  3. 2 Pushbuttons with sleep, lots of st=fail
18 Posts 3 Posters 4.8k Views 2 Watching
  • CrankyCoderC CrankyCoder
    I have a small node with 2 push buttons. For some reason the node isn't transmitting via radio
    I see this in my node debug:
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=1)
    TSM:FPAR
    TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
    !TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=fail:2.0.0
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=2,st=fail:0
    !TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=3,st=fail:
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=10,sg=0,ft=4,st=fail:WallSwitch
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=5,st=fail:1.1
    !TSM:UPL FAIL, SNP
    TSM:FPAR
    TSP:MSG:READ 0-0-1 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
    Request registration...
    !TSP:SEND:TNR
    TSM:FPAR
    !TSP:SEND:TNR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
    TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
    Node registration=1
    Init complete, id=1, parent=0, distance=1, registration=1
    !TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=fail:0
    !TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=1,st=fail:0
    !TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=2,st=fail:0
    !TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=3,st=fail:0
    !TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=4,st=fail:0
    !TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=5,st=fail:0
    !TSM:UPL FAIL, SNP
    TSM:FPAR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    TSM:FPAR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    On my gateway i see this.
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.2.50
    startup
    IP: 192.168.2.50
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;TSP:MSG:READ 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=1)
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
    0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
    0;255;3;0;9;TSP:SANCHK:OK
    0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;TSP:MSG:PINGED (ID=1, hops=1)
    0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
    0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
    0;255;3;0;9;TSP:MSG:ACK msg
    0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
    0;255;3;0;9;Sending message on topic: mygateway1-out/1/255/3/0/12
    0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
    0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
    0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=fail:1
    I restarted the gateway ad let it boot before I turned on the node. It looks like the node had some trouble trying to commmunicate with the gateway to start. Then you can see towards the end, the attempted sends where from me pushing 1 of the 2 buttons. My node code is
    #define SKETCH_NAME "WallSwitch"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "1"
    #define MY_NODE_ID 1
    #define TEMPERATURE_PRECISION 9
    #define CHILD_LIGHT_ID 1
    #define ON_PIN 3
    #define OFF_PIN 2
    int OFF_VAL = 0;
    int ON_VAL = 0;
    MyMessage msg_light(CHILD_LIGHT_ID,V_LIGHT);
       analogReference(INTERNAL1V1);
       analogReference(INTERNAL);
      present(CHILD_LIGHT_ID, S_LIGHT);
      wait(300);
      sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER,true);
      wait(300);
    int whichbutton;
    whichbutton = sleep(digitalPinToInterrupt(2),LOW,digitalPinToInterrupt(3),LOW,3600000);//86400000);
    switch (whichbutton) {
      case digitalPinToInterrupt(2):
          {//off
          send(msg_light.set(0),true);
          wait(300);
      case digitalPinToInterrupt(3):
          {//on
          send(msg_light.set(1),true);
          wait(300);
    The node is also not sending the sketchname but the version it sends.
    tekkaT
    tekkaT
    tekka
    @Jason-Brunk Is this related to https://forum.mysensors.org/topic/4435/solved-upl-fail/4?
    • CrankyCoderC
      CrankyCoderC
      CrankyCoder
      i didn't think so at first. but it could be. Is there a way for me to merge? or should I delete the post with less info?
      Home Automation Tinkerer
      www.CrankyCoder.net
      Gateway: MQTTClientGateway
      MySensors: 2.3
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        I have changed the capacitor values. Removed all my serial.println just in case that was causing problems.
        here is my gateway log
        IP: 192.168.2.50
        IP: 192.168.2.50
        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
        0;255;3;0;9;Sending message on topic: mygateway1-out/1/255/3/0/6
        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
        0;255;3;0;9;Sending message on topic: mygateway1-out/1/1/0/0/3
        0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
        here is the node. Even just the basic sketch info stuff is failing to send.
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR:OK
        TSM:ID
        TSM:CHKID:OK (ID=1)
        TSM:UPL
        TSP:CHKUPL:OK
        TSM:UPL:OK
        TSM:READY
        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
        !TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
        !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=fail:WallSwitch
        !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.1
        TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=2,st=ok:
        Node registration=1
        www.CrankyCoder.net
        MySensors: 2.3
        TheoLT 1 Reply Last reply
          IP: 192.168.2.50
          IP: 192.168.2.50
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=1)
          TSM:UPL
          TSP:CHKUPL:OK
          TSM:UPL:OK
          TSM:READY
          Node registration=1
          TheoLT
          TheoLT
          TheoL
          @Jason-Brunk Did you try to replace the radio's? One of them might be broken.
