  2. Bug Reports
  3. API documentation not up to date
6 Posts 5 Posters 3.0k Views 5 Watching
  • ybycodeY
    ybycodeY
    ybycode
    It seems the v2.0.x documentation has not been updated since the signature of the sleep function has changed:
    In v1.5.x:
    bool sleep(int interrupt, int mode, unsigned long ms=0)
    Whereas in v2.0.x:
    uint8_t sleep(int interrupt, int mode, unsigned long ms=0);
    yann
    TheoLT 1 Reply Last reply
    • ybycodeY ybycode
      In v1.5.x:
      Whereas in v2.0.x:
      yann
      TheoLT
      TheoLT
      TheoL
      wrote on last edited by TheoL
      @ybycode this what I found in the 2.0 API doc on the main page
      Sleeping
      To save battery it is crucial to sleep you node as much as possible. The node can wake up from external interrupts or by a timer.
      The following sleep your radio and Arduino (in PowerDownMode). Wakes up on timer interrupt.
      void sleep(unsigned long ms);
      ms - Number of milliseconds to sleep.
      The following sleeps your radio and Arduino (in PowerDownMode). Wakes up on timer interrupt or from an external interrupt.
      See: http://arduino.cc/en/Reference/attachInterrupt for details on modes and which pin is assigned to what interrupt. On Nano/Pro Mini: 0=Pin2, 1=Pin3
      bool sleep(int interrupt, int mode, unsigned long ms=0);
      interrupt - Interrupt that should trigger the wakeup.
      mode - RISING, FALLING, CHANGE
      ms - Number of milliseconds to sleep (or 0 to sleep forever).
      The sleep method returns true if wake up was triggered by pin change and false means timer woke it up.
      int8_t sleep(uint8_t interrupt1, uint8_t mode1, uint8_t interrupt2, uint8_t mode2, unsigned long ms=0);
      interrupt1 - First interrupt that should trigger the wakeup.
      mode1 - Mode for first interrupt (RISING, FALLING, CHANGE)
      interrupt2 - Second interrupt that should trigger the wakeup.
      mode2 - Mode for second interrupt (RISING, FALLING, CHANGE)
      Returns the interrupt number if wake up was triggered by pin change and negative if timer woke it up.
      • ybycodeY
        ybycodeY
        ybycode
        I agree, that's what I read too. But the function call
        doesn't return a boolean anymore, but a uint8_t, but the interrupt number if it was triggered, or -1 if timeout, or -2 if not possible because of a firmware update.
        See https://github.com/mysensors/MySensors/blob/development/core/MySensorsCore.h#L252
        yann
        • mfalkviddM
          The doxygen documentation is correct (says int_8t) but the API documentation still says bool.
          Isn't the API documentation generated from Doxygen? @hek could you enlighten us why the documentation differs? What can we do to fix it? A pull request isn't feasible since the code already is correct.
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @mfalkvidd
            I think the mysensors site is manually updated.
            I suggest looking into converting the site source to github pages, which would enable the whole community helping keeping the site docs up to date.
              Yes, the site is manually updated (improvements is on its way). Must have missed the sleep updates when doing the overview.
              Doxygen is always the best place/most correct place to look. And we'll probably move over to pure doxygen once it covers a majority of the library.
              12.5k
