  3. node var request issue
12 Posts 3 Posters 3.9k Views 1 Watching
    @epierre
    Looks like you might have mixed up command-types in your gateway when responding to requests. Should be SET (c=1).
    Right now c=3 == INTERNAL
    • epierreE
      epierreE
      epierre
      @hek argh... values having changed, it would have been good to have such low level exchanges a bit documented as before(at least explaining you answer a get by a set...)... now that part works,
      Next I have to investigate why it is not counting anymore... so bat we can't yet make OTA updates
      https://github.com/empierre/arduino/blob/master/WaterMeterPulseSensor2.ino
      z-wave - Vera -> Domoticz
      • epierreE
        epierreE
        epierre
        ok this is now fixed, I added a led pulse too.
        @hek could wwe provide both methods in the smae sketch to handle both visual pulse and reed ? the default one does not work for reed....
        hekH 1 Reply Last reply
        • epierreE epierre
          @epierre
          Please go ahead and make the addition to support reed senors.
            @epierre
            @hek What's different from a regular button when using a reed sensor? Both have to be debounced...
            • YveauxY Yveaux
              @Yveaux
              I have no idea.... @epierre could perhaps give some insight?
                @Yveaux
                @epierre @hek This is what we're talking about, right?
                • YveauxY Yveaux
                  @Yveaux
                  I might have misinterpreted @epierre. But I would guess he means that type of reed switch @Yveaux .. But I cannot understand why that would make any difference from any other pulse sensor.. Maybe the pulses are longer?
                    @Yveaux
                    @hek Maybe what I said -- it has to be debounced.
                    Let's wait for input from @epierre then ;-)
                    • epierreE
                      epierreE
                      epierre
                      @Yveaux @hek in fact it has to be debounced for it vibrates on rising and falling so it is important to see. maybe the bling delay would do it simply but someoone may remove the led...
                      Also through trial and error here is the way to manage it:
                        // Setup the reed
                        pinMode(DIGITAL_INPUT_SENSOR,INPUT);
                        // Activate internal pull-up
                        digitalWrite(DIGITAL_INPUT_SENSOR,HIGH);
                        attachInterrupt(INTERRUPT, onPulse, FALLING);
                      you have to power the pin to get the signal when both sides are connected.
                      12.5k
