  2. Announcements
  • M marceloaqno
    @hawk_2050 same for you guys who helped, thank you for all the feedback.
    @jerseyguy1996 I don't see anything wrong with your config.Try to add a small delay() after the first send() and before the sendBattery().
    @annegerben This looks like a wire problem. I updated the guide, check the wire section again.
    annegerben
    @marceloaqno thanks for the updated in the guide, I've now successfully connected the radio to the RPI.
    • E
      E
      ericvdb
      Would it be possible to connect a I2C display to display some information, and drive that display from within mysGatway.cpp ?
      • E ericvdb
        marceloaqno
        Code Contributor
        @ericvdb I2C is the next thing I'll do as soon as I finished adding support for signing.
        • jerseyguy1996J
          jerseyguy1996J
          jerseyguy1996
          @marceloaqno Amazing....adding the short delay fixed it! I'm curious why that is the case. Do you have an explanation for that?
          • jerseyguy1996J jerseyguy1996
            marceloaqno
            Code Contributor
            wrote on last edited by marceloaqno
            #23
            @jerseyguy1996 It's probaly related to this: https://www.mysensors.org/build/raspberry#improving-throughput-for-nrf24
            jerseyguy1996J 1 Reply Last reply
            • Patrik SöderströmP
              Patrik SöderströmP
              Patrik Söderström
              Just installed MySensors on one of my Raspberry. Works really great! :) Picks up the other node I have over NRF without trouble. Next I will try and add some sensors directly on the Raspberry.
              Big thanks for this!
              • M marceloaqno
                jerseyguy1996J
                jerseyguy1996J
                jerseyguy1996
                wrote on last edited by jerseyguy1996
                #25
                @marceloaqno Oh that makes sense :-) I'm wondering if that is also what is causing my problem with reconnecting when the node loses contact with the gateway. The node connects perfectly when the gateway is running but if it loses the connection for any reason it can't seem to be able to reconnect and just goes into a loop of attempts. Here is the debug info from the node:
                This is the initialization output
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=3)
                TSM:FPAR
                TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSP:MSG:READ 0-0-3 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                TSP:MSG:PAR OK (ID=0, dist=1)
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=3)
                TSM:UPL
                TSP:PING:SEND (dest=0)
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                TSP:MSG:READ 0-0-3 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                TSP:MSG:PONG RECV (hops=1)
                TSP:CHKUPL:OK
                TSM:UPL:OK
                TSM:READY
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                TSP:MSG:SEND 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                TSP:MSG:READ 0-0-3 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=ok:Sensor Node
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                TSP:MSG:SEND 3-3-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 3-3-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 3-3-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 3-3-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 3-3-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                Request registration...
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                TSP:MSG:READ 0-0-3 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                Node registration=1
                Init complete, id=3, parent=0, distance=1, registration=1
                TSP:MSG:SEND 3-3-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:32.00
                TSP:MSG:SEND 3-3-0-0 s=2,c=1,t=24,pt=3,l=2,sg=0,ft=0,st=ok:0
                TSP:MSG:SEND 3-3-0-0 s=3,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=ok:1
                TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=ok:1
                TSP:MSG:SEND 3-3-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=ok:1
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:39
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:76
                So far so good!
                Next I shutdown the gateway to simulate a lost connection:
                !TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=fail:1
                !TSP:MSG:SEND 3-3-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,ft=1,st=fail:1
                !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=2,st=fail:74
                !TSP:MSG:SEND 3-3-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=3,st=fail:32.00
                !TSP:MSG:SEND 3-3-0-0 s=2,c=1,t=24,pt=3,l=2,sg=0,ft=4,st=fail:0
                !TSP:MSG:SEND 3-3-0-0 s=3,c=1,t=2,pt=1,l=1,sg=0,ft=5,st=fail:1
                !TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,ft=6,st=fail:1
                !TSP:MSG:SEND 3-3-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,ft=7,st=fail:1
                !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=8,st=fail:72
                Its still doing what I expect it to do. It begins attempting to reconnect:
                !TSM:UPL FAIL, SNP
                TSM:FPAR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                Fixing Transport Layer
                TSM:FPAR
                TSM:FPAR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                Still working as intended. Next I start the gateway back up to see if it will reconnect. Here is where I have problems.
