	else if (humidity != lastHum)
                  	  lastHum = humidity;
                  	  battLoop++;
                  	if (battLoop > 10)
                  	  check_batt();
                  	  battLoop=0;
                    pinTriggered = gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                  void check_batt()
                    // get the battery Voltage
                    Serial.println(sensorValue);
                    Serial.print(batteryV);
                    Serial.println(" V");
                    Serial.print(batteryPcnt);
                    Serial.println(" %");
                  	// Power up radio after sleep
                  	oldBatteryPcnt = batteryPcnt;
                  T C 2 Replies Last reply
                  • W
                    W
                    waynehead99
                    How did you get 3 options for the sleep interrupt? Whenever I would try and add the sleep_time option it would give me compile errors.
                    • mountainmanM mountainman
                      int oldValue=-1;
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                      int battLoop =0;
                        gw.begin();
                        check_batt();
                        if (pinTriggered)
                      		battLoop++;
                      		oldValue = value;
                      	pinTriggered=0;
                      	  if (!metric)
                      	  battLoop++;
                      	  lastHum = humidity;
                      	  battLoop++;
                      	if (battLoop > 10)
                      	  check_batt();
                      	  battLoop=0;
                      void check_batt()
                      Tibus
                      wrote on last edited by Tibus
                      #49
                      @mountainman
                      Thank you verry much, exactly what i need!
                      For child's id, if you have two sensor you have to change the ID in the second?
                      Sensor 1 :
                      Sensor 2:
                      #define CHILD_ID_HUM 3
                      #define CHILD_ID_TEMP 4
                      #define CHILD_ID_MOTION 5
                      • mountainmanM
                        mountainmanM
                        mountainman
                        @waynehead99 Are you using the new 1.4 Lib?
                        • E egbertje
                          Somebody has good result in a working multisensor and wants to share his code?
                          NuubiN
                          NuubiN
                          Nuubi
                          wrote on last edited by Nuubi
                          #51
                          @egbertje Good Question :-) It would be nice to learn from existing working sketches..
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            @waynehead99 you most likely need 1.4 Lib for the new sleep constructor. I have not used sleep on 1.3 so I do not remember what arguments you had available there.
                            I have also extended sleep with an additional constructor which @hek has pulled into the release branch of 1.4 that permits you to use two external interrupts with independent triggers for sleep in addition to a timeout. Great for nodes with multiple sensors that still run on battery.
                            • E
                              E
                              egbertje
                              wrote on last edited by egbertje
                              #53
                              @Mountainman ;
                              Im trying your code and its almost what im looking for.
                              I have two questions about it:
                              1 : Is it possible that the battery info has is own child id?
                              2 : Why dont you implement a light sensor like an LDR?
                              I think that including LDR/light then you have the ideal multisensor ; light + temp/hum + motion + batt monitoring !
                              But for now im playing with your code and try to implement light.
                                int oldValue=-1;
                                DHT dht;
                                float lastTemp;
                                float lastHum;
                                int battLoop =0;
                                  gw.begin();
                                  check_batt();
                                  if (pinTriggered)
                                		battLoop++;
                                		oldValue = value;
                                	pinTriggered=0;
                                	  if (!metric)
                                	  battLoop++;
                                	  lastHum = humidity;
                                	  battLoop++;
                                	if (battLoop > 10)
                                	  check_batt();
                                	  battLoop=0;
                                void check_batt()
                                C
                                C
                                codenea
                                @mountainman Is there any instructions on how to wire/setup the hardware to work with your code?
                                • mountainmanM
                                  mountainmanM
                                  mountainman
                                  @egbertje;
                                  The battery percentage is associated with the parent Arduino Node in the vera UI.
                                  I have some LDRs ordered from Ebay so that is the next step. I had previously used the BH1750 I2C sensor in a multi sensor with the 1.3 lib but I want to debug on its own as it seemed to be giving unexpected readings.
                                  @codenea The instructions are pretty much from the main page although if I get a chance I try to draw it up and post some pics. My setup not very pretty yet with perf board and jumper wires. A dedicated PCB would be nice.
                                  • epierreE
                                    epierreE
                                    epierre
                                    Here is my combo to make a Home Monitoring solution:
                                    https://github.com/empierre/arduino/blob/master/MQv01dgi_1_4.ino
                                    It includes (currently on a Mega):
                                    • Barometer : BMP085
                                    • Temperature + Humidity DHT11
                                    • Particle sensor
                                    • Gas sensors MQ2 MQ6 MQ131 MQ135 TGS2600 2SH12
                                    To be added when stabilized:
                                    • Sound level in DB
                                    Could be added:
                                    • Light sensor
                                    • Vibration sensor
                                    • PIR
                                    z-wave - Vera -> Domoticz
                                    • pgoP
                                      pgoP
                                      pgo
                                      wrote on last edited by pgo
                                      #57
                                      Hi guys,
                                      this is a one node with publishing DS temperatures and listening for relay commands I finished and tested yesterday>
                                      https://github.com/pgo-sk/mysensors/blob/master/arduino/DS_and_Relay.ino
                                      feel free to comment/use/publish...
                                      I combined the Dalas and Relay examples together - you have to deactivate the sleep for the relays to listen 100% of time.
                                      MQTT identification on openHAB:
                                      MyMQTT/20/0/V_TEMP - DS sensor(s)
                                      MyMQTT/20/1/V_LIGHT - relay 1
                                      MyMQTT/20/2/V_LIGHT - relay 2
                                      If somebody is interested I can post the maps/items files for openHAB
                                      Regards,
                                      Pego
                                      PS I am working on an home automation system with solar hot air panels control/solar hot water panels and all the common stuff like lights/temperatures/weather etc.. More here: https://github.com/pgo-sk/mysensors/wiki/Home-automation-using-mysensors-and-openHAB
                                      • I
                                        I
                                        integlikewhoa
                                        I'm also following along interested in the Temp, Humidity, and motion sensor.
                                        • I integlikewhoa
                                          Tibus
                                          @integlikewhoa check this :
                                          http://forum.mysensors.org/topic/404/3-in-1-humidity-temp-and-motion
