  3. node var request issue
12 Posts 3 Posters 3.4k Views 1 Watching
  • epierreE Offline
    epierreE Offline
    epierre
    My water meter has several issues since going 1.4 :
    • transmission/reception issues
    • reception of a variable value
      With the same hardware/software in 1.3 it was perfectly functional, not it isn't... do you have an idea how to improve the node to request the var at a frequent pace till it gets the answer or is able to read the answer ?
    thanks,
    z-wave - Vera -> Domoticz
    • epierreE Offline
      epierreE Offline
      epierre
      @hek here is what the console shows me:
      sensor started, id 2
      send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=3,st=ok:1.4
      send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
      send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=11,st=ok:Water Meter
      send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=8,st=ok:1.0 reed
      send: 2-2-0-0 s=5,c=0,t=21,pt=0,l=3,st=ok:1.4
      send: 2-2-0-0 s=5,c=2,t=24,pt=0,l=3,st=ok:1.4
      read: 0-0-2 s=5,c=3,t=24,pt=0,l=5:50623
      I don't see the println from incomming message.
      Afterward the node keeps asking the VAR_1 value to the node although answers are given:
      send: 2-2-0-0 s=5,c=2,t=24,pt=0,l=5,st=ok:50623
      and so on ...
      I'm not so confident this piece of code works:
       if (message.type==V_VAR1) {
      pulseCount = oldPulseCount = message.getLong();
      Serial.print("Received last pulse count from gw:");
      Serial.println(pulseCount);
      pcReceived = true;
      • hekH Offline
        hekH Offline
        @epierre
        Looks like you might have mixed up command-types in your gateway when responding to requests. Should be SET (c=1).
        Right now c=3 == INTERNAL
        • epierreE Offline
          epierreE Offline
          epierre
          @hek argh... values having changed, it would have been good to have such low level exchanges a bit documented as before(at least explaining you answer a get by a set...)... now that part works,
          Next I have to investigate why it is not counting anymore... so bat we can't yet make OTA updates
          https://github.com/empierre/arduino/blob/master/WaterMeterPulseSensor2.ino
          • epierreE Offline
            epierreE Offline
            epierre
            ok this is now fixed, I added a led pulse too.
            @hek could wwe provide both methods in the smae sketch to handle both visual pulse and reed ? the default one does not work for reed....
            hekH 1 Reply Last reply
            • epierreE epierre
              hekH Offline
              hekH Offline
              @epierre
              Please go ahead and make the addition to support reed senors.
                @epierre
                YveauxY Offline
                YveauxY Offline
                @hek What's different from a regular button when using a reed sensor? Both have to be debounced...
                • YveauxY Yveaux
                  hekH Offline
                  hekH Offline
                  @Yveaux
                  I have no idea.... @epierre could perhaps give some insight?
                    @Yveaux
                    YveauxY Offline
                    YveauxY Offline
                    @epierre @hek This is what we're talking about, right?
                    • YveauxY Yveaux
                      hekH Offline
                      hekH Offline
                      @Yveaux
                      I might have misinterpreted @epierre. But I would guess he means that type of reed switch @Yveaux .. But I cannot understand why that would make any difference from any other pulse sensor.. Maybe the pulses are longer?
                        @Yveaux
                        YveauxY Offline
                        YveauxY Offline
                        @hek Maybe what I said -- it has to be debounced.
                        Let's wait for input from @epierre then ;-)
                        • epierreE Offline
                          epierreE Offline
                          epierre
                          @Yveaux @hek in fact it has to be debounced for it vibrates on rising and falling so it is important to see. maybe the bling delay would do it simply but someoone may remove the led...
                          Also through trial and error here is the way to manage it:
                            // Setup the reed
                            pinMode(DIGITAL_INPUT_SENSOR,INPUT);
                            // Activate internal pull-up
                            digitalWrite(DIGITAL_INPUT_SENSOR,HIGH);
                            attachInterrupt(INTERRUPT, onPulse, FALLING);
                          you have to power the pin to get the signal when both sides are connected.
                          113.2k
