  3. [SOLVED] Gateway without radio not working on current development branch
21 Posts 8 Posters 7.1k Views 6 Watching
  • jsiddallJ
    jsiddallJ
    jsiddall
    Great, thanks!
    tekkaT 1 Reply Last reply
    • jsiddallJ jsiddall
      Great, thanks!
      tekkaT
      tekkaT
      tekka
      @jsiddall has been addressed in PR#502.
      jsiddallJ 1 Reply Last reply
      • tekkaT tekka
        jsiddallJ
        jsiddallJ
        jsiddall
        @tekka: TYVM. Tested the fix and it works great, no errors.
        • skatunS
          skatunS
          skatun
          Fyi, I had same problem with serial gateway. I guess that is fixed now aswell as the ethernet gateway?
          • skatunS skatun
            jsiddallJ
            jsiddallJ
            jsiddall
            Yes, I have tested both serial and ethernet gateways and both work now.
            • skatunS
              skatunS
              skatun
              Is there a smarter way to upgrade the development version on windows instead of download zip file-> extract it-> replace files? Also how can I find out if its outdated or not? I am going to download the new version now to see if the patch works and hence I were wondering the best way to do so:)
              RFM69R mfalkviddM 2 Replies Last reply
              • skatunS skatun
                RFM69R
                RFM69R
                RFM69
                @skatun Can you use git, not an expert... but I think thats the way to go... :)
                • skatunS skatun
                  Yes. Delete the old version first. Then extract (no need to replace since the old files have been deleted)
                  Otherwise you'll most likely get compile errors.
                  skatunS 1 Reply Last reply
                    skatunS
                    skatunS
                    skatun
                    @mfalkvidd
                    On windows 7 it ask me to replace files with new one, when I click yes, everything works fine. The main issue is to detect when new files are available and then do the update. These days I keep downloading the development branch around once a month to make sure I am not working on to old versions.
                    • skatunS skatun
                      @mfalkvidd
                      @skatun yes, that method will work if you are lucky. But if a file has been renamed or something similar you will get warnings and/or errors. Better to delete the old library first.
                      • chrlyraC
                        chrlyraC
                        chrlyra
                        I have the same situation here, I mean, serial gateway with local sensors and no radio. But I'd like to use the 1.5 version as I'm not sure with the new one is compatible with homeassistant. Is this fix only to 2.0 branch?
                        skatunS martinhjelmareM jsiddallJ 3 Replies Last reply
                        • chrlyraC chrlyra
                          skatunS
                          skatunS
                          skatun
                          @chrlyra
                          If I am not completely wrong, this fix is only to 2.0
                          • chrlyraC chrlyra
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @chrlyra
                            Version 2.0 of the mysensors library should be compatible with home assistant, but the new sensor s_types and v_types are not yet supported. I'm working on this.
                            • chrlyraC chrlyra
                              jsiddallJ
                              jsiddallJ
                              jsiddall
                              @chrlyra: I don't think local sensors are in the main branch so you need development for that
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                @jsiddall
                                Version 2.0, which was just released, supports local sensors on gateway, ie you should not need dev branch anymore for that feature.
                                  @jsiddall
                                  jsiddallJ
                                  jsiddallJ
                                  jsiddall
                                  @martinhjelmare: right you are. I didn't realize 2.0 was out. I guess my post would have made more sense 4 days ago!
                                  • chrlyraC
                                    chrlyraC
                                    chrlyra
                                    great news. I will try the version 2.0 this week.