                TSM:FPAR
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=3)
                TSM:UPL
                !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                TSP:CHKUPL:FAIL (hops=255)
                !TSM:UPL:FAIL
                TSM:FPAR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                TSM:FPAR
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=3)
                TSM:UPL
                !TSM:UPL:FAIL
                TSM:FPAR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                It looks like the first few messages to initialize the reconnect go through okay and then it misses everything afterwards. If I reset the node it will connect again with no problems.
                What do you think might be happening here?
                • ysinhY
                  ysinhY
                  ysinh
                  A tiny hint for the users of domoticz :
                  ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB20
                  make
                  :) i hope this helps
                  then in the hardware setup
                  MySensors Gateway USB
                  serial port: /dev/ttyUSB20
                  carlylerC 1 Reply Last reply
                  • G
                    G
                    gvorster
                    I'm a bit confused about gateway and controller. Can I use a Pi as both gateway and controller?
                      Yes!
                      • jerseyguy1996J
                        jerseyguy1996J
                        jerseyguy1996
                        I'm using the virtual serial port option and one of the things that I notice is that the port gets created where the tty group only has write access.
                        pi@raspberrypi:/dev/pts $ ls -l
                        total 0
                        crw--w---- 1 root tty  136, 0 Oct 10 18:49 0
                        I can change it manually but if I reboot the raspberry pi it goes back to write access only. How do I get it to be created with 'rw' access?
                        • jerseyguy1996J
                          jerseyguy1996J
                          jerseyguy1996
                          Nevermind....When I set "--my-serial-groupname=tty" in ./configure it works.
                          • NiklasON
                            NiklasON
                            NiklasO
                            Where do I put the security stuff for the signing?
                            • NiklasON NiklasO
                              GertSandersG
                              GertSandersG
                              GertSanders
                              #32
                              @NiklasO
                              Signing is not yet supported in the current Raspi Gateway.
                              NiklasON 1 Reply Last reply
                              • GertSandersG GertSanders
                                @NiklasO
                                NiklasON
                                NiklasON
                                NiklasO
                                wrote on last edited by NiklasO
                                #33
                                @GertSanders said:
                                @NiklasO
                                Ok, thanks.
                                I now see that in this thread. Did not see the earlier discussion in the comments on the main page. Hope to see support soon.
                                I have disabled signing for the time being but I want it on ofc. ;)
                                • b0rmannB
                                  b0rmannB
                                  b0rmann
                                  what's about RS485 transport on raspberry pi? especially from wired RS485 mysensors network to MQTT
                                  • R
                                    R
                                    raulandresmoch
                                    Can you use the RP as gateway and also as controller?
                                    • R raulandresmoch
                                      NiklasON
                                      NiklasON
                                      NiklasO
                                      #36
                                      @raulandresmoch
                                      Sure. I use this with Domoticz on my Pi.
                                      "MySensors Gateway with LAN interface" as hardware pointing to 127.0.0.1:5003
                                      Also, I can connect with other controller software like MYSController from my other computers to my Pi-IP at port 5003.
                                      • b0rmannB b0rmann
                                        marceloaqno
                                        Code Contributor
                                        @b0rmann I could add support for RS485, but I'll need your help to test because I don't have the hardware.
                                        b0rmannB 1 Reply Last reply
                                        • DrJeffD
                                          DrJeffD
                                          DrJeff
                                          The line above
                                          ./examples_linux/mysGatewaymsyGateway -h
                                          needs to be corrected to
                                          ./examples_linux/mysGateway -h
                                          Thanks for all the hard work! Awesome!
