  2. Announcements
  • M marceloaqno
    @jerseyguy1996 It's probaly related to this: https://www.mysensors.org/build/raspberry#improving-throughput-for-nrf24
    jerseyguy1996J
    jerseyguy1996J
    jerseyguy1996
    wrote on last edited by jerseyguy1996
    #25
    @marceloaqno Oh that makes sense :-) I'm wondering if that is also what is causing my problem with reconnecting when the node loses contact with the gateway. The node connects perfectly when the gateway is running but if it loses the connection for any reason it can't seem to be able to reconnect and just goes into a loop of attempts. Here is the debug info from the node:
    This is the initialization output
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=3)
    TSM:FPAR
    TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-3 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=3)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-3 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
    TSP:MSG:SEND 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
    TSP:MSG:READ 0-0-3 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=ok:Sensor Node
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
    TSP:MSG:SEND 3-3-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 3-3-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 3-3-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 3-3-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 3-3-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    Request registration...
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
    TSP:MSG:READ 0-0-3 s=255,c=3,t=27,pt=1,l=1,sg=0:1
    Node registration=1
    Init complete, id=3, parent=0, distance=1, registration=1
    TSP:MSG:SEND 3-3-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:32.00
    TSP:MSG:SEND 3-3-0-0 s=2,c=1,t=24,pt=3,l=2,sg=0,ft=0,st=ok:0
    TSP:MSG:SEND 3-3-0-0 s=3,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:SEND 3-3-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:39
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:76
    So far so good!
    Next I shutdown the gateway to simulate a lost connection:
    !TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=fail:1
    !TSP:MSG:SEND 3-3-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,ft=1,st=fail:1
    !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=2,st=fail:74
    !TSP:MSG:SEND 3-3-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=3,st=fail:32.00
    !TSP:MSG:SEND 3-3-0-0 s=2,c=1,t=24,pt=3,l=2,sg=0,ft=4,st=fail:0
    !TSP:MSG:SEND 3-3-0-0 s=3,c=1,t=2,pt=1,l=1,sg=0,ft=5,st=fail:1
    !TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,ft=6,st=fail:1
    !TSP:MSG:SEND 3-3-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,ft=7,st=fail:1
    !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=8,st=fail:72
    Its still doing what I expect it to do. It begins attempting to reconnect:
    !TSM:UPL FAIL, SNP
    TSM:FPAR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    Fixing Transport Layer
    TSM:FPAR
    TSM:FPAR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    Still working as intended. Next I start the gateway back up to see if it will reconnect. Here is where I have problems.
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=3)
    TSM:UPL
    !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    TSM:FPAR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=3)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    It looks like the first few messages to initialize the reconnect go through okay and then it misses everything afterwards. If I reset the node it will connect again with no problems.
    What do you think might be happening here?
    • ysinhY
      ysinhY
      ysinh
      A tiny hint for the users of domoticz :
      ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB20
      make
      :) i hope this helps
      then in the hardware setup
      MySensors Gateway USB
      serial port: /dev/ttyUSB20
      carlylerC 1 Reply Last reply
      • G
        G
        gvorster
        I'm a bit confused about gateway and controller. Can I use a Pi as both gateway and controller?
          Yes!
          • jerseyguy1996J
            jerseyguy1996J
            jerseyguy1996
            I'm using the virtual serial port option and one of the things that I notice is that the port gets created where the tty group only has write access.
            pi@raspberrypi:/dev/pts $ ls -l
            total 0
            crw--w---- 1 root tty  136, 0 Oct 10 18:49 0
            I can change it manually but if I reboot the raspberry pi it goes back to write access only. How do I get it to be created with 'rw' access?
            • jerseyguy1996J
              jerseyguy1996J
              jerseyguy1996
              Nevermind....When I set "--my-serial-groupname=tty" in ./configure it works.
              • NiklasON
                NiklasON
                NiklasO
                Where do I put the security stuff for the signing?
                • NiklasON NiklasO
                  GertSandersG
                  GertSandersG
                  GertSanders
                  #32
                  @NiklasO
                  Signing is not yet supported in the current Raspi Gateway.
                  NiklasON 1 Reply Last reply
                  • GertSandersG GertSanders
                    @NiklasO
                    NiklasON
                    NiklasON
                    NiklasO
                    wrote on last edited by NiklasO
                    #33
                    @GertSanders said:
                    @NiklasO
                    Ok, thanks.
