  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
    wrote on last edited by hek
    This thread contains comments for the article "Temperature Sensor" posted on MySensors.org.
    • mrwombleM
      mrwombleM
      mrwomble
      Hi there, I'm new to Mysensors and I thought I'd start with a simple DS Temp sensor. However, I'm getting compile errors when I try compile it. Can someone please point me in the right direction?
      Arduino: 1.6.11 (Windows 7), Board: "Arduino Nano, ATmega328"
      WARNING: Category 'Sensor' in library DallasTemperature is not valid. Setting to 'Uncategorized'
      In file included from C:\Users\Admin\Documents\Arduino\Projects\MS Temp sensor node\DallasTemperatureSensor\DallasTemperatureSensor.ino:37:0:
      C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()':
      C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:249:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
           int16_t millisToWaitForConversion(uint8_t);
      DallasTemperatureSensor:85: error: within this context
      Multiple libraries were found for "DallasTemperature.h"
       Used: C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature
       Not used: C:\Users\Admin\Documents\Arduino\libraries\Arduino-Temperature-Control-Library-master
      exit status 1
      within this context
      S 1 Reply Last reply
      • mrwombleM
        mrwombleM
        mrwomble
        Ah, never mind! Managed to resolve it after all. For the benefit of others who may hit the same issue: the code depends on a very particular version of the DallasTemperature library, the versions downloaded via the Arduino IDE don't work and give the errors above. I had to download the library from the examples on github here: https://github.com/mysensors/MySensorsArduinoExamples
        remisR 1 Reply Last reply
        • mrwombleM mrwomble
          remisR
          remisR
          remis
          @mrwomble
          Hello mrwomble.
          Could you detail the file you have use to compile OK ? Do we need to use the full library? I plan to use local file with
          #include "filename.h"
          instead of
          #include <filename.h>
          • Patrik SöderströmP
            Patrik SöderströmP
            Patrik Söderström
            I have trouble with this on a NodeMCU 0.9.
            #error "Please define I/O register types here"
            Anyone who can help?
            • Patrik SöderströmP Patrik Söderström
              @Patrik-Söderström could you give us some more context about the problem?
              Which line does the error occur on? Does the error message say anything more? (we are not magicians :-) )
              Have you modified the example sketch in any way? if so, what changes?
                Patrik SöderströmP
                Patrik Söderström
                wrote on last edited by Patrik Söderström
                I use the following code, I have added the GW support for ESP board.
                 * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                 * http://www.mysensors.org/build/temp
                //#define MY_RADIO_NRF24
                #define MY_BAUD_RATE 9600
                #define MY_GATEWAY_ESP8266
                #define MY_ESP8266_SSID "TP54C10"
                #define MY_ESP8266_PASSWORD "blarretp54c10"
                #define MY_PORT 5003
                #include <ESP8266WiFi.h>
                #include <OneWire.h>
                int numSensors=0;
                bool receivedConfig = false;
                bool metric = true;
                MyMessage msg(0,V_TEMP);
                void before()
                  sensors.begin();
                     present(i, S_TEMP);
                  sleep(conversionTime);
                    float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                    #if COMPARE_TEMP == 1
                  sleep(SLEEP_TIME);
                the exakt error I get in Arduino IDE is
                In file included from C:\Users\xxxxx\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:22:0,
                                 from Z:\MySensors\NodeMCU-Water meter\NodeMCU-Water_meter\NodeMCU-Water_meter.ino:51:
                C:\Users\xxxxxx\Documents\Arduino\libraries\OneWire/OneWire.h:108:2: error: #error "Please define I/O register types here"
                exit status 1
                Error compiling for board NodeMCU 0.9 (ESP-12 Module).```
                  int numSensors=0;
                  bool metric = true;
                  void before()
                    sensors.begin();
                       present(i, S_TEMP);
                    sleep(SLEEP_TIME);
                  exit status 1
                  @Patrik-Söderström according to http://www.esp8266.com/viewtopic.php?f=12&t=9430 you need a newer version of the onewire library.
                  • toddsantoroT
                    toddsantoroT
                    toddsantoro
                    Can anyone tell me what these errors say?
                    DallasTemperature.cpp:433: error: no 'int16_t DallasTemperature::calculateTemperature(const uint8_t*, uint8_t*)' member function declared in class 'DallasTemperature'
                    int16_t DallasTemperature::calculateTemperature(const uint8_t* deviceAddress, uint8_t* scratchPad){
                    sketch/DallasTemperature.cpp: In member function 'int16_t DallasTemperature::getTemp(const uint8_t*)':
                    DallasTemperature.cpp:484: error: 'calculateTemperature' was not declared in this scope
                    if (isConnected(deviceAddress, scratchPad)) return calculateTemperature(deviceAddress, scratchPad);
                    sketch/DallasTemperature.cpp: In member function 'bool DallasTemperature::hasAlarm(const uint8_t*)':
                    DallasTemperature.cpp:764: error: 'calculateTemperature' was not declared in this scope
                    char temp = calculateTemperature(deviceAddress, scratchPad) >> 7;
                    exit status 1
                    • remisR remis
                      @mrwomble
                      Hello mrwomble.
                      instead of
                      remisR
                      remisR
                      remis
                      @remis
                      I confirm that i can suppress the compilation error but nothing append on serial port...
