  3. {DEV} Multi-Sensor Node goes into boot loop
21 Posts 8 Posters 6.6k Views 8 Watching
  • D Offline
    drock1985
    I'm trying to make a multi-sensor node for my porch. I want the sensor to have a Temp/Motion/LUX sensors and have used the Dallas temp sensor and BH1750 Lux sensor for this project. I have tested the individual components on their own, and each of them works (not with the MySensors library but on their own).
    I am using the 2.0 DEV branch and trying to combine the example sketches for the above sensors into one. I can compile fine, but when I try to boot, I go into a boot loop with the Arduino. This is the output from the Serial window after enabling Debug:
    Starting sensor (RNNNA-, 2.0.0-beta)
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=21)
    TSM:FPAR
    TSP:MSG:SEND 21-21-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 4-4-21 s=255,c=3,t=8,pt=1,l=1,sg=0:2
    TSP:MSG:FPAR RES (ID=4, dist=2)
    TSP:MSG:PAR OK (ID=4, dist=3)
    TSP:MSG:READ 0-0-21 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSP:MSG:READ 2-2-21 s=255,c=3,t=8,pt=1,l=1,sg=0:2
    TSP:MSG:FPAR RES (ID=2, dist=2)
    TSP:MSG:READ 14-14-21 s=255,c=3,t=8,pt=1,l=1,sg=0:1
    TSP:MSG:FPAR RES (ID=14, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=21)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 21-21-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSP:MSG:PAR OK (ID=14, dist=2)
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSP:MSG:PAR OK (ID=2, dist=3)
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    And this is the sketch:
     * Version 1.0 - Henrik Ekblad
    // Enable debug prints
    #define MY_NODE_ID 21
    #include <OneWire.h>
    #include <BH1750.h>
    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
    int numSensors=0;
    boolean receivedConfig = false;
    boolean metric = true;
    #define CHILD_ID_MOTION 1   // Id of the sensor child
    #define CHILD_ID_TEMP 2   // ID of Temperature Sensor
    #define CHILD_ID_LUX 3  // ID of Lux Sensor
    BH1750 lightSensor;
    // Initialize motion message
    MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
    MyMessage msgLux(CHILD_ID_LUX, V_LIGHT_LEVEL);
    uint16_t lastlux;
      lightSensor.begin();
      sensors.begin();
    void presentation()  {
      sendSketchInfo("yes", "1.0");
      present(CHILD_ID_MOTION, S_MOTION);
      present(CHILD_ID_LUX, S_LIGHT_LEVEL);
      // Read digital motion value
      Serial.println(tripped);
      send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
      Serial.println(lux);
      if (lux != lastlux) {
          send(msgLux.set(lux));
          lastlux = lux;
      wait(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
          send(msgTemp.setSensor(i).set(temperature,1));
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • R Offline
      R Offline
      rollercontainer
      wrote on last edited by rollercontainer
      Same thing here. I am using MQTT gateway.
      #include <string.h>
      #define __FILENAME__ (strrchr(__FILE__, '\\') ? strrchr(__FILE__, '\\') + 1 : __FILE__)
      #define SKETCH_NAME __FILENAME__
      #define SKETCH_DATE __DATE__
      #define MY_NODE_ID 100
      #include <SI7021.h>
      TSM:INIT
      TSM:RADIO:OK
      TSP:ASSIGNID:OK (ID=100)
      TSM:FPAR
      TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
      TSM:FPAR
      TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=100)
      TSM:UPL
      TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
      !TSM:UPL:FAIL
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:UPL
      !TSM:UPL:FAIL```
      • R Offline
        R Offline
        rollercontainer
        Ok, 2.0 looks like to be stable now (-> Master branch) We both struggle at point "CHKUPL" which means "Check Uplink". So, maybe our Gateway has to be updated too. I will give it a try...
        https://github.com/mysensors/MySensors/blob/986389b12591917ecbc44021c63a2cdf6f8c8222/core/MyTransport.cpp#L250
        • R Offline
          R Offline
          rollercontainer
          Nope. Recompiled MQTT Gateway: Node error persists... CHKUPL:Fail
          • R Offline
            R Offline
            rollercontainer
            Hm, MQTTGateway only comes up on PC, not on USB power supply. And it is not presenting itself, but sendig local DHT values.
            • R Offline
              R Offline
              rollercontainer
              MY_DEBUG disabled, MQTT Gateway comes up on regular power. Bug?
              • R Offline
                R Offline
                rollercontainer
                Well, 2.0 seems buggy. Now my Node is trying to find its parent. Funny, because I told him which to use:
                #define MY_PARENT_NODE_ID 0
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=10)
                TSM:FPAR
                TSP:MSG:SEND 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                • R rollercontainer
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  T Offline
                  T Offline
                  tekka
                  @rollercontainer We need to look into that - that's not the anticipated behaviour. Please submit an issue on git and we will investigate further. Thanks for the feedback.
