  3. Which Arduino IDE version?
31 Posts 12 Posters 14.9k Views 12 Watching
  • tekkaT tekka
    @sundberg84 Yes, read here for further information related to the compiler bug: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=77326
    TheoLT
    TheoLT
    TheoL
    @tekka Great job. Hopefully they'll soon release a bug fix for this.
    • TheoLT
      TheoLT
      TheoL
      Confirmed that soft SPI also works an a Serial Gateway. Uploaded 2.0 on that one and tested with 1.5 sketch.
      tekkaT 1 Reply Last reply
      • TheoLT TheoL
        tekkaT
        tekkaT
        tekka
        @TheoL Maybe important for your MySensors tutorial: I suggest using Arduino IDE 1.6.11 with AVR board defs 1.6.11 (1.6.12 and 1.6.13 seem buggy, at least regarding the Ethernet lib)
        • tekkaT tekka
          sundberg84S
          sundberg84S
          @tekka - If i want to build myself a ethernet gw with 2.0 it should work if i download and use IDE < 1.6.12 ?
          • sundberg84S sundberg84
            tekkaT
            tekkaT
            tekka
            @sundberg84 Not IDE, but AVR board defs 1.6.11
            • tlpeterT
              tlpeterT
              tlpeter
              And how do i downgrade AVR board devs?
              • AndurilA
                AndurilA
                Anduril
                in your IDE go to tools -> boards: "..." -> board manager and there select Arduino AVR board in the correct version.
                • tlpeterT
                  tlpeterT
                  tlpeter
                  Thanks, i would not have found that by myself :smile:
                  • petewillP
                    petewillP
                    petewill
                    It has been a long time since I've updated my IDE (currently running 1.6.6) and I wanted to update before I start converting everything to MySensors 2.0. I noticed that there is a newer version 1.6.12 and the bug reported above appears to have been fixed. Has anyone used the newest IDE and boards files? I will be using an Ethernet gateway but I'm not sure if it is still best to downgrade the boards files. Thanks!
                    • Mark SwiftM
                      Mark SwiftM
                      Mark Swift
                      Crash still happens using the latest version, downgraded to 1.6.11 :(
                      petewillP 1 Reply Last reply
                      • Mark SwiftM Mark Swift
                        petewillP
                        petewillP
                        petewill
                        @Mark-Swift I'm using IDE 1.6.12 and board defs 1.6.14 and my Ethernet gateway has been running for almost a week with no apparent issues. How often are you seeing the crash?
                        • Mark SwiftM
                          Mark SwiftM
                          Mark Swift
                          My W5100 will not start with 1.6.14, it just reboots after getting an IP...
                            petewillP
                            petewillP
                            petewill
                            @Mark-Swift Wow, that's strange. What Ethernet library are you using? I'm on 1.1.2.
                            • Mark SwiftM
                              Mark SwiftM
                              Mark Swift
                              @petewill same! :-(
                              I will try it again when I find a moment, I was using DCHP, are you?
                                @petewill same! :-(
                                petewillP
                                petewillP
                                petewill
                                @Mark-Swift No, I'm using a static IP.
                                • Mark SwiftM
                                  Mark SwiftM
                                  Mark Swift
                                  wrote on last edited by Mark Swift
                                  #25
                                  An example of what my gateway does with 1.6.14
                                  )<�a���dv)�0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.0.1-beta
                                  0;255;3;0;9;TSM:INIT
                                  0;255;3;0;9;TSM:INIT:TSP OK
                                  0;255;3;0;9;TSM:INIT:GW MODE
                                  0;255;3;0;9;TSM:READY
                                  IP: 192.168.1.43
                                  0;255;3;0;9;MCO:BGN:STP
                                  0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                  0;255;3;0;9;TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  0;255;3;0;9;TSF:MSG:BC
                                  0;255;3;0;9;TSF:MSG:FPAR REQ,ID=3
                                  0;255;3;0;9;TSF:CKU:OK,FCTRL
                                  0;255;3;0;9;TSF:MSG:GWL OK
                                  0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  0;255;3;0;9;TSF:MSG:READ,3-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                  0;255;3;0;9;TSF:MSG:PINGED,ID=3,HP=1
                                  0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:20.9
                                  IP: 192.168.1.43
                                  0;255;3;0;9;TSF:MSG:READ,1-1-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                  IP: 192.168.1.43
                                  0;255;3;0;9;TSF:MSG:READ,3-3-0,s=1,c=1,t=16,pt=2,l=2,sg=0:1
                                  IP: 192.168.1.43
                                  0;255;3;0;9;TSF:MSG:READ,3-3-0,s=3,c=1,t=16,pt=2,l=2,sg=0:1
                                  IP: 192.168.1.43
                                  0;255;3;0;9;TSF:MSG:READ,3-3-0,s=10,c=1,t=16,pt=1,l=1,sg=0:0
                                  IP: 192.168.1.43
                                  IP: 192.168.1.43
                                  IP: 192.168.1.43
                                    IP: 192.168.1.43
                                    IP: 192.168.1.43
                                    IP: 192.168.1.43
                                    IP: 192.168.1.43
                                    IP: 192.168.1.43
                                    IP: 192.168.1.43
                                    IP: 192.168.1.43
                                    IP: 192.168.1.43
                                    petewillP
                                    petewillP
                                    petewill
                                    @Mark-Swift Strange. You're sure all the connections are correct? Are you trying to connect multiple devices to the gateway? Do you have two devices with the same MAC address? I didn't do much beyond the stock code. I am using the LEDs and inclusion mode with an NRF radio using softspi.
                                    Mark SwiftM YveauxY 2 Replies Last reply
                                    • petewillP petewill
                                      Mark SwiftM
                                      Mark SwiftM
                                      Mark Swift
                                      @petewill I will need to check the connections, but it works once I roll back, so doubt it's connections? Just one controller, I disable the second one while testing. MAC address is unique, and the same in each sketch. It's baffling!
                                        @petewill not everybody seems to experience the crashes. My gw is also running fine...
                                        But it's a fact the board defs cause the issue ; it's confirmed by arduino and fixed in the compiler but it will probably take a while to make it into the official release.
                                        Until then, if you experience reboots then downgrade the board defs.
                                        • YveauxY Yveaux
                                          petewillP
                                          petewillP
                                          petewill
                                          @Yveaux Strange. Good to know though. :thumbsup: Thanks.
