  3. [Solved]UPL:Fail
[Solved]UPL:Fail
47 Posts 7 Posters 18.7k Views 5 Watching
  • Pictor LallemandP
    Pictor LallemandP
    Pictor Lallemand
    i add 2 capacitors of 22uf in serie the gateway is powered by my laptop
    the node is powered by my laptop for use serial debug
    debug node
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=100)
    TSM:FPAR
    TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=100)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    gw debug
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:MSG:READ 100-100-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=100)
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
    0;255;3;0;9;TSP:SANCHK:OK
    Thank you for your support
    tekkaT 1 Reply Last reply
    • Pictor LallemandP Pictor Lallemand
      debug node
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:UPL
      !TSM:UPL:FAIL
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:UPL
      !TSM:UPL:FAIL
      TSM:FPAR
      gw debug
      0;255;0;0;18;2.0.0
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      #27
      @Pictor-Lallemand Did you add the 22uF caps in parallel or in series? In parallel you get 44uF, in series ~11uF...
      Pictor LallemandP 1 Reply Last reply
      • tekkaT tekka
        Pictor LallemandP
        Pictor LallemandP
        Pictor Lallemand
        @tekka in parallel
          @tekka in parallel
          tekkaT
          tekkaT
          tekka
          @Pictor-Lallemand ok, then try putting them further away and/or decrease TX_POWER for both nodes by setting
          • tekkaT tekka
            Pictor LallemandP
            Pictor LallemandP
            Pictor Lallemand
            @tekka I just try not conclusive
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            !TSM:UPL:FAIL
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            an idea ?
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              !TSM:UPL:FAIL
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              an idea ?
              tekkaT
              tekkaT
              tekka
              #31
              @Pictor-Lallemand Looks to me like power issue and/or radio interference. If you have 100uF or larger caps, try replacing them. Also, is there a WiFi AP nearby?
              • tekkaT tekka
                Pictor LallemandP
                Pictor LallemandP
                Pictor Lallemand
                @tekka it is always the same worries I added capacitors 330uF no wifi point naarby
                  tekkaT
                  tekkaT
                  tekka
                  @Pictor-Lallemand What HW are you using & frequency?
                  • tekkaT tekka
                    Pictor LallemandP
                    Pictor LallemandP
                    Pictor Lallemand
                    @tekka What is the HW?
                      #35
                      @Pictor-Lallemand
                      HW= hardware ;) FW for firmware or SW software
                      that's weird you're not lucky on this, I agree with tekka it looks like hardware issue..Perhaps you could try to replace your usb cable, not sure but who knows, or maybe some bad dupont cable too (try with some other). I have already seen bad usb or dupont cables so...or maybe try with another radio module.
                      • Pictor LallemandP
                        Pictor LallemandP
                        Pictor Lallemand
                        @tekka My HW is arduino pro mini 5v + ams1117 3,3V for radio module and NRF24L01 for radio
                        • Pictor LallemandP
                          Pictor LallemandP
                          Pictor Lallemand
                          @tekka
                          I weld son tips on antenna here debug
                          node
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:UPL
                          !TSM:UPL:FAIL
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:UPL
                          !TSM:UPL:FAIL
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:UPL
                          !TSM:UPL:FAIL
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:UPL
                          !TSM:UPL:FAIL
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:UPL
                          !TSM:UPL:FAIL
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSP:MSG:READ 0-0-255 s=255,c=3,t=20,pt=0,l=1,sg=0:0
                          TSP:MSG:BC
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:UPL
                          !TSM:UPL:FAIL
                          TSM:FPAR
                          TSP:MSG:BC
                          TSP:MSG:BC
                          !TSP:FPAR:ACTIVE (msg not send)
                          TSP:MSG:BC
                          TSP:MSG:BC
                          TSP:MSG:BC
                          TSP:MSG:BC
                          TSM:FPAR:OK
                          TSM:ID
                          TSP:MSG:BC
                          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=ok:0
                          TSP:MSG:BC
                          TSP:MSG:BC
                          TSM:UPL
                          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                          TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          TSP:MSG:PONG RECV (hops=1)
                          TSP:CHKUPL:OK
                          TSM:UPL:OK
                          TSM:READY
                          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                          TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                          TSP:MSG:READ 0-0-100 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          TSP:MSG:READ 0-0-100 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                          !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=fail:TestNode
                          !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.0
                          !TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=17,pt=0,l=7,sg=0,ft=2,st=fail:Counter
                          Request registration...
