  2. Announcements
  • E
    E
    ericvdb
    @marceloaqno what about gpio interrupts, is that supported?
    I'm thinking to use a RPi as a pulse counter for water, electricity and gas with no radio, just ethernet or mqtt.
    In combination with a I2C display, this could be a nice project ;)
    Greetz,
    Eric
    • Christian SimonsenC
      Christian SimonsenC
      Christian Simonsen
      I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. And I have followed the steps under "install and build", which seem to have worked fine. I didn't make any changes to the conf file. However now Im stuck. How do I setup the Raspberry Pi with the NRF24L01+ as a gateway in the MyController Gateway setup page in Safari?
      • shfgS shfg
        Thanks for this excellent port. I'm having an issue running it as an MQTT gateway on the RPi (Model A). It compiles without hassles, but cant make a successful MQTT connection. I get the following:
        mysGateway: Starting gateway...
        mysGateway: Protocol version - 2.0.1-beta
        mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
        mysGateway: TSF:LRT:OK
        mysGateway: TSM:INIT
        mysGateway: TSM:INIT:TSP OK
        mysGateway: TSM:INIT:GW MODE
        mysGateway: TSM:READY
        mysGateway: MCO:REG:NOT NEEDED
        mysGateway: MCO:BGN:STP
        mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
        mysGateway: Attempting MQTT connection...
        mysGateway: connected to 127.0.0.1
        ... those attempts recurring every 15 seconds or so, and in that time, no other activity is processed.
        From the code, I would have expected 'MQTT connected' rather than 'connected to 127.0.0.1'?
        I have mosquitto running on the pi in this case - which is working perfectly in other tests. Both serial and ethernet gateway modes compile and run perfectly, only the mqtt mode not working.
        Has anyone else had a similar issue?
        marceloaqno
        Code Contributor
        wrote on last edited by marceloaqno
        #45
        @shfg There were some reports about this problem in the past, do you see any error messages in your mosquitto log?
        @ericvdb yes, you can attach a function to handle an interruption like this:
        uint8_t mode = FALLING;	// Valid options are: CHANGE, FALLING, RISING
        uint8_t physPin = 16;	// Choose a pin that fits your needs
        void irqHandler(void)
        	// Process the interrupt
        	attachInterrupt(physPin, irqHandler, mode);
        Support for I2C was added in the latest version.
        shfgS 2 Replies Last reply
        • Christian SimonsenC Christian Simonsen
          marceloaqno
          Code Contributor
          @Christian-Simonsen If you are using the default build options for the RPi gateway, in MyController (Resources -> Add gateway) choose Ethernet for the type and enter your RPi ip address in the Host name field.
          Christian SimonsenC 1 Reply Last reply
          • T
            Toyman
            Is it compatible with pre-2.0 versions eg 1.5?
            • M marceloaqno
              Christian SimonsenC
              Christian SimonsenC
              Christian Simonsen
              Thanks that did the trick
                Christian SimonsenC
                Christian Simonsen
                wrote on last edited by Christian Simonsen
                #49
                Background: I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. I have also set up the raspberry pi as a gateway in the MyController Gateway setup page in Safari. It found it and it seem to work.
                However to my question. How do I know if the Raspberry Pi gateway with NRF24L01 work? How can I monitor what the Raspberry Pi gateway receive? Is there a similar way as the "Serial Monitor" that I use in the Arduino application, when accessing Arduino Uno via USB?
                If there is I need to monitor this via OSX Terminal.
                jerseyguy1996J 1 Reply Last reply
                • E
                  E
                  ericvdb
                  @marceloaqno
                  Today i tried to use the sketch Water Meter Pulse Sensor in mysGateway.cpp but i run into alot of errors, you have any idea?
                  mysGateway.cpp:
                   * Created by Marcelo Aquino <marceloaqno@gmail.org>
                   * Copyleft (c) 2016, Marcelo Aquino
                  #include <iostream>
                  #include <cstdio>
                  #include <unistd.h>
                  // For more options run ./configure --help
                  // Config file
                  //#define MY_LINUX_CONFIG_FILE "/etc/mysensors.dat"
                  #define MY_GATEWAY_MAX_CLIENTS 10
                  // Serial config
                  // Enable this if you are using an Arduino connected to the USB
                  //#define MY_LINUX_SERIAL_PORT "/dev/ttyACM0"
                  // Enable this if you need to connect to a controller running on the same device
                  //#define MY_IS_SERIAL_PTY
                  // Choose a symlink name for the PTY device
                  //#define MY_LINUX_SERIAL_PTY "/dev/ttyMySensorsGateway"
                  // Grant access to the specified system group for the serial device
                  //#define MY_LINUX_SERIAL_GROUPNAME "tty"
                  // MQTT options
                  //#define MY_PORT 1883
                  //#define MY_MQTT_CLIENT_ID "mysensors-1"
                  //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
                  //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
                  // Flash leds on rx/tx/err
                  //#define MY_DEFAULT_ERR_LED_PIN 12  // Error LED pin
                  //#define MY_DEFAULT_RX_LED_PIN  16  // Receive LED pin
                  //#define MY_DEFAULT_TX_LED_PIN  18  // Transmit LED pin
                  // Inverse the blinking feature
                  #define DIGITAL_INPUT_SENSOR 26                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
                  #define PULSE_FACTOR 1000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
                  #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
                  #define MAX_FLOW 40                             // Max flow (l/min) value to report. This filters outliers.
