  2. Announcements
  • ysinhY
    ysinhY
    ysinh
    A tiny hint for the users of domoticz :
    ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB20
    make
    :) i hope this helps
    then in the hardware setup
    MySensors Gateway USB
    serial port: /dev/ttyUSB20
    carlylerC 1 Reply Last reply
    • G
      G
      gvorster
      I'm a bit confused about gateway and controller. Can I use a Pi as both gateway and controller?
        Yes!
        • jerseyguy1996J
          jerseyguy1996J
          jerseyguy1996
          I'm using the virtual serial port option and one of the things that I notice is that the port gets created where the tty group only has write access.
          pi@raspberrypi:/dev/pts $ ls -l
          total 0
          crw--w---- 1 root tty  136, 0 Oct 10 18:49 0
          I can change it manually but if I reboot the raspberry pi it goes back to write access only. How do I get it to be created with 'rw' access?
          • jerseyguy1996J
            jerseyguy1996J
            jerseyguy1996
            Nevermind....When I set "--my-serial-groupname=tty" in ./configure it works.
            • NiklasON
              NiklasON
              NiklasO
              Where do I put the security stuff for the signing?
              • NiklasON NiklasO
                GertSandersG
                GertSandersG
                GertSanders
                #32
                @NiklasO
                Signing is not yet supported in the current Raspi Gateway.
                NiklasON 1 Reply Last reply
                • GertSandersG GertSanders
                  @NiklasO
                  NiklasON
                  NiklasON
                  NiklasO
                  wrote on last edited by NiklasO
                  #33
                  @GertSanders said:
                  @NiklasO
                  Ok, thanks.
                  I now see that in this thread. Did not see the earlier discussion in the comments on the main page. Hope to see support soon.
                  I have disabled signing for the time being but I want it on ofc. ;)
                  • b0rmannB
                    b0rmannB
                    b0rmann
                    what's about RS485 transport on raspberry pi? especially from wired RS485 mysensors network to MQTT
                    • R
                      R
                      raulandresmoch
                      Can you use the RP as gateway and also as controller?
                      • R raulandresmoch
                        NiklasON
                        NiklasON
                        NiklasO
                        #36
                        @raulandresmoch
                        Sure. I use this with Domoticz on my Pi.
                        "MySensors Gateway with LAN interface" as hardware pointing to 127.0.0.1:5003
                        Also, I can connect with other controller software like MYSController from my other computers to my Pi-IP at port 5003.
                        • b0rmannB b0rmann
                          marceloaqno
                          Code Contributor
                          @b0rmann I could add support for RS485, but I'll need your help to test because I don't have the hardware.
                          b0rmannB 1 Reply Last reply
                          • DrJeffD
                            DrJeffD
                            DrJeff
                            The line above
                            ./examples_linux/mysGatewaymsyGateway -h
                            needs to be corrected to
                            ./examples_linux/mysGateway -h
                            Thanks for all the hard work! Awesome!
                            • DrJeffD DrJeff
                              The line above
                              @DrJeff Thanks for noticing. It should be fixed now.
                              • M marceloaqno
                                b0rmannB
                                b0rmannB
                                b0rmann
                                @marceloaqno
                                i am ready. after compiled and upload example node sketch i have on rs485 to usb convertor (/dev/ttyUSB0) output nice mysensors data:
                                01 FF 00 58 07 02 FF FF - FF 02 03 07 FF 03 66 04
                                testing playground photo: 0_1476563966730_playground.jpg
                                  mvader
                                  wrote on last edited by mvader
                                  #41
                                  I noticed the "improve rf24" section was added. and it mentioned high cpu.
                                  i set mine up a few weeks ago and am not using an interrupt on my radio.
                                  my cpu is only 2-3%
                                  I'm curious if the high cpu problem is seen by many?
                                  also a 2nd question.
                                  if i were to add an interrupt. how can i "re-configure" my setup to include that new -switch
                                  or do i have to remove everything and re-clone from git hub and start over?
                                  • shfgS
                                    shfgS
                                    shfg
                                    Thanks for this excellent port. I'm having an issue running it as an MQTT gateway on the RPi (Model A). It compiles without hassles, but cant make a successful MQTT connection. I get the following:
                                    mysGateway: Starting gateway...
                                    mysGateway: Protocol version - 2.0.1-beta
                                    mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                                    mysGateway: TSF:LRT:OK
                                    mysGateway: TSM:INIT
                                    mysGateway: TSM:INIT:TSP OK
                                    mysGateway: TSM:INIT:GW MODE
                                    mysGateway: TSM:READY
                                    mysGateway: MCO:REG:NOT NEEDED
                                    mysGateway: MCO:BGN:STP
                                    mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                    mysGateway: Attempting MQTT connection...
                                    mysGateway: connected to 127.0.0.1
                                    ... those attempts recurring every 15 seconds or so, and in that time, no other activity is processed.
                                    From the code, I would have expected 'MQTT connected' rather than 'connected to 127.0.0.1'?
                                    I have mosquitto running on the pi in this case - which is working perfectly in other tests. Both serial and ethernet gateway modes compile and run perfectly, only the mqtt mode not working.
                                    Has anyone else had a similar issue?
                                    • E
                                      E
                                      ericvdb
                                      @marceloaqno what about gpio interrupts, is that supported?
                                      I'm thinking to use a RPi as a pulse counter for water, electricity and gas with no radio, just ethernet or mqtt.
                                      In combination with a I2C display, this could be a nice project ;)
                                      Greetz,
                                      Eric
                                      • Christian SimonsenC
                                        Christian SimonsenC
                                        Christian Simonsen
                                        I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. And I have followed the steps under "install and build", which seem to have worked fine. I didn't make any changes to the conf file. However now Im stuck. How do I setup the Raspberry Pi with the NRF24L01+ as a gateway in the MyController Gateway setup page in Safari?
                                        • shfgS shfg
                                          marceloaqno
                                          Code Contributor
                                          wrote on last edited by marceloaqno
                                          #45
                                          @shfg There were some reports about this problem in the past, do you see any error messages in your mosquitto log?
                                          @ericvdb yes, you can attach a function to handle an interruption like this:
                                          uint8_t mode = FALLING;	// Valid options are: CHANGE, FALLING, RISING
                                          uint8_t physPin = 16;	// Choose a pin that fits your needs
                                          void irqHandler(void)
                                          	// Process the interrupt
                                          	attachInterrupt(physPin, irqHandler, mode);
                                          Support for I2C was added in the latest version.
                                          shfgS 2 Replies Last reply