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            Yes. I have an extra and have tried swapping out in various combinations. I have tried with and without capacitors.
            www.CrankyCoder.net
            MySensors: 2.3
              TheoLT
              TheoLT
              TheoL
              @Jason-Brunk I'm having a hard time trying to understand your test sketch.
              Especially this piece. If I'm not mistaken you go to sleep for an hour or until one of the interrupt pins goes low.
              I'm however not sure what the sleep method returns.
              int whichbutton;
              Could you try a basic sketch and see if that runs? That'll eliminate hardware problems.
              • CrankyCoderC
                CrankyCoderC
                CrankyCoder
                From what I read it's supposed to return which pin goes low. but yes, I can try a basic sketch. Let me find one.
                www.CrankyCoder.net
                MySensors: 2.3
                • CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  ok, loaded the motionsensor sketch.
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:CHKID:OK (ID=1)
                  TSM:UPL
                  TSP:CHKUPL:OK
                  TSM:UPL:OK
                  TSM:READY
                  !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=3,st=fail:Motion Sensor
                  !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=4,st=fail:1.0
                  !TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=1,pt=0,l=0,sg=0,ft=5,st=fail:
                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=6,st=ok:2
                  Node registration=1
                  !TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=fail:1
                  Still seeing fails transmitting. Any thoughts?
                  www.CrankyCoder.net
                  MySensors: 2.3
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:CHKID:OK (ID=1)
                    TSM:UPL
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    Node registration=1
                    TheoLT
                    TheoLT
                    TheoL
                    @Jason-Brunk No I'm sorry. It looks like a communication thing. Maybe @tekka can help with this
                    • CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      Just so I can try to understand. The st=fail on the sensor node indicates that it wasn't able to send via the radio right? Not that the other end couldn't receive it? Just wondering which end point I should be focusing on :)
                      www.CrankyCoder.net
                      MySensors: 2.3
                      tekkaT 1 Reply Last reply
                        tekkaT
                        tekkaT
                        tekka
                        @Jason-Brunk st=fail indicates, that the RF module did not receive an ACK from the destination node, i.e. the message was sent but not received.
                        • CrankyCoderC
                          CrankyCoderC
                          CrankyCoder
                          I saw in this post https://forum.mysensors.org/topic/4430/solved-does-not-work-after-latest-update/5 you mentioned that 2.0 may have some slightly higher power requirements. What size cap is recommended now?
                          www.CrankyCoder.net
                          MySensors: 2.3
                            tekkaT
                            tekkaT
                            tekka
                            wrote on last edited by tekka
                            @Jason-Brunk I'm using 100uF caps, but 22uF seemed ok in this case.
                            • CrankyCoderC
                              CrankyCoderC
                              CrankyCoder
                              oh wow. ok, that's way more than I have on mine now. Let me try that and see if that does the trick.
                              www.CrankyCoder.net
                              MySensors: 2.3
                                tekkaT
                                tekkaT
                                tekka
                                @Jason-Brunk what are you using?
                                • CrankyCoderC
                                  CrankyCoderC
                                  CrankyCoder
                                  i have tried 10, 22, 47
                                  www.CrankyCoder.net
                                  MySensors: 2.3
                                  • CrankyCoderC
                                    CrankyCoderC
                                    CrankyCoder
                                    Just finished switching them out with 100's. MUCH better. Still having a fail on startup. looks like it's when it's sending the framework version
                                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=ok:WallSwitch
                                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
                                    TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                                    Node registration=1
                                    TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
                                    TSP:MSG:READ 0-0-1 s=1,c=1,t=2,pt=2,l=2,sg=0:0
                                    TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:1
                                    TSP:MSG:READ 0-0-1 s=1,c=1,t=2,pt=2,l=2,sg=0:1
                                    Connected much faster and 3 presses of both buttons all succeeded.
                                    www.CrankyCoder.net
                                    MySensors: 2.3
                                    12.5k