                      Could somebody write here the typical serial port output with debug available?
                      This example is not working. What is the good solution to use this temperature sensor ?
                      thanks
                      • A
                        Alex B Goode
                        Why don't we use an internal pull-up resistor available within an arduino board? Why additional external one?
                        pinMode(pin, INPUT); // set pin to input
                        digitalWrite(pin, HIGH); // turn on pullup resistors
                        • A Alex B Goode
                          @Alex-B-Goode the datasheet says "The 1-Wire bus requires an external pullup resistor of approximately 5kΩ"
                          The internal pull-up of most Arduinos are 20-50kΩ
                          So my guess is that the reason is that the person who created the instructions read the datasheet and chose to follow its recommendation. But accounding to http://electronics.stackexchange.com/a/62096/107155 the exact size might not be important, so it might be possible to use the internal pull up. Try it and let us know if it works.
                          • toddsantoroT
                            toddsantoroT
                            toddsantoro
                            Does this example compile for anyone??? I get this error:
                            In file included from /Users/Documents/Arduino/tas_temp/tas_temp.ino:37:0:
                            /Users/Documents/Arduino/libraries/DallasTemperature/DallasTemperature.h: In function 'void loop()':
                            /Users/Documents/Arduino/libraries/DallasTemperature/DallasTemperature.h:252:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
                            tas_temp:85: error: within this context
                            exit status 1
                            within this context
                            • toddsantoroT toddsantoro
                              exit status 1
                              within this context
                              @toddsantoro see post 2 and 3 in this thread or read the instructions on the build page, just under the "Example" heading.
                              mrwombleM toddsantoroT 2 Replies Last reply
                                mrwombleM
                                mrwombleM
                                mrwomble
                                ^ What he said 😁
                                  toddsantoroT
                                  toddsantoroT
                                  toddsantoro
                                  wrote on last edited by toddsantoro
                                  @mfalkvidd OK. I have it compiling and uploaded to the nano. My config file looks like this now:
                                  sensor 6:
                                    -platform: onewire
                                      names:
                                        some_id: outside
                                        mount_dir: "/mnt/1wire"
                                  I get an error when I restart HASS on the Pi.
                                  ERROR (Thread-6) [homeassistant.components.sensor.onewire] No onewire sensor found. Check if dtoverlay=w1-gpio is in your /boot/config.txt. Check the mount_dir parameter if it's defined.
                                  I guess my question is do I need to define the mount_dir variable and if so is the one I have correct? And if it is correct do I need to create that directory on my Pi?
                                  I also do not get any output in the Arduino Serial Monitor window. Not sure if I even should...
                                  Thanks in advance for any help...
                                    sensor 6:
                                      -platform: onewire
                                        names:
                                          some_id: outside
                                    @toddsantoro I am not familiar with homeassistant so I have no clue unfortunately.
                                    About debug output on the serial monitor: Debug needs to be enabled first. See instructions at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help and https://www.mysensors.org/build/debug
                                    Debug output is often essential when troubleshooting.
                                    toddsantoroT 1 Reply Last reply
                                      toddsantoroT
                                      toddsantoroT
                                      toddsantoro
                                      @mfalkvidd Thank you!!! I get this output in the serial monitor
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSP:ASSIGNID:OK (ID=2)
                                      TSM:FPAR
                                      TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                      TSM:FPAR
                                      TSP:MSG:READ 0-0-2 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      TSP:MSG:PAR OK (ID=0, dist=1)
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=2)
                                      TSM:UPL
                                      TSP:PING:SEND (dest=0)
                                      TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                      TSP:MSG:READ 0-0-2 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      TSP:MSG:PONG RECV (hops=1)
                                      TSP:CHKUPL:OK
                                      TSM:UPL:OK
                                      TSM:READY
                                      TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                      TSP:MSG:SEND 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                      TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                      TSP:MSG:READ 0-0-2 s=255,c=3,t=6,pt=0,l=1,sg=0:I
                                      TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=ok:Temperature Sensor
                                      TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
                                      Request registration...
                                      TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                      TSP:MSG:READ 0-0-2 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      Node registration=1
                                      Init complete, id=2, parent=0, distance=1, registration=1
                                      Does this look OK? If so I will ask my previous question on the Home Assistant forum. You have been a great help and once I get one of these things down I will be able to help others:)
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:CHKID:OK (ID=2)
                                        TSM:UPL
                                        TSP:CHKUPL:OK
                                        TSM:UPL:OK
                                        TSM:READY
                                        Node registration=1
                                        @toddsantoro yes that looks good.
                                        The "st=ok:xyz" means message xyz was acknowledged by the destination node (in your case by the gateway)
                                          stingone
                                          No compile error but i cant see anything on the serial monitor. also the temp sensor burend out with a 4k7 resistor :S