                  • D Offline
                    drock1985
                    hi @rollercontainer
                    Thanks for looking into this with me. I had some more luck believe it or not after upgrading to 2.0.0 on my Gateway. Using the same sketch as I posted for my node, and updating my ESP8266 Gateway to the 2.0 sketch solved the reboot issue. Only problem now is the DallasTemperature sensor does not seem to be registering with the gateway.
                    Of curious notice, when I looked through the example sketches in the new MySensors 2.0 Library, i did not see an example sketch for the DallasTemperature sensors this time around.
                    My Projects
                    2 Door Chime Sensor
                    Y A 2 Replies Last reply
                    • D drock1985
                      hi @rollercontainer
                      Y Offline
                      Y Offline
                      For maintenance reasons, examples depending on external libraries have been removed in 2.0.0, to be placed in a separate repository (work in progress).
                      • D Offline
                        drock1985
                        Getting there.... I had to re-add the OneWire, Wire and DallasTemperature sensor and make a few modifications to the sketch, but I have the beginnings now and it is showing up properly in Home-Assistant and responding nicely. I'm off to make supper, but the only thing I can see needing to modify big time is adding "send temp on change only" and getting the temp to show to a decimal place.
                        Here is the sketch for now:
                        #include <BH1750.h>
                        int numSensors=0;
                        BH1750 lightSensor;
                        uint16_t lastlux;
                          sensors.begin();
                              lastlux = lux;
                            int temperature = (((sensors.getTempCByIndex(0)) * 10.)) / 10.;
                              send(msgTemp.set(temperature));
                        My Projects
                        2 Door Chime Sensor
                        • D drock1985
                          hi @rollercontainer
                          A Offline
                          A Offline
                          AWI
                          @drock1985 I had similar problems with the failure messages. After an upgrade of my repeater it functions again. Development seems to have some issues with backward compatibility. Hard to reproduce the errors..
                          D 1 Reply Last reply
                          • A AWI
                            drock1985
                            @AWI
                            Ah, never thought about that. I do have a node/repeater still on 1.5 running. Thanks; now I know my next project.
                            My Projects
                            2 Door Chime Sensor
                            • E Offline
                              E Offline
                              emc2
                              wrote on last edited by emc2
                              !TSM:UPL:FAIL
                              Did you end up finding what was the problem?
                              I have the same errors on new nodes compiled with the stable release. It was working fine on the dev branch before, and my old sensors still works, but not the new ones...
                              Edit:
                              I had to revert to https://github.com/mysensors/MySensors/tree/244f79771acb60588c6b4fd6dd0fa4b5daf4cb64
                              June 26th commit break everything for me. Unfortunately a lot of changes were made this day...
                              mitchellM 1 Reply Last reply
                              • R Offline
                                R Offline
                                rollercontainer
                                read above again:
                                Gateway 2.0.0beta with Node 2.0.0 = UPL:FAIL (which means UPLink)
                                Gateway 2.0.0 with Node 2.0.0 = FPAR:FAIL (which means FindPARent)
                                my error is reported to github, maybe you should do this too with yours?
                                https://github.com/mysensors/MySensors/issues
                                • E Offline
                                  E Offline
                                  emc2
                                  Oh, so just switching from beta to 2.0 master "fixed" UPL:FAIL by switching it to a FPAR:FAIL?
                                  I thought you did some fixes and then ended up with another error, my bad. Github it is I guess...
                                  • R Offline
                                    R Offline
                                    rollercontainer
                                    I am not a coder, just a user. So I am not able to fix errors here.
                                    • E emc2
                                      !TSM:UPL:FAIL
                                      Edit:
                                      mitchellM Offline
                                      mitchellM Offline
                                      mitchell
                                      wrote on last edited by mitchell
                                      !TSM:UPL:FAIL
                                      Edit:
                                      Thank you, had the same problem, replaced it with the files from the 26th and got it working.
                                      • E Offline
                                        E Offline
                                        emc2
                                        @mitchell Glad it was useful.
                                        Do you also have a Raspberry Pi Gateway with the radio module directly on the GPIO? It seems the problem come from here, issue can now be tracked on https://github.com/mysensors/Raspberry/issues/31
                                        Also if needed you can replace core/MyHwESP8266.h and core/MyMainESP8266.cpp with the release version so you can use an ESP8266 device too.
                                        • E emc2
                                          mitchellM Offline
                                          mitchellM Offline
                                          mitchell
                                          @emc2 Indeed on a Raspberry with direct connection. Thank you for the link, I will follow the progress.
                                          12.0k