                  #define CHILD_ID 1                              // Id of the sensor child
                  unsigned long SEND_FREQUENCY = 30000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                  MyMessage flowMsg(CHILD_ID,V_FLOW);
                  MyMessage volumeMsg(CHILD_ID,V_VOLUME);
                  MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
                  double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
                  volatile double flow = 0;
                  bool pcReceived = false;
                  unsigned long oldPulseCount = 0;
                  unsigned long newBlink = 0;
                  double oldflow = 0;
                  double volume =0;
                  double oldvolume =0;
                  unsigned long lastSend =0;
                  unsigned long lastPulse =0;
                  void onPulse()
                    if (!SLEEP_MODE)
                      unsigned long interval = newBlink-lastBlink;
                      if (interval!=0)
                        lastPulse = millis();
                        if (interval<500000L) {
                          // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
                          return;
                        flow = (60000000.0 /interval) / ppl;
                      lastBlink = newBlink;
                    pulseCount++;
                    attachInterrupt(DIGITAL_INPUT_SENSOR, onPulse, FALLING);
                    sendSketchInfo("Water Meter", "1.1");
                    // Register this device as Waterflow sensor
                    present(CHILD_ID, S_WATER);
                    unsigned long currentTime = millis();
                    if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY))
                      lastSend=currentTime;
                      if (!pcReceived) {
                        //Last Pulsecount not yet received from controller, request it again
                        request(CHILD_ID, V_VAR1);
                        return;
                      if (!SLEEP_MODE && flow != oldflow) {
                        oldflow = flow;
                        Serial.print("l/min:");
                        Serial.println(flow);
                        // Check that we dont get unresonable large flow value.
                        if (flow<((unsigned long)MAX_FLOW)) {
                          send(flowMsg.set(flow, 2));                   // Send flow value to gw
                      // No Pulse count received in 2min
                      if(currentTime - lastPulse > 120000){
                        flow = 0;
                      // Pulse count has changed
                      if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
                        oldPulseCount = pulseCount;
                        Serial.print("pulsecount:");
                        Serial.println(pulseCount);
                        send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
                        double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                        if ((volume != oldvolume)||(!SLEEP_MODE)) {
                          oldvolume = volume;
                          Serial.print("volume:");
                          Serial.println(volume, 3);
                          send(volumeMsg.set(volume, 3));               // Send volume value to gw
                    if (SLEEP_MODE) {
                      sleep(SEND_FREQUENCY);
                  ./configure --my-debug=enable --my-gateway=ethernet --my-radio=none --my-port=5003
                  [OK] machine detected: SoC=BCM2835, Type=RPi, CPU=armv6l, REV=000e.
                  [OK] init system detected: systemd
                  [OK] Finished.
                  make:
                  root@raspberrypi:/downloads/MySensors# make
                  cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/log.o drivers/Linux/log.c
                  g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/noniso.o drivers/Linux/noniso.cpp
                  g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Print.o drivers/Linux/Print.cpp
                  g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetClient.o drivers/Linux/EthernetClient.cpp
                  g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SerialPort.o drivers/Linux/SerialPort.cpp
                  g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Stream.o drivers/Linux/Stream.cpp
                  g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/IPAddress.o drivers/Linux/IPAddress.cpp
                  g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/compatibility.o drivers/Linux/compatibility.cpp
                  g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SoftEeprom.o drivers/Linux/SoftEeprom.cpp
                  g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetServer.o drivers/Linux/EthernetServer.cpp
                  g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o examples_linux/mysGateway.o examples_linux/mysGateway.cpp
                  examples_linux/mysGateway.cpp: In function âvoid onPulse()â:
                  examples_linux/mysGateway.cpp:96:37: error: âmicrosâ was not declared in this scope
                  examples_linux/mysGateway.cpp: In function âvoid loop()â:
                  examples_linux/mysGateway.cpp:166:41: error: call of overloaded âset(volatile long unsigned int&)â is ambiguous
                  examples_linux/mysGateway.cpp:166:41: note: candidates are:
                  In file included from ./MySensors.h:319:0,
                                   from examples_linux/mysGateway.cpp:60:
                  ./core/MyMessage.cpp:222:12: note: MyMessage& MyMessage::set(const char*) <near match>
                   MyMessage& MyMessage::set(const char* value) {
                  ./core/MyMessage.cpp:222:12: note:   no known conversion for argument 1 from âvolatile long unsigned intâ to âconst char*â
                  ./core/MyMessage.cpp:234:12: note: MyMessage& MyMessage::set(bool)
                   MyMessage& MyMessage::set(bool value) {
                  ./core/MyMessage.cpp:241:12: note: MyMessage& MyMessage::set(uint8_t)
                   MyMessage& MyMessage::set(uint8_t value) {
                  ./core/MyMessage.cpp:256:12: note: MyMessage& MyMessage::set(uint32_t)
                   MyMessage& MyMessage::set(uint32_t value) {
