  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • ximinezX ximinez
    Is there a "pre setup" available yet? The failed transmits are before sensor values are transmitted, so they aren't in the actual sketch but somewhere in the library. I'd like to try just sleeping the sensor 5-10 seconds before the initial data is transmitted and see if that makes a difference.
    alexsh1A
    alexsh1A
    alexsh1
    #494
    @ximinez I do not think so. Either to patch the library or you do it in the sketch. Unless I do not know some other secret place.
    • ximinezX ximinez
      @ximinez
      You can add a before()-method.
      ximinezX 1 Reply Last reply
        @ximinez
        ximinezX
        ximinezX
        ximinez
        @hek said:
        @ximinez
        It's that easy? I'll give it a try when I get around to it, unless @alexsh1 feels like trying it first :)
        • HaakonH
          HaakonH
          Haakon
          Hi! I have just gotten four Sensebenders and was hoping to connect PIRs to them and powering them with AA batteries. I understand from the forums that people do this. But is there a working Arduino sketch example implementing a PIR for wake-up out there? (And perhaps there is a more detailed description for such a hardware setup for us newbies?)
          alexsh1A 1 Reply Last reply
          • T
            tomkxy
            I have bought another couple of sensebenders.
            I am not able to upload sketches to one of them.
            When I connect the programmer the status led goes to solid red. From another one, I realized that it is not solid red.
            What is the meaning of a solid red status LED?
              What does the log say when you upload?
              • HaakonH Haakon
                alexsh1A
                alexsh1A
                alexsh1
                @Haakon Have a look here - https://forum.mysensors.org/topic/2478/slim-cr123a-2aa-battery-node
                Just change your board for sensebender.
                • T
                  tomkxy
                  @hek
                  D -Uflash:w:/var/folders/3s/rjbksrj96nv0hqfqjlpfw8bm0000gn/T/build8699526819198040594.tmp/SecurityPersonalizer.cpp.hex:i
                           User configuration file is "/Users/tom/.avrduderc"
                           Using Port                    : /dev/cu.usbserial-DA01IGTO
                           Overriding Baud Rate          : 57600
                  avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
                  avrdude: ser_recv(): read error: Device not configured
                  Probleme beim Hochladen auf die Platine. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload
                  I have Sensebender selected as board.
                  Btw, where is the hardware folder? It is not present anymore in the development branch?
                    You can use the build in board manager nowadays.
                    https://github.com/mysensors/ArduinoBoards
                    Check board for solder bridges or anything suspicious.
                    • J
                      J
                      johnr
                      I wonder if anyone modified the original sensebender sketch to include a door sensor?
                      Do you need a pullup? If you have a sketch somewhere I would be happy if you could send/post it, as I have problem finding time to code right now.
                      martinhjelmareM alexsh1A 2 Replies Last reply
                      • J johnr
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @johnr
                        Here's one for a button, but shouldn't matter:
                        https://forum.mysensors.org/topic/2887/sensebender-micro-button/2
                        • J johnr
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @johnr This is easy.
                          // PIN = 2 or 3 only
                          void setup {
                            pinMode(PIN,INPUT);
                            digitalWrite(PIN,HIGH);
                          This activates internal pull-up.
                          The sensebender has got pinout of Pro Mini
                          • T
                            timropp
                            Well that didn't go well... assembling my first micro. Soldered on some pins for the FTDI connection, added power (2xAA holder), and soldered on the radio with cap. Then I put in batteries and brought up my domoticz page to see if it showed up. Started to smell something, looked down, and there's smoke coming from the battery holder. Grabbed the whole thing and yanked the wire free then dropped it in the sink. Not sure where I screwed up, but I sure shorted something!
                            VeraEdge UI7 with Mysensors ethernet gateway
                              :scream: Did you find the problem?
                              • T timropp
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @timropp sounds like you shorted batteries somewhere
                                • T
                                  timropp
                                  Nope, didn't find the problem. Must be some solder that shorted the batteries out but I don't see it. Oh well... main problem is that was my only 2AA holder on hand, and it melted right through the end of it, so now I have to wait on more before I can try again. Bummer :)
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    You can feed it with just two wires connected to the USB FTDI TTL converter / programmer - have a look at this https://www.mysensors.org/hardware/micro
                                    Available Pins - GND, GND, VCC (on the right)
                                      mvader
                                      I am having an odd issue with one of my sensebender boards.
