  3. [SOLVED] Gateway without radio not working on current development branch
21 Posts 8 Posters 7.1k Views 6 Watching
  • skatunS
    skatunS
    skatun
    Fyi, I had same problem with serial gateway. I guess that is fixed now aswell as the ethernet gateway?
    jsiddallJ 1 Reply Last reply
    • skatunS skatun
      jsiddallJ
      jsiddallJ
      jsiddall
      Yes, I have tested both serial and ethernet gateways and both work now.
      • skatunS
        skatunS
        skatun
        Is there a smarter way to upgrade the development version on windows instead of download zip file-> extract it-> replace files? Also how can I find out if its outdated or not? I am going to download the new version now to see if the patch works and hence I were wondering the best way to do so:)
        RFM69R mfalkviddM 2 Replies Last reply
        • skatunS skatun
          RFM69R
          RFM69R
          RFM69
          @skatun Can you use git, not an expert... but I think thats the way to go... :)
          • skatunS skatun
            Yes. Delete the old version first. Then extract (no need to replace since the old files have been deleted)
            Otherwise you'll most likely get compile errors.
            skatunS 1 Reply Last reply
              skatunS
              skatunS
              skatun
              @mfalkvidd
              On windows 7 it ask me to replace files with new one, when I click yes, everything works fine. The main issue is to detect when new files are available and then do the update. These days I keep downloading the development branch around once a month to make sure I am not working on to old versions.
              • skatunS skatun
                @mfalkvidd
                @skatun yes, that method will work if you are lucky. But if a file has been renamed or something similar you will get warnings and/or errors. Better to delete the old library first.
                • chrlyraC
                  chrlyraC
                  chrlyra
                  I have the same situation here, I mean, serial gateway with local sensors and no radio. But I'd like to use the 1.5 version as I'm not sure with the new one is compatible with homeassistant. Is this fix only to 2.0 branch?
                  skatunS martinhjelmareM jsiddallJ 3 Replies Last reply
                  • chrlyraC chrlyra
                    skatunS
                    skatunS
                    skatun
                    @chrlyra
                    If I am not completely wrong, this fix is only to 2.0
                    • chrlyraC chrlyra
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @chrlyra
                      Version 2.0 of the mysensors library should be compatible with home assistant, but the new sensor s_types and v_types are not yet supported. I'm working on this.
                      • chrlyraC chrlyra
                        jsiddallJ
                        jsiddallJ
                        jsiddall
                        @chrlyra: I don't think local sensors are in the main branch so you need development for that
                        • jsiddallJ jsiddall
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @jsiddall
                          Version 2.0, which was just released, supports local sensors on gateway, ie you should not need dev branch anymore for that feature.
                            @jsiddall
                            jsiddallJ
                            jsiddallJ
                            jsiddall
                            @martinhjelmare: right you are. I didn't realize 2.0 was out. I guess my post would have made more sense 4 days ago!
                            • chrlyraC
                              chrlyraC
                              chrlyra
                              great news. I will try the version 2.0 this week.
