  3. Which Arduino IDE version?
31 Posts 12 Posters 14.9k Views 12 Watching
  • tekkaT tekka
    @TheoL Maybe important for your MySensors tutorial: I suggest using Arduino IDE 1.6.11 with AVR board defs 1.6.11 (1.6.12 and 1.6.13 seem buggy, at least regarding the Ethernet lib)
    sundberg84S
    sundberg84S
    @tekka - If i want to build myself a ethernet gw with 2.0 it should work if i download and use IDE < 1.6.12 ?
    tekkaT 1 Reply Last reply
    • sundberg84S sundberg84
      tekkaT
      tekkaT
      tekka
      @sundberg84 Not IDE, but AVR board defs 1.6.11
      • tlpeterT
        tlpeterT
        tlpeter
        And how do i downgrade AVR board devs?
        • AndurilA
          AndurilA
          Anduril
          in your IDE go to tools -> boards: "..." -> board manager and there select Arduino AVR board in the correct version.
          • tlpeterT
            tlpeterT
            tlpeter
            Thanks, i would not have found that by myself :smile:
            • petewillP
              petewillP
              petewill
              It has been a long time since I've updated my IDE (currently running 1.6.6) and I wanted to update before I start converting everything to MySensors 2.0. I noticed that there is a newer version 1.6.12 and the bug reported above appears to have been fixed. Has anyone used the newest IDE and boards files? I will be using an Ethernet gateway but I'm not sure if it is still best to downgrade the boards files. Thanks!
              • Mark SwiftM
                Mark SwiftM
                Mark Swift
                Crash still happens using the latest version, downgraded to 1.6.11 :(
                petewillP 1 Reply Last reply
                • Mark SwiftM Mark Swift
                  petewillP
                  petewillP
                  petewill
                  @Mark-Swift I'm using IDE 1.6.12 and board defs 1.6.14 and my Ethernet gateway has been running for almost a week with no apparent issues. How often are you seeing the crash?
                  • Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    My W5100 will not start with 1.6.14, it just reboots after getting an IP...
                      petewillP
                      petewillP
                      petewill
                      @Mark-Swift Wow, that's strange. What Ethernet library are you using? I'm on 1.1.2.
                      • Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        @petewill same! :-(
                        I will try it again when I find a moment, I was using DCHP, are you?
                          @petewill same! :-(
                          petewillP
                          petewillP
                          petewill
                          @Mark-Swift No, I'm using a static IP.
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            wrote on last edited by Mark Swift
                            #25
                            An example of what my gateway does with 1.6.14
                            )<�a���dv)�0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.0.1-beta
                            0;255;3;0;9;TSM:INIT
                            0;255;3;0;9;TSM:INIT:TSP OK
                            0;255;3;0;9;TSM:INIT:GW MODE
                            0;255;3;0;9;TSM:READY
                            IP: 192.168.1.43
                            0;255;3;0;9;MCO:BGN:STP
                            0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                            0;255;3;0;9;TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                            0;255;3;0;9;TSF:MSG:BC
                            0;255;3;0;9;TSF:MSG:FPAR REQ,ID=3
                            0;255;3;0;9;TSF:CKU:OK,FCTRL
                            0;255;3;0;9;TSF:MSG:GWL OK
                            0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                            0;255;3;0;9;TSF:MSG:READ,3-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                            0;255;3;0;9;TSF:MSG:PINGED,ID=3,HP=1
                            0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:20.9
                            IP: 192.168.1.43
                            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                            IP: 192.168.1.43
                            0;255;3;0;9;TSF:MSG:READ,3-3-0,s=1,c=1,t=16,pt=2,l=2,sg=0:1
                            IP: 192.168.1.43
                            0;255;3;0;9;TSF:MSG:READ,3-3-0,s=3,c=1,t=16,pt=2,l=2,sg=0:1
                            IP: 192.168.1.43
                            0;255;3;0;9;TSF:MSG:READ,3-3-0,s=10,c=1,t=16,pt=1,l=1,sg=0:0
                            IP: 192.168.1.43
                            IP: 192.168.1.43
                            IP: 192.168.1.43
                              IP: 192.168.1.43
                              IP: 192.168.1.43
                              IP: 192.168.1.43
                              IP: 192.168.1.43
                              IP: 192.168.1.43
                              IP: 192.168.1.43
                              IP: 192.168.1.43
                              IP: 192.168.1.43
                              petewillP
                              petewillP
                              petewill
                              @Mark-Swift Strange. You're sure all the connections are correct? Are you trying to connect multiple devices to the gateway? Do you have two devices with the same MAC address? I didn't do much beyond the stock code. I am using the LEDs and inclusion mode with an NRF radio using softspi.
                              Mark SwiftM YveauxY 2 Replies Last reply
                              • petewillP petewill
                                Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                @petewill I will need to check the connections, but it works once I roll back, so doubt it's connections? Just one controller, I disable the second one while testing. MAC address is unique, and the same in each sketch. It's baffling!
                                  @petewill not everybody seems to experience the crashes. My gw is also running fine...
                                  But it's a fact the board defs cause the issue ; it's confirmed by arduino and fixed in the compiler but it will probably take a while to make it into the official release.
                                  Until then, if you experience reboots then downgrade the board defs.
                                  • YveauxY Yveaux
                                    petewillP
                                    petewillP
                                    petewill
                                    @Yveaux Strange. Good to know though. :thumbsup: Thanks.
                                    • cmrockwellC
                                      cmrockwellC
                                      cmrockwell
                                      I am a relatively new user to MySensors, and I think a bug such as this needs to be described on the main page on how to build an Ethernet Gateway. This problem caused me a lot of frustation, and I don't know enough about how the hardware works to even realize that my gateway was being reset every 2 seconds. Anyone trying to build a W5100 ethernet gateway with a fresh Arduino install is going to experience this bug, and I think it will reflect poorly on the whole MySensors project if this bug is not highlighted on the build page.
                                      The biggest benefit of the MySensors project is that getting up and running is relatively easy, but bugs such as this definitely make it harder.
                                      • H
                                        H
                                        hoggin
                                        I completely agree. I am having a hell of a time getting mine to work at its to the point where I'm searching for an alternative to mysensors. This post should be in the main page regarding setup. I have wasted hours trying to figure this out.
