  3. [Solved]UPL:Fail
[Solved]UPL:Fail
47 Posts 7 Posters 18.7k Views 5 Watching
  • Pictor LallemandP Pictor Lallemand
    i add 22uF capacitor to node and GW
    debug gw
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:MSG:READ 100-100-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=100)
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
    0;255;3;0;9;TSP:SANCHK:OK
    debug node
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=100)
    TSM:FPAR
    TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=100)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    I'm really frustrated that it does not work correctly yet I applied literally your sugestions
    tekkaT
    tekkaT
    tekka
    @Pictor-Lallemand ok, now next step: substitute all caps to 100uF (or if not available add a second 22uF in parallel). Please test and upload the same logs again. How do you power your nodes?
    • Pictor LallemandP
      Pictor LallemandP
      Pictor Lallemand
      i add 2 capacitors of 22uf in serie the gateway is powered by my laptop
      the node is powered by my laptop for use serial debug
      debug node
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:UPL
      !TSM:UPL:FAIL
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:UPL
      !TSM:UPL:FAIL
      TSM:FPAR
      gw debug
      0;255;0;0;18;2.0.0
      Thank you for your support
      tekkaT 1 Reply Last reply
        debug node
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR:OK
        TSM:ID
        TSM:UPL
        !TSM:UPL:FAIL
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR:OK
        TSM:ID
        TSM:UPL
        !TSM:UPL:FAIL
        TSM:FPAR
        gw debug
        0;255;0;0;18;2.0.0
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        #27
        @Pictor-Lallemand Did you add the 22uF caps in parallel or in series? In parallel you get 44uF, in series ~11uF...
        Pictor LallemandP 1 Reply Last reply
        • tekkaT tekka
          Pictor LallemandP
          Pictor LallemandP
          Pictor Lallemand
          @tekka in parallel
            @tekka in parallel
            tekkaT
            tekkaT
            tekka
            @Pictor-Lallemand ok, then try putting them further away and/or decrease TX_POWER for both nodes by setting
            • tekkaT tekka
              Pictor LallemandP
              Pictor LallemandP
              Pictor Lallemand
              @tekka I just try not conclusive
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              !TSM:UPL:FAIL
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              an idea ?
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR:OK
                TSM:ID
                TSM:UPL
                !TSM:UPL:FAIL
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                an idea ?
                tekkaT
                tekkaT
                tekka
                #31
                @Pictor-Lallemand Looks to me like power issue and/or radio interference. If you have 100uF or larger caps, try replacing them. Also, is there a WiFi AP nearby?
                • tekkaT tekka
                  Pictor LallemandP
                  Pictor LallemandP
                  Pictor Lallemand
                  @tekka it is always the same worries I added capacitors 330uF no wifi point naarby
                    tekkaT
                    tekkaT
                    tekka
                    @Pictor-Lallemand What HW are you using & frequency?
                    • tekkaT tekka
                      Pictor LallemandP
                      Pictor LallemandP
                      Pictor Lallemand
                      @tekka What is the HW?
                        #35
                        @Pictor-Lallemand
                        HW= hardware ;) FW for firmware or SW software
                        that's weird you're not lucky on this, I agree with tekka it looks like hardware issue..Perhaps you could try to replace your usb cable, not sure but who knows, or maybe some bad dupont cable too (try with some other). I have already seen bad usb or dupont cables so...or maybe try with another radio module.
                        • Pictor LallemandP
                          Pictor LallemandP
                          Pictor Lallemand
                          @tekka My HW is arduino pro mini 5v + ams1117 3,3V for radio module and NRF24L01 for radio
                          • Pictor LallemandP
                            Pictor LallemandP
                            Pictor Lallemand
                            @tekka
                            I weld son tips on antenna here debug
                            node
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSP:MSG:READ 0-0-255 s=255,c=3,t=20,pt=0,l=1,sg=0:0
                            TSP:MSG:BC
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSP:MSG:BC
                            TSP:MSG:BC
                            !TSP:FPAR:ACTIVE (msg not send)
                            TSP:MSG:BC
                            TSP:MSG:BC
                            TSP:MSG:BC
                            TSP:MSG:BC
                            TSM:FPAR:OK
                            TSM:ID
                            TSP:MSG:BC
                            TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=ok:0
                            TSP:MSG:BC
                            TSP:MSG:BC
                            TSM:UPL
                            TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                            TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                            TSP:MSG:PONG RECV (hops=1)
                            TSP:CHKUPL:OK
                            TSM:UPL:OK
                            TSM:READY
                            TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                            TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                            TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                            TSP:MSG:READ 0-0-100 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                            TSP:MSG:READ 0-0-100 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                            !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=fail:TestNode
                            !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.0
                            !TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=17,pt=0,l=7,sg=0,ft=2,st=fail:Counter
                            Request registration...