                          !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=fail:2
                          !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=fail:2
                          !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=fail:2
                          !TSM:UPL FAIL, SNP
                          TSM:FPAR
                          !TSP:SEND:TNR
                          TSM:FPAR
                          Init complete, id=100, parent=255, distance=255, registration=1
                          !TSP:SEND:TNR
                          !TSP:SEND:TNR
                          !TSP:SEND:TNR
                          !TSP:SEND:TNR
                          TSM:FPAR
                          !TSP:SEND:TNR
                          !TSP:SEND:TNR
                          gateway debug from MYSController
                          8	13/08/2016 18:33:12	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			required
                          10	13/08/2016 18:33:20	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          11	13/08/2016 18:33:22	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          12	13/08/2016 18:33:27	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                          14	13/08/2016 18:33:27	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                          17	13/08/2016 18:33:27	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                          18	13/08/2016 18:33:27	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                          20	13/08/2016 18:33:27	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                          23	13/08/2016 18:33:28	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                          24	13/08/2016 18:33:46	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          25	13/08/2016 18:34:01	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                          27	13/08/2016 18:34:01	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                          30	13/08/2016 18:34:01	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                          31	13/08/2016 18:34:01	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                          33	13/08/2016 18:34:01	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                          36	13/08/2016 18:34:02	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                          37	13/08/2016 18:34:08	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          38	13/08/2016 18:34:08	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                          40	13/08/2016 18:34:08	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                          43	13/08/2016 18:34:09	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                          44	13/08/2016 18:34:09	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                          46	13/08/2016 18:34:09	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                          49	13/08/2016 18:34:09	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                          50	13/08/2016 18:34:09	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          51	13/08/2016 18:34:10	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          52	13/08/2016 18:34:10	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          53	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          54	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          55	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          56	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          57	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          58	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          59	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          60	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          62	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          63	13/08/2016 18:34:13	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          64	13/08/2016 18:34:13	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                          65	13/08/2016 18:34:14	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                          67	13/08/2016 18:34:15	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                          69	13/08/2016 18:34:15	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                          71	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	NA (24)	BYTE	1	NO		1
                          72	13/08/2016 18:34:16	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			hops=1)
                          73	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	NA (25)	BYTE	1	NO	ok	1
                          74	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	I_SIGNING_PRESENTATION	CUSTOM	2	NO		0100
                          75	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_SIGNING_PRESENTATION	CUSTOM	2	NO	ok	0100
                          76	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_PRESENTATION	S_ARDUINO_NODE	STRING	5	NO		2.0.0
                          78	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	I_CONFIG	BYTE	1	NO		0
                          81	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_CONFIG	STRING	1	NO	ok	M
                          84	13/08/2016 18:36:27	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                            @tekka
                            node
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSP:MSG:BC
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSP:MSG:BC
                            TSP:MSG:BC
                            TSP:MSG:BC
                            TSP:MSG:BC
                            TSP:MSG:BC
                            TSP:MSG:BC
                            TSM:FPAR:OK
                            TSM:ID
                            TSP:MSG:BC
                            TSP:MSG:BC
                            TSP:MSG:BC
                            TSM:UPL
                            TSP:CHKUPL:OK
                            TSM:UPL:OK
                            TSM:READY
                            !TSM:UPL FAIL, SNP
                            TSM:FPAR
                            !TSP:SEND:TNR
                            TSM:FPAR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            TSM:FPAR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            tekkaT
                            tekkaT
                            tekka
                            @Pictor-Lallemand Looks to me like a power issue, not an antenna issue.
                            Half of the messages are OK, and then all of a sudden they all fail:
                            TSM:UPL
                            TSP:CHKUPL:OK
                            TSM:UPL:OK
                            TSM:READY
                            At what frequency are you running your minis? Out of curiosity, can you post a pic of your node+radio (ideally with a pic of the cap) and GW+radio - this may give additional info.
                            • Pictor LallemandP
                              Pictor LallemandP
                              Pictor Lallemand
                              @tekka
                              my node
                              my gateway
                                @tekka
                                my node
                                my gateway
                                tekkaT
                                tekkaT
                                tekka
                                @Pictor-Lallemand ok, now upload this sketch to both nodes and post the debug output:
                                #define MY_CORE_ONLY
                                void setup(){
                                  MY_SERIALDEVICE.begin(115200);
                                  MY_SERIALDEVICE.println(F("**********"));
                                  MY_SERIALDEVICE.println(__FILE__);
                                  MY_SERIALDEVICE.println(MYSENSORS_LIBRARY_VERSION);
                                  MY_SERIALDEVICE.println(hwFreeMem());
                                  MY_SERIALDEVICE.println(hwCPUVoltage());
                                  MY_SERIALDEVICE.println(hwCPUFrequency());
                                  MY_SERIALDEVICE.println(F_CPU);
                                void loop(){}
                                • Pictor LallemandP
                                  Pictor LallemandP
                                  Pictor Lallemand
                                  @tekka my debug output
                                  C:\Users\victor\Documents\Arduino\sketch_aug14c\sketch_aug14c.ino
                                  2.0.0
                                  1703
                                  5001
                                  164
                                  16000000
                                    2.0.0
                                    1703
                                    5001
                                    164
                                    16000000
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Pictor-Lallemand and from your GW?
                                    • Pictor LallemandP
                                      Pictor LallemandP
                                      Pictor Lallemand
                                      @tekka
                                      debug gw
                                      C:\Users\victor\Documents\Arduino\sketch_aug14b\sketch_aug14b.ino
                                      2.0.0
                                      1703
                                      4728
                                      175
                                      16000000
                                        @tekka
                                        debug gw
                                        2.0.0
                                        1703
                                        4728
                                        175
                                        16000000
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Pictor-Lallemand Ok output looks good, GW is running at a slightly higher frequency - but this can also be an artefact. I assume your radios run at 3V3?
                                        Let's try these things:
                                        1. increase the RF24 data rate to 1MBPS using
                                        #define MY_RF24_DATARATE RF24_1MBPS
                                        1. If (1) doesn't improve the radio transmissions, change the RF24 channel using
                                        #define MY_RF24_CHANNEL 37
                                        • Pictor LallemandP
                                          Pictor LallemandP
                                          Pictor Lallemand
                                          @tekka I already used the command 1Mbit