                                      I have flashed 5 in a row, same sketch, same everything.
                                      all look fine (and in english) in the serial monitor. but this one board displays different.
                                      it does seem to work. but i can't figure out why it's showing up different in the monitor.
                                      any ideas?
                                      Óåîóåâåîäåò Íéãòï Æ× 1.5óåîä: 2-2-0-0 ó=255,ã=0,ô=17,ðô=0,ì=3,óç=0,óô=ïë:1.5
                                      óåîä: 2-2-0-0 ó=255,ã=3,ô=6,ðô=1,ì=1,óç=0,óô=ïë:0
                                      óåîóïò óôáòôåä, éä=2, ðáòåîô=0, äéóôáîãå=1
                                       - Ïîìéîå!
                                      óåîä: 2-2-0-0 ó=255,ã=3,ô=11,ðô=0,ì=17,óç=0,óô=ïë:Óåîóåâåîäåò Íéãòï
                                      óåîä: 2-2-0-0 ó=255,ã=3,ô=12,ðô=0,ì=3,óç=0,óô=ïë:1.5
                                      óåîä: 2-2-0-0 ó=1,ã=0,ô=6,ðô=0,ì=0,óç=0,óô=ïë:
                                      óåîä: 2-2-0-0 ó=2,ã=0,ô=7,ðô=0,ì=0,óç=0,óô=ïë:
                                      óåîä: 2-2-0-0 ó=3,ã=0,ô=1,ðô=0,ì=0,óç=0,óô=ïë:
                                      óåîä: 2-2-0-0 ó=4,ã=0,ô=16,ðô=0,ì=0,óç=0,óô=ïë:
                                      éóÍåôòéã: 0
                                      ÔåíðÄéææ :174.85
                                      ÈõíÄéææ  :154.00
                                      Ô: 74.85
                                      È: 54
                                      óåîä: 2-2-0-0 ó=1,ã=1,ô=0,ðô=7,ì=5,óç=0,óô=ïë:74.8
                                      óåîä: 2-2-0-0 ó=2,ã=1,ô=1,ðô=2,ì=2,óç=0,óô=ïë:54
                                      óåîä: 2-2-0-0 ó=255,ã=3,ô=0,ðô=1,ì=1,óç=0,óô=ïë:97
                                      ÏÔÁ Æ× õðäáôå åîáâìåä
                                      óåîä: 2-2-0-0 ó=4,ã=1,ô=23,ðô=2,ì=2,óç=0,óô=ïë:99
                                      Ìéçèô: 99
                                      ÔåíðÄéææ :0.01
                                      ˆõíÄéææ  :0.00
                                      Ìéçèô: 99
                                      tbowmoT 1 Reply Last reply
                                      • M mvader
                                        any ideas?
                                         - Ïîìéîå!
                                        éóÍåôòéã: 0
                                        ÔåíðÄéææ :174.85
                                        ÈõíÄéææ  :154.00
                                        Ô: 74.85
                                        È: 54
                                        Ìéçèô: 99
                                        ÔåíðÄéææ :0.01
                                        ˆõíÄéææ  :0.00
                                        Ìéçèô: 99
                                        tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @mvader
                                        What baudrate are you using? It seems like it's to much off, for the ftdi to decode it correctly. Have you tried to lower it to, let's say 9600 baud? And does it still do this?
                                        • tbowmoT tbowmo
                                          @mvader
                                          mvader
                                          @tbowmo said:
                                          @mvader
                                          I have not tried 9600, but i've done 5 today all the same code.. no problems.
                                          i have 4 others deployed from when i first bought these (when they came out) same code for them as well..
                                          could be a bum board..idk. when i fired it up, i could see it in the controller software though. so it does seem to work. it just gives me that in the serial monitor.. strange for sure :) I'll let you know how 9600 works out.
                                          AnticimexA 1 Reply Last reply