                            !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=fail:2
                            !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=fail:2
                            !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=fail:2
                            !TSM:UPL FAIL, SNP
                            TSM:FPAR
                            !TSP:SEND:TNR
                            TSM:FPAR
                            Init complete, id=100, parent=255, distance=255, registration=1
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            TSM:FPAR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            gateway debug from MYSController
                            8	13/08/2016 18:33:12	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			required
                            10	13/08/2016 18:33:20	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            11	13/08/2016 18:33:22	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            12	13/08/2016 18:33:27	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                            14	13/08/2016 18:33:27	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                            17	13/08/2016 18:33:27	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                            18	13/08/2016 18:33:27	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                            20	13/08/2016 18:33:27	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                            23	13/08/2016 18:33:28	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                            24	13/08/2016 18:33:46	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            25	13/08/2016 18:34:01	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                            27	13/08/2016 18:34:01	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                            30	13/08/2016 18:34:01	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                            31	13/08/2016 18:34:01	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                            33	13/08/2016 18:34:01	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                            36	13/08/2016 18:34:02	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                            37	13/08/2016 18:34:08	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            38	13/08/2016 18:34:08	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                            40	13/08/2016 18:34:08	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                            43	13/08/2016 18:34:09	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                            44	13/08/2016 18:34:09	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                            46	13/08/2016 18:34:09	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                            49	13/08/2016 18:34:09	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                            50	13/08/2016 18:34:09	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            51	13/08/2016 18:34:10	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            52	13/08/2016 18:34:10	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            53	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            54	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            55	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            56	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            57	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            58	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            59	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            60	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            62	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            63	13/08/2016 18:34:13	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            64	13/08/2016 18:34:13	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            65	13/08/2016 18:34:14	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                            67	13/08/2016 18:34:15	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                            69	13/08/2016 18:34:15	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                            71	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	NA (24)	BYTE	1	NO		1
                            72	13/08/2016 18:34:16	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			hops=1)
                            73	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	NA (25)	BYTE	1	NO	ok	1
                            74	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	I_SIGNING_PRESENTATION	CUSTOM	2	NO		0100
                            75	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_SIGNING_PRESENTATION	CUSTOM	2	NO	ok	0100
                            76	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_PRESENTATION	S_ARDUINO_NODE	STRING	5	NO		2.0.0
                            78	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	I_CONFIG	BYTE	1	NO		0
                            81	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_CONFIG	STRING	1	NO	ok	M
                            84	13/08/2016 18:36:27	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                              @tekka
                              node
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSP:MSG:BC
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              TSP:MSG:BC
                              TSP:MSG:BC
                              TSP:MSG:BC
                              TSP:MSG:BC
                              TSP:MSG:BC
                              TSP:MSG:BC
                              TSM:FPAR:OK
                              TSM:ID
                              TSP:MSG:BC
                              TSP:MSG:BC
                              TSP:MSG:BC
                              TSM:UPL
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              !TSM:UPL FAIL, SNP
                              TSM:FPAR
                              !TSP:SEND:TNR
                              TSM:FPAR
                              !TSP:SEND:TNR
                              !TSP:SEND:TNR
                              !TSP:SEND:TNR
                              !TSP:SEND:TNR
                              TSM:FPAR
                              !TSP:SEND:TNR
                              !TSP:SEND:TNR
                              tekkaT
                              tekkaT
                              tekka
                              @Pictor-Lallemand Looks to me like a power issue, not an antenna issue.
                              Half of the messages are OK, and then all of a sudden they all fail:
                              TSM:UPL
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              At what frequency are you running your minis? Out of curiosity, can you post a pic of your node+radio (ideally with a pic of the cap) and GW+radio - this may give additional info.
                              • Pictor LallemandP
                                Pictor LallemandP
                                Pictor Lallemand
                                @tekka
                                my node
                                my gateway
                                  @tekka
                                  my node
                                  my gateway
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Pictor-Lallemand ok, now upload this sketch to both nodes and post the debug output:
                                  #define MY_CORE_ONLY
                                  void setup(){
                                    MY_SERIALDEVICE.begin(115200);
                                    MY_SERIALDEVICE.println(F("**********"));
                                    MY_SERIALDEVICE.println(__FILE__);
                                    MY_SERIALDEVICE.println(MYSENSORS_LIBRARY_VERSION);
                                    MY_SERIALDEVICE.println(hwFreeMem());
                                    MY_SERIALDEVICE.println(hwCPUVoltage());
                                    MY_SERIALDEVICE.println(hwCPUFrequency());
                                    MY_SERIALDEVICE.println(F_CPU);
                                  void loop(){}
                                  • Pictor LallemandP
                                    Pictor LallemandP
                                    Pictor Lallemand
                                    @tekka my debug output
                                    C:\Users\victor\Documents\Arduino\sketch_aug14c\sketch_aug14c.ino
                                    2.0.0
                                    1703
                                    5001
                                    164
                                    16000000
                                      2.0.0
                                      1703
                                      5001
                                      164
                                      16000000
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @Pictor-Lallemand and from your GW?
                                      • Pictor LallemandP
                                        Pictor LallemandP
                                        Pictor Lallemand
                                        @tekka
                                        debug gw
                                        C:\Users\victor\Documents\Arduino\sketch_aug14b\sketch_aug14b.ino
                                        2.0.0
                                        1703
                                        4728
                                        175
                                        16000000
                                          @tekka
                                          debug gw
                                          2.0.0
                                          1703
                                          4728
                                          175
                                          16000000
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @Pictor-Lallemand Ok output looks good, GW is running at a slightly higher frequency - but this can also be an artefact. I assume your radios run at 3V3?
                                          Let's try these things:
                                          1. increase the RF24 data rate to 1MBPS using
                                          #define MY_RF24_DATARATE RF24_1MBPS
                                          1. If (1) doesn't improve the radio transmissions, change the RF24 channel using
                                          #define MY_RF24_CHANNEL 37