                  ./core/MyMessage.cpp:263:12: note: MyMessage& MyMessage::set(int32_t)
                   MyMessage& MyMessage::set(int32_t value) {
                  ./core/MyMessage.cpp:270:12: note: MyMessage& MyMessage::set(uint16_t)
                   MyMessage& MyMessage::set(uint16_t value) {
                  ./core/MyMessage.cpp:277:12: note: MyMessage& MyMessage::set(int16_t)
                   MyMessage& MyMessage::set(int16_t value) {
                  examples_linux/mysGateway.cpp:180:25: error: call of overloaded âsleep(long unsigned int&)â is ambiguous
                  examples_linux/mysGateway.cpp:180:25: note: candidates are:
                  In file included from examples_linux/mysGateway.cpp:22:0:
                  /usr/include/unistd.h:444:21: note: unsigned int sleep(unsigned int)
                   extern unsigned int sleep (unsigned int __seconds);
                  In file included from ./MySensors.h:320:0,
                  ./core/MySensorsCore.cpp:543:8: note: int8_t sleep(uint32_t, bool)
                   int8_t sleep(const uint32_t sleepingMS, const bool smartSleep) {
                  Makefile:46: recipe for target 'examples_linux/mysGateway.o' failed
                  make: *** [examples_linux/mysGateway.o] Error 1
                  • E
                    E
                    ericvdb
                    @marceloaqno
                    i was able to get a bit further by replacing all "unsigned long" declarations with "uint"
                    Remains unsolved:
                    examples_linux/mysGateway.cpp:96:28: error: âmicrosâ was not declared in this scope
                         uint newBlink = micros();
                    examples_linux/mysGateway.cpp:180:25: error: call of overloaded âsleep(uint&)â is ambiguous
                    • T
                      Toyman
                      I probably miss something, but why are trying to compile the arduino sketch on Raspberry Pi???
                        @ericvdb
                        As @Toyman implies, we haven't ported the full Arduino environment here. This should mainly be used for running the Serial/Ethernet gateway directly on your RPi.
                        You cannot just run any MySensors example without risking to make heavy adaptations/implementation on your own.
                        • E ericvdb
                          @marceloaqno
                          Remains unsolved:
                          marceloaqno
                          Code Contributor
                          #54
                          @ericvdb micros() hasn't been ported, use:
                          millis() /1000;
                          for sleep(), replace:
                          with
                          sleep(SEND_FREQUENCY, false);
                          Also, if you want to print something don't use Serial.print() or Serial.println(), use printf() or debug().
                          should be:
                          debug("l/min: %f\n", flow);
                          as @hek said, the main focus now is to be used as a gateway, with time adding sensors will become less problematic.
                          • E
                            E
                            ericvdb
                            @marceloaqno
                            I have it almost working. Regarding the interrupt, I have to pull-up to 3.3V the io pin through a resistor of 10k?
                            Right now the interrupt isn't firing
                            • M marceloaqno
                              shfgS
                              shfgS
                              shfg
                              @marceloaqno thanks, turned on mosquitto logging and am getting this error on mosquitto:
                              1476724216: Invalid protocol "MQTT" in CONNECT from 127.0.0.1.
                              1476724216: Socket read error on client (null), disconnecting.
                              Tried an alternative mosquitto broker on another server too - same error.
                              • E
                                E
                                ericvdb
                                @marceloaqno
                                I have it working :smiley: only need to play with the debounce value
                                • M marceloaqno
                                  shfgS
                                  shfgS
                                  shfg
                                  @marceloaqno I finally have the MQTT gateway working after upgrading mosquitto to the latest build... I had installed mosquitto with apt-get under Wheezy which apparently pulled an older version. In retrospect probably should have just upgraded to Jessie from the outset! Working perfectly now (still under wheezy though FWIW)... thanks!
                                  • b0rmannB
                                    b0rmannB
                                    b0rmann
                                      marceloaqno
                                      Code Contributor
                                      @Christian-Simonsen start the gateway with debug enabled:
                                      mysGateway -d
                                        jerseyguy1996J
                                        jerseyguy1996J
                                        jerseyguy1996
                                        @Christian-Simonsen If you don't have debug enabled you could also just use:
                                        tail -f /dev/ttyUSB20
                                        My port is named ttyUSB20. You should substitute whatever you have named your port.
                                        • jerseyguy1996J jerseyguy1996
                                          Christian SimonsenC
                                          Christian SimonsenC
                                          Christian Simonsen
                                          @jerseyguy1996
                                          Thanks I'll test it. But it seems like I've jumped over a step or two. Or something isn't working. Nothing happened when I wrote "Make" in Terminal, so I jumped over this step. I guess that might be the problem.
                                          Do I have to configure (./configure -help) or can I use the default values when I connect the NRF24L01 to the GPIO pins?
