  3. Which Arduino IDE version?
31 Posts 12 Posters 14.9k Views 12 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    Crash still happens using the latest version, downgraded to 1.6.11 :(
    petewillP 1 Reply Last reply
    • Mark SwiftM Mark Swift
      petewillP
      petewillP
      petewill
      @Mark-Swift I'm using IDE 1.6.12 and board defs 1.6.14 and my Ethernet gateway has been running for almost a week with no apparent issues. How often are you seeing the crash?
      • Mark SwiftM
        Mark SwiftM
        Mark Swift
        My W5100 will not start with 1.6.14, it just reboots after getting an IP...
          petewillP
          petewillP
          petewill
          @Mark-Swift Wow, that's strange. What Ethernet library are you using? I'm on 1.1.2.
          • Mark SwiftM
            Mark SwiftM
            Mark Swift
            @petewill same! :-(
            I will try it again when I find a moment, I was using DCHP, are you?
              @petewill same! :-(
              petewillP
              petewillP
              petewill
              @Mark-Swift No, I'm using a static IP.
              • Mark SwiftM
                Mark SwiftM
                Mark Swift
                wrote on last edited by Mark Swift
                #25
                An example of what my gateway does with 1.6.14
                )<�a���dv)�0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.0.1-beta
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSM:INIT:TSP OK
                0;255;3;0;9;TSM:INIT:GW MODE
                0;255;3;0;9;TSM:READY
                IP: 192.168.1.43
                0;255;3;0;9;MCO:BGN:STP
                0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                0;255;3;0;9;TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;TSF:MSG:BC
                0;255;3;0;9;TSF:MSG:FPAR REQ,ID=3
                0;255;3;0;9;TSF:CKU:OK,FCTRL
                0;255;3;0;9;TSF:MSG:GWL OK
                0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;TSF:MSG:READ,3-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                0;255;3;0;9;TSF:MSG:PINGED,ID=3,HP=1
                0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:20.9
                IP: 192.168.1.43
                0;255;3;0;9;TSF:MSG:READ,1-1-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                IP: 192.168.1.43
                0;255;3;0;9;TSF:MSG:READ,3-3-0,s=1,c=1,t=16,pt=2,l=2,sg=0:1
                IP: 192.168.1.43
                0;255;3;0;9;TSF:MSG:READ,3-3-0,s=3,c=1,t=16,pt=2,l=2,sg=0:1
                IP: 192.168.1.43
                0;255;3;0;9;TSF:MSG:READ,3-3-0,s=10,c=1,t=16,pt=1,l=1,sg=0:0
                IP: 192.168.1.43
                IP: 192.168.1.43
                IP: 192.168.1.43
                  IP: 192.168.1.43
                  IP: 192.168.1.43
                  IP: 192.168.1.43
                  IP: 192.168.1.43
                  IP: 192.168.1.43
                  IP: 192.168.1.43
                  IP: 192.168.1.43
                  IP: 192.168.1.43
                  petewillP
                  petewillP
                  petewill
                  @Mark-Swift Strange. You're sure all the connections are correct? Are you trying to connect multiple devices to the gateway? Do you have two devices with the same MAC address? I didn't do much beyond the stock code. I am using the LEDs and inclusion mode with an NRF radio using softspi.
                  Mark SwiftM YveauxY 2 Replies Last reply
                  • petewillP petewill
                    Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    @petewill I will need to check the connections, but it works once I roll back, so doubt it's connections? Just one controller, I disable the second one while testing. MAC address is unique, and the same in each sketch. It's baffling!
                      @petewill not everybody seems to experience the crashes. My gw is also running fine...
                      But it's a fact the board defs cause the issue ; it's confirmed by arduino and fixed in the compiler but it will probably take a while to make it into the official release.
                      Until then, if you experience reboots then downgrade the board defs.
                      • YveauxY Yveaux
                        petewillP
                        petewillP
                        petewill
                        @Yveaux Strange. Good to know though. :thumbsup: Thanks.
                        • cmrockwellC
                          cmrockwellC
                          cmrockwell
                          I am a relatively new user to MySensors, and I think a bug such as this needs to be described on the main page on how to build an Ethernet Gateway. This problem caused me a lot of frustation, and I don't know enough about how the hardware works to even realize that my gateway was being reset every 2 seconds. Anyone trying to build a W5100 ethernet gateway with a fresh Arduino install is going to experience this bug, and I think it will reflect poorly on the whole MySensors project if this bug is not highlighted on the build page.
                          The biggest benefit of the MySensors project is that getting up and running is relatively easy, but bugs such as this definitely make it harder.
                          • H
                            H
                            hoggin
                            I completely agree. I am having a hell of a time getting mine to work at its to the point where I'm searching for an alternative to mysensors. This post should be in the main page regarding setup. I have wasted hours trying to figure this out.
