  2. Announcements
  • DrJeffD DrJeff
    The line above
    ./examples_linux/mysGatewaymsyGateway -h
    needs to be corrected to
    ./examples_linux/mysGateway -h
    Thanks for all the hard work! Awesome!
    @DrJeff Thanks for noticing. It should be fixed now.
    • M marceloaqno
      @b0rmann I could add support for RS485, but I'll need your help to test because I don't have the hardware.
      b0rmannB
      b0rmannB
      b0rmann
      @marceloaqno
      i am ready. after compiled and upload example node sketch i have on rs485 to usb convertor (/dev/ttyUSB0) output nice mysensors data:
      01 FF 00 58 07 02 FF FF - FF 02 03 07 FF 03 66 04
      testing playground photo: 0_1476563966730_playground.jpg
        mvader
        wrote on last edited by mvader
        #41
        I noticed the "improve rf24" section was added. and it mentioned high cpu.
        i set mine up a few weeks ago and am not using an interrupt on my radio.
        my cpu is only 2-3%
        I'm curious if the high cpu problem is seen by many?
        also a 2nd question.
        if i were to add an interrupt. how can i "re-configure" my setup to include that new -switch
        or do i have to remove everything and re-clone from git hub and start over?
        • shfgS
          shfgS
          shfg
          Thanks for this excellent port. I'm having an issue running it as an MQTT gateway on the RPi (Model A). It compiles without hassles, but cant make a successful MQTT connection. I get the following:
          mysGateway: Starting gateway...
          mysGateway: Protocol version - 2.0.1-beta
          mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
          mysGateway: TSF:LRT:OK
          mysGateway: TSM:INIT
          mysGateway: TSM:INIT:TSP OK
          mysGateway: TSM:INIT:GW MODE
          mysGateway: TSM:READY
          mysGateway: MCO:REG:NOT NEEDED
          mysGateway: MCO:BGN:STP
          mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
          mysGateway: Attempting MQTT connection...
          mysGateway: connected to 127.0.0.1
          ... those attempts recurring every 15 seconds or so, and in that time, no other activity is processed.
          From the code, I would have expected 'MQTT connected' rather than 'connected to 127.0.0.1'?
          I have mosquitto running on the pi in this case - which is working perfectly in other tests. Both serial and ethernet gateway modes compile and run perfectly, only the mqtt mode not working.
          Has anyone else had a similar issue?
          • E
            E
            ericvdb
            @marceloaqno what about gpio interrupts, is that supported?
            I'm thinking to use a RPi as a pulse counter for water, electricity and gas with no radio, just ethernet or mqtt.
            In combination with a I2C display, this could be a nice project ;)
            Greetz,
            Eric
            • Christian SimonsenC
              Christian SimonsenC
              Christian Simonsen
              I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. And I have followed the steps under "install and build", which seem to have worked fine. I didn't make any changes to the conf file. However now Im stuck. How do I setup the Raspberry Pi with the NRF24L01+ as a gateway in the MyController Gateway setup page in Safari?
              • shfgS shfg
                marceloaqno
                Code Contributor
                wrote on last edited by marceloaqno
                #45
                @shfg There were some reports about this problem in the past, do you see any error messages in your mosquitto log?
                @ericvdb yes, you can attach a function to handle an interruption like this:
                uint8_t mode = FALLING;	// Valid options are: CHANGE, FALLING, RISING
                uint8_t physPin = 16;	// Choose a pin that fits your needs
                void irqHandler(void)
                	// Process the interrupt
                	attachInterrupt(physPin, irqHandler, mode);
                Support for I2C was added in the latest version.
                shfgS 2 Replies Last reply
                • Christian SimonsenC Christian Simonsen
                  marceloaqno
                  Code Contributor
                  @Christian-Simonsen If you are using the default build options for the RPi gateway, in MyController (Resources -> Add gateway) choose Ethernet for the type and enter your RPi ip address in the Host name field.
