  2. Bug Reports
  3. OTA firmware updating is too slow..
23 Posts 7 Posters 10.3k Views 9 Watching
  • yd kimY
    yd kimY
    yd kim
    0_1474527483347_MySensors_20160922-171044 - Copy.zip I'm using Mysensors 2.0 for weatherstation and try to use OTA function. It works but too slow and got fail on every 4-10 message. 65k hex file took over 1hour which seems not normal. Node and Gateway are close enough( about 1.5 meter without wall) and sensor data has no loss at all.
    I think this is related with presentation issue which I have and solve with wait (200).
    I have attached log file.
    Is there anything I'm missing this issue?
    Thank you in advance.
    Regards,
    YD
    • yd kimY yd kim
      Regards,
      YD
      sundberg84S
      sundberg84S
      @yd-kim - I had this issue as well, because the node and gateway was to close to each-other.
      Try to move them apart some more if possible and try.
      • yd kimY
        yd kimY
        yd kim
        Thank you for quick reply.
        I moved it to downstairs. There is one door is closed. but seems not much different.
        I put node into downstairs cupboard and close door but seems not much different.
        Thank you. Looks like handling issue. probably too fast to handle in steam mode?
        My node is 8Mhz 3.3V board and Gateway is 5V. Both are atmega328.
        YD
        • yd kimY yd kim
          YD
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @yd-kim
          Firmware messages have longer payload than regular temp or similar sensor messages. If you don't have perfect communication you will probably experience dropped messages during OTA FW update even if you don't have that problem for normal operation.
          • yd kimY
            yd kimY
            yd kim
            Thanks martinhjelmare,
            Yes seems that happen to me however I have no idea why it happen.
            I have added 10uF cap for NRF24L01 and another 470uF as well.
            It happen when presentation when I load 9 sensors. I have to add wait(200) for each present() otherwise 4th or 5th fail.
            Looks like there is no handshake or doesn't consider receiver capacity.
            Is there any workaround to fix this?
            Main issue is when it fails, seems wait about 5 seconds to send again. As long as it wait less than a second, it will help for this situation..
            Cheers,
            YD
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              I can post my test sketch for OTA FW updates that I used when developing support for it in pymysensors. It worked good on a SensebenderMicro 8 MHz. I think I made some adjustments to make the update more effective. I also found that it worked better with debug activated, which might be a sign that communication was not perfect. My guess is printing to serial slows down things just a little bit.
              • yd kimY
                yd kimY
                yd kim
                It will be great. I also turn on debug..
                It means driver itself is too fast to handle on atmega328??
                If we can reduce delay when it fails,it will be great. 5 seconds is too much I guess.
                • AndurilA
                  AndurilA
                  Anduril
                  @yd-kim what bootloader are you using? I have similar problems with tekkas newest bootloader, but the older one works fine for me.
                  yd kimY 1 Reply Last reply
                  • AndurilA Anduril
                    yd kimY
                    yd kimY
                    yd kim
                    @Anduril
                    Oh really? I did use MYSBootloaderV13pre.hex.
                    Can you let me know which one you use?
                    • AndurilA
                      AndurilA
                      Anduril
                      yeah I tried with the V13pre.hex, but with that I had problems as you descibed. Also the serial upload didn't worked for me. So there was no reason to not use the old one wich was included in his beta of MYSController. That worked much better. Maybe you can find the old version on tekkas download site of MYSController.
                      • AndurilA Anduril
                        yd kimY
                        yd kimY
                        yd kim
                        @Anduril
                        Thank you! Will try tomorrow and update on this post!
                        • AndurilA
                          AndurilA
                          Anduril
                          just as an update, here the link to tekkas 'old' MySController with the old bootloader: https://forum.mysensors.org/topic/838/windows-gui-controller-for-mysensors/2
                          • martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            I implemented a check for firmware update message in my modified SenseBenderMicro sketch, and alternative behavior in the loop if FW update is ongoing. This doesn't solve the problem of dropped messages, but could be good to speed up the update and don't waste time on sensor updates.
                              if (fwUpdateOngoing) {
                                fwUpdateOngoing = false;
                                fwUpdateOngoing = wait(OTA_WAIT_PERIOD, C_STREAM, ST_FIRMWARE_RESPONSE);
                                normalFlow();
                            void normalFlow() {
                              sleep(5);
                              int buttonValue = digitalRead(BUTTON_PIN);
                              measureCount ++;
                              sendBattery ++;
                              bool forceTransmit = false;
                              transmission_occured = false;
                            #ifndef MY_OTA_FIRMWARE_FEATURE
                                highfreq = false;
                              if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
                                forceTransmit = true;
                                measureCount = 0;
                              if (buttonValue != oldValue) {
                                 // Send in the new buttonValue
                                 send(msg.set(buttonValue==HIGH ? 0 : 1));
                                 oldValue = buttonValue;
                                 transmission_occured = true;
                            #ifdef MY_OTA_FIRMWARE_FEATURE
                              if (transmission_occured) {
                              sleep(digitalPinToInterrupt(BUTTON_PIN), CHANGE, MEASURE_INTERVAL);
                            Mark SwiftM M 2 Replies Last reply
                                  normalFlow();
                              void normalFlow() {
                                sleep(5);
                                measureCount ++;
                                sendBattery ++;
                                  highfreq = false;
                                  measureCount = 0;
                              Mark SwiftM
                              Mark SwiftM
                              Mark Swift
                              tekkaT 1 Reply Last reply
                              • Mark SwiftM Mark Swift
                                [[topic:post-is-deleted]]
                                tekkaT
                                tekkaT
                                tekka
                                @Mark-Swift I'm not sure I understood you right - can you explain how this applies to the bootloader?
                                • Mark SwiftM
                                  Mark SwiftM
                                  Mark Swift
                                  wrote on last edited by Mark Swift
                                        normalFlow();
                                    void normalFlow() {
                                      sleep(5);
                                      measureCount ++;
                                      sendBattery ++;
                                        highfreq = false;
                                        measureCount = 0;
                                    manutremo
                                    Sorry to revive this old topic but I didn't find any other one that covered this topic.
                                    I started implementing FOTA in all my nodes and was finding some low speeds as described on this topic. I then implemented the checks proposed by @martinhjelmare and they certainly helped :grinning: , although they are not yet perfect.
                                    As I said I didn't other topics covering how to avoid the node from doing anything else while the FOTA is in place, not did I find any other examples on this web nor in the github mysensors examples folder.
                                    Is this the only way to do this, or is there any other better way around since this was published?
                                      manutremo
                                      No wonder, I think I found the way... I found there is a function isFirmwareUpdateOngoing() in MyOTAFirmwareUpdate.cpp that seems to provide that functionality in a much easier way :+1:
                                      • Mark SwiftM
                                        Mark SwiftM
                                        Mark Swift
                                        @manutremo please share your method so we can all benefit :)
                                          manutremo
                                          If I understood correctly, it should as simple as in loop:
                                          if (!isFirmwareUpdateOngoing()) {
                                          <do whatever>
                                          but for the moment take it with a pinch of salt...
