  3. [SOLVED] Gateway without radio not working on current development branch
21 Posts 8 Posters 7.1k Views 6 Watching
  • jsiddallJ jsiddall
    Great, thanks!
    tekkaT
    tekkaT
    tekka
    @jsiddall has been addressed in PR#502.
    jsiddallJ 1 Reply Last reply
    • tekkaT tekka
      jsiddallJ
      jsiddallJ
      jsiddall
      @tekka: TYVM. Tested the fix and it works great, no errors.
      • skatunS
        skatunS
        skatun
        Fyi, I had same problem with serial gateway. I guess that is fixed now aswell as the ethernet gateway?
        • skatunS skatun
          jsiddallJ
          jsiddallJ
          jsiddall
          Yes, I have tested both serial and ethernet gateways and both work now.
          • skatunS
            skatunS
            skatun
            Is there a smarter way to upgrade the development version on windows instead of download zip file-> extract it-> replace files? Also how can I find out if its outdated or not? I am going to download the new version now to see if the patch works and hence I were wondering the best way to do so:)
            RFM69R mfalkviddM 2 Replies Last reply
            • skatunS skatun
              RFM69R
              RFM69R
              RFM69
              @skatun Can you use git, not an expert... but I think thats the way to go... :)
              • skatunS skatun
                Yes. Delete the old version first. Then extract (no need to replace since the old files have been deleted)
                Otherwise you'll most likely get compile errors.
                skatunS 1 Reply Last reply
                  skatunS
                  skatunS
                  skatun
                  @mfalkvidd
                  On windows 7 it ask me to replace files with new one, when I click yes, everything works fine. The main issue is to detect when new files are available and then do the update. These days I keep downloading the development branch around once a month to make sure I am not working on to old versions.
                  • skatunS skatun
                    @mfalkvidd
                    @skatun yes, that method will work if you are lucky. But if a file has been renamed or something similar you will get warnings and/or errors. Better to delete the old library first.
                    • chrlyraC
                      chrlyraC
                      chrlyra
                      I have the same situation here, I mean, serial gateway with local sensors and no radio. But I'd like to use the 1.5 version as I'm not sure with the new one is compatible with homeassistant. Is this fix only to 2.0 branch?
                      skatunS martinhjelmareM jsiddallJ 3 Replies Last reply
                      • chrlyraC chrlyra
                        skatunS
                        skatunS
                        skatun
                        @chrlyra
                        If I am not completely wrong, this fix is only to 2.0
                        • chrlyraC chrlyra
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @chrlyra
                          Version 2.0 of the mysensors library should be compatible with home assistant, but the new sensor s_types and v_types are not yet supported. I'm working on this.
                          • chrlyraC chrlyra
                            jsiddallJ
                            jsiddallJ
                            jsiddall
                            @chrlyra: I don't think local sensors are in the main branch so you need development for that
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @jsiddall
                              Version 2.0, which was just released, supports local sensors on gateway, ie you should not need dev branch anymore for that feature.
                                @jsiddall
                                jsiddallJ
                                jsiddallJ
                                jsiddall
                                @martinhjelmare: right you are. I didn't realize 2.0 was out. I guess my post would have made more sense 4 days ago!
                                • chrlyraC
                                  chrlyraC
                                  chrlyra
                                  great news. I will try the version 2.0 this week.