                    I now see that in this thread. Did not see the earlier discussion in the comments on the main page. Hope to see support soon.
                    I have disabled signing for the time being but I want it on ofc. ;)
                    • b0rmannB
                      b0rmannB
                      b0rmann
                      what's about RS485 transport on raspberry pi? especially from wired RS485 mysensors network to MQTT
                      • R
                        R
                        raulandresmoch
                        Can you use the RP as gateway and also as controller?
                        • R raulandresmoch
                          NiklasON
                          NiklasON
                          NiklasO
                          #36
                          @raulandresmoch
                          Sure. I use this with Domoticz on my Pi.
                          "MySensors Gateway with LAN interface" as hardware pointing to 127.0.0.1:5003
                          Also, I can connect with other controller software like MYSController from my other computers to my Pi-IP at port 5003.
                          • b0rmannB b0rmann
                            marceloaqno
                            Code Contributor
                            @b0rmann I could add support for RS485, but I'll need your help to test because I don't have the hardware.
                            b0rmannB 1 Reply Last reply
                            • DrJeffD
                              DrJeffD
                              DrJeff
                              The line above
                              ./examples_linux/mysGatewaymsyGateway -h
                              needs to be corrected to
                              ./examples_linux/mysGateway -h
                              Thanks for all the hard work! Awesome!
                              • DrJeffD DrJeff
                                The line above
                                @DrJeff Thanks for noticing. It should be fixed now.
                                • M marceloaqno
                                  b0rmannB
                                  b0rmannB
                                  b0rmann
                                  @marceloaqno
                                  i am ready. after compiled and upload example node sketch i have on rs485 to usb convertor (/dev/ttyUSB0) output nice mysensors data:
                                  01 FF 00 58 07 02 FF FF - FF 02 03 07 FF 03 66 04
                                  testing playground photo: 0_1476563966730_playground.jpg
                                    mvader
                                    wrote on last edited by mvader
                                    #41
                                    I noticed the "improve rf24" section was added. and it mentioned high cpu.
                                    i set mine up a few weeks ago and am not using an interrupt on my radio.
                                    my cpu is only 2-3%
                                    I'm curious if the high cpu problem is seen by many?
                                    also a 2nd question.
                                    if i were to add an interrupt. how can i "re-configure" my setup to include that new -switch
                                    or do i have to remove everything and re-clone from git hub and start over?
                                    • shfgS
                                      shfgS
                                      shfg
                                      Thanks for this excellent port. I'm having an issue running it as an MQTT gateway on the RPi (Model A). It compiles without hassles, but cant make a successful MQTT connection. I get the following:
                                      mysGateway: Starting gateway...
                                      mysGateway: Protocol version - 2.0.1-beta
                                      mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                                      mysGateway: TSF:LRT:OK
                                      mysGateway: TSM:INIT
                                      mysGateway: TSM:INIT:TSP OK
                                      mysGateway: TSM:INIT:GW MODE
                                      mysGateway: TSM:READY
                                      mysGateway: MCO:REG:NOT NEEDED
                                      mysGateway: MCO:BGN:STP
                                      mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                      mysGateway: Attempting MQTT connection...
                                      mysGateway: connected to 127.0.0.1
                                      ... those attempts recurring every 15 seconds or so, and in that time, no other activity is processed.
                                      From the code, I would have expected 'MQTT connected' rather than 'connected to 127.0.0.1'?
                                      I have mosquitto running on the pi in this case - which is working perfectly in other tests. Both serial and ethernet gateway modes compile and run perfectly, only the mqtt mode not working.
                                      Has anyone else had a similar issue?
                                      • E
                                        E
                                        ericvdb
                                        @marceloaqno what about gpio interrupts, is that supported?
                                        I'm thinking to use a RPi as a pulse counter for water, electricity and gas with no radio, just ethernet or mqtt.
                                        In combination with a I2C display, this could be a nice project ;)
                                        Greetz,
                                        Eric
                                        • Christian SimonsenC
                                          Christian SimonsenC
                                          Christian Simonsen
                                          I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. And I have followed the steps under "install and build", which seem to have worked fine. I didn't make any changes to the conf file. However now Im stuck. How do I setup the Raspberry Pi with the NRF24L01+ as a gateway in the MyController Gateway setup page in Safari?
