  3. Alternative to ArduinoIDE
29 Posts 13 Posters 9.8k Views 10 Watching
  • Daniel OliveiraD Offline
    Daniel Oliveira
    wrote on last edited by Daniel Oliveira
    Hi everyone!
    I would like o know if any of you use an IDE to develop MySensors projects and libraries, I find ArduinoIDE atrocious.
    Actually I think that it does not even deserve the name of IDE because does not even highlight all occurrences of a selected work.
    I've tried sloeber: http://eclipse.baeyens.it/index.shtml but I'm not able to make it to compile the MySensors library 2.0.0 due to the extensive use of #defines and #ifndef, etc.
    Does anybody use anything else that can recommend?
    Thank you all in advance,
    Daniel
    MySensors rules my home :)
    andrewA 1 Reply Last reply
    • hekH Offline
      hekH Offline
      Old thread, but something might still apply:
      https://forum.mysensors.org/topic/1369/best-ide-to-use-for-mysensors-projects
      Daniel OliveiraD 1 Reply Last reply
        Daniel Oliveira
        Hello @hek, @tekka, @Anticimex and @Yveaux ,
        I'm sorry to bothering you, but I would appreciate a feedback from you :)
        I have professional experience as software tester/developer but from a completely different world, nevertheless I would like to go back to my roots (electronics) and start participating more actively in this great community.
        So I would like to have your feedback on your development environment, software used etc. Something that you can recommend? I honestly would love an IDE like eclipse.
        Do you have experience with anything other than ArduinoIDE like THIS plugin for Visual Studio and Atmel Studio, THISeclipse plugin, the recent PlatformIO or other?
        AnticimexA 1 Reply Last reply
        • Daniel OliveiraD Daniel Oliveira
          AnticimexA Offline
          AnticimexA Offline
          Anticimex
          @Daniel-Oliveira I use the stino plugin for sublime text. It basically abstracts the arduino IDE so you still get the piss poor build system but then, you have to use it if you want to easily use libraries and program the device I suppose. But at least all operations are done from within sublime text and the arduino IDE just need to be installed, not running. But it can be a but tricky to configure the plugin properly and it lags somewhat behind new Arduino IDE releases.
            Daniel Oliveira
            Thanks @hek,
            I was writing at same time you replied, I'll take a look.
              Thanks @hek,
              YveauxY Offline
              YveauxY Offline
              @Daniel-Oliveira I want to take another look at the ARduino Makefile https://github.com/sudar/Arduino-Makefile
              Seems promising, especially since I'm now able to run a Linux subsystem on Windows since the Windows 10 Anniversary Update; saves me the trouble of installing cygwin etc.
              • E Offline
                E Offline
                ericvdb
                There is also Visual Micro for Visual Studio
                • scalzS Offline
                  scalzS Offline
                  I'm still using arduino ide, or sublimetext on my side too...it's a long time i would like to try visualmicro so i could use VS but never find the time to try.
                  problem is sometimes when you change your chain, things can goes well or you need to dig in. so i was lazy. But i agree, arduino ide is ...too simple :) something with brackets (I don't know if there is a plugin like this btw) or sublimetext, is simple but a lot better!
                  And more sense to use a nice ide, if you want to use other mcu with mysensors..on my side I prefer local solution, not a big fan of cloud dev..
                  @ericvdb do you use VisualMicro ? does it work well, not so much things to change to make libs working, mysensors for instance? it's very tempting..
                  tekkaT 1 Reply Last reply
                  • scalzS scalz
                    tekkaT Offline
                    tekkaT Offline
                    tekka
                    @scalz @Daniel-Oliveira I'm using VS with VisualMicro - works smoothly with lots of nice features...
                    • scalzS Offline
                      scalzS Offline
                      @tekka rooooooh, that's not fair :) thx for info :thumbsup: so now I have no excuse to not try. great
                        Daniel Oliveira
                        Thanks to all of you for your feedback,
                        I'll give it a try to Visual Micro, I?m also curious about PlatformIO with eclipse as editor.
                        I'll keep ou posted on the results for future reference.
                        Regards
                        • D Offline
                          drock1985
                          This is a good thread; been recently contemplating changing IDE's myself.
                          Visual Studio seems to be the most complete - I think I will give this one a try. Anyone have any tips for how to use this coming from the Arduino IDE (with no previous programming experience?)
                          My Projects
                          2 Door Chime Sensor
                          Washing Machine Monitor
                          • D drock1985
                            Daniel Oliveira
                            Being using it from some hours and indeed it seems to be a great alternative, it even has a dark skin :D
                            You can use it to program in a more pure C++ way (my goal here), but it also support projects with .ino files so you can use your existing ArduinoIDE projects.
                            To get used to Visual Studio/Micro I'm following their User guide, you can find it HERE
                            Feel free to continue sharing your experiences
                            S 1 Reply Last reply
                              stedew
                              @Daniel-Oliveira
                              Hello Daniel for what it's worth: Jantje posted a Fix in Github:
                              the selection of subfolders included to the path is not consistent with the Arduino IDE
                              Just have to test it further
                              Regards,
                              Stefan
                              • tbowmoT Offline
                                tbowmoT Offline
                                tbowmo
                                I have plans for trying to get platform.io up and running, specially because I use ATOM editor for most file editing (even in mysensors core).
                                I have some shell scripts that enables me to build sketches etc. from cli, all are based on arduino in cli mode though, but makes it easy for me to verify errors / warnings in a sketch when I hack on core files (which you can't edit through arduino anyways)
                                • S Offline
                                  Stuart Middleton
                                  As a professional developer who lives in Visual Studio and XCode, I prefer the VS plugin. I'm not saying it's any good, and in fact it crashes now and then, but you get all of the power of VS behind you.
                                  dpressleD 1 Reply Last reply
                                  • S Stuart Middleton
                                    dpressleD Offline
                                    dpressleD Offline
                                    dpressle
                                    @Stuart-Middleton +1
                                    Are you using vs2015? with the arduino IDE extension?
                                    • S Offline
                                      Stuart Middleton
                                      Yes. However I've found it more unstable than the previous version. Maybe that's just my setup.
                                        dpressleD Offline
                                        dpressleD Offline
                                        dpressle
                                        @Stuart-Middleton I am getting so many errors on a simple sketch:
                                        Severity Code Description Project File Line Suppression State
                                        Error (active) expected a '{' c:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.h 154
                                        What am i missing here?
                                        • dpressleD Offline
                                          dpressleD Offline
                                          dpressle
                                          Error (active) missing closing quote c:\Users\dpressle\Documents\Arduino\libraries\MySensors-2.0.0\core\MyTransport.cpp 507
                                          Error (active) missing closing quote c:\Users\dpressle\Documents\Arduino\libraries\MySensors-2.0.0\core\MySensorsCore.cpp 262
                                          i get this on all of the debug function calls in these files.
                                          11.9k
                                          113.3k
