  3. Getting the Ethernet/ESP8266 gateway to act as client instead of server
14 Posts 5 Posters 7.9k Views 8 Watching
  • rakeshpaiR
    rakeshpaiR
    rakeshpai
    Thanks, @mfalkvidd. That seems to only work for the MQTT gateway, though. I was wondering if there's something similar for the socket API, using just the Ethernet/ESP8266 gateways (without MQTT).
      Enabling client mode is documented in the sketch here:
      https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayESP8266/GatewayESP8266.ino#L104
      stofakillerS 1 Reply Last reply
      • rakeshpaiR
        rakeshpaiR
        rakeshpai
        Client mode is what I was looking for, thanks, @hek.
        Is it possible to define the controller IP address dynamically at runtime, rather than having it compiled into the sketch? That way, it could be possible to have some sort of API/UI to configure the gateway after deployment, without having to reflash the Arduino.
        (I'm working off the development branch, if that's any help.)
          wrote on last edited by hek
          No, but you can set an url instead (and control it via your/some dns): https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyGatewayTransportEthernet.cpp#L160
          • rakeshpaiR
            rakeshpaiR
            rakeshpai
            Cool. Doesn't quite do the job, but I'll figure my way around it. Thanks again, @hek.
            • A
              Adam McCartney
              This isn't what you're looking for, but whats stopping you hosting the controller in your own home and using a VPN or internet facing controller behind security or using a VPN on your phone?
              i currently run Domoticz and have a Domain pointed at a Raspberry pi in my house. access outside the internal network requires a username and password, but recently i setup OpenVPN so that when connect to the VPN on my phone, i can use the Domoticz app or access the Domoticz web interface without having to setup Authentication.
              rakeshpaiR 1 Reply Last reply
              • A Adam McCartney
                rakeshpaiR
                rakeshpaiR
                rakeshpai
                @Adam-McCartney That certainly works. I'm looking to avoid the overhead of the configuration and setup required at home, and want to keep it simple for everyone to use ("just go to <url>"). There's also the interesting possibility of the hosted controller being used by more than one household, but that's something for the future.
                • A
                  Adam McCartney
                  Personally, i dont like the idea of my controller being on someone elses Box. I have all i need on the RPi. Plus, if my internet connection goes down, i can still turn my lights off!
                  Domoticz allows you to join up controllers so you can still have access to other controllers in other houses. Its worth having a look.
                    stofakillerS
                    stofakillerS
                    stofakiller
                    wrote on last edited by stofakiller
                    @hek
                    Hi, In the 3 post is there a link https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayESP8266/GatewayESP8266.ino#L104... The link is dead and i tried to find it, but with no luck... Can you post the new URL?
                    Regards,
                    Jan
                    • stofakillerS stofakiller
                      @hek
                      Regards,
                      Jan
                      @stofakiller Examples->MySensors->GatewayESP8266MQTTClient in the Arduino IDE or https://github.com/mysensors/MySensors/tree/development/examples/GatewayESP8266MQTTClient is what you are looking for I think (at least for MySensors 2)
                      Or GatewayESP8266 / https://github.com/mysensors/MySensors/tree/development/examples/GatewayESP8266 for the one without mqtt
                        stofakillerS
                        stofakillerS
                        stofakiller
                        @mfalkvidd
                        I have look at both of them... But my interest lies in the esp8266 as a client/node without NRF24L01, to eg switch a relay on/off... And it has to go through my Vera controller... I have been playing with Apples Homekit, Raspberry Pi and Vera, and now i can control my vera switches and dimmers with just my voice
                        Regards,
                        Jan
                          @mfalkvidd
                          Regards,
                          Jan
                          @stofakiller I think that is supported but I don't know how to do it. Hopefully someone else can chip in.