                  Christian SimonsenC 1 Reply Last reply
                  • T
                    Toyman
                    Is it compatible with pre-2.0 versions eg 1.5?
                    • M marceloaqno
                      Christian SimonsenC
                      Christian SimonsenC
                      Christian Simonsen
                      Thanks that did the trick
                        Christian SimonsenC
                        Christian Simonsen
                        wrote on last edited by Christian Simonsen
                        #49
                        Background: I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. I have also set up the raspberry pi as a gateway in the MyController Gateway setup page in Safari. It found it and it seem to work.
                        However to my question. How do I know if the Raspberry Pi gateway with NRF24L01 work? How can I monitor what the Raspberry Pi gateway receive? Is there a similar way as the "Serial Monitor" that I use in the Arduino application, when accessing Arduino Uno via USB?
                        If there is I need to monitor this via OSX Terminal.
                        jerseyguy1996J 1 Reply Last reply
                        • E
                          E
                          ericvdb
                          @marceloaqno
                          Today i tried to use the sketch Water Meter Pulse Sensor in mysGateway.cpp but i run into alot of errors, you have any idea?
                          mysGateway.cpp:
                           * Created by Marcelo Aquino <marceloaqno@gmail.org>
                           * Copyleft (c) 2016, Marcelo Aquino
                          #include <iostream>
                          #include <cstdio>
                          #include <unistd.h>
                          // For more options run ./configure --help
                          // Config file
                          //#define MY_LINUX_CONFIG_FILE "/etc/mysensors.dat"
                          #define MY_GATEWAY_MAX_CLIENTS 10
                          // Serial config
                          // Enable this if you are using an Arduino connected to the USB
                          //#define MY_LINUX_SERIAL_PORT "/dev/ttyACM0"
                          // Enable this if you need to connect to a controller running on the same device
                          //#define MY_IS_SERIAL_PTY
                          // Choose a symlink name for the PTY device
                          //#define MY_LINUX_SERIAL_PTY "/dev/ttyMySensorsGateway"
                          // Grant access to the specified system group for the serial device
                          //#define MY_LINUX_SERIAL_GROUPNAME "tty"
                          // MQTT options
                          //#define MY_PORT 1883
                          //#define MY_MQTT_CLIENT_ID "mysensors-1"
                          //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
                          //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
                          // Flash leds on rx/tx/err
                          //#define MY_DEFAULT_ERR_LED_PIN 12  // Error LED pin
                          //#define MY_DEFAULT_RX_LED_PIN  16  // Receive LED pin
                          //#define MY_DEFAULT_TX_LED_PIN  18  // Transmit LED pin
                          // Inverse the blinking feature
                          #define DIGITAL_INPUT_SENSOR 26                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
                          #define PULSE_FACTOR 1000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
                          #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
                          #define MAX_FLOW 40                             // Max flow (l/min) value to report. This filters outliers.
                          #define CHILD_ID 1                              // Id of the sensor child
                          unsigned long SEND_FREQUENCY = 30000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                          MyMessage flowMsg(CHILD_ID,V_FLOW);
                          MyMessage volumeMsg(CHILD_ID,V_VOLUME);
                          MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
                          double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
                          volatile double flow = 0;
                          bool pcReceived = false;
                          unsigned long oldPulseCount = 0;
                          unsigned long newBlink = 0;
                          double oldflow = 0;
                          double volume =0;
                          double oldvolume =0;
                          unsigned long lastSend =0;
                          unsigned long lastPulse =0;
                          void onPulse()
                            if (!SLEEP_MODE)
                              unsigned long interval = newBlink-lastBlink;
                              if (interval!=0)
                                lastPulse = millis();
                                if (interval<500000L) {
                                  // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
                                  return;
                                flow = (60000000.0 /interval) / ppl;
                              lastBlink = newBlink;
                            pulseCount++;
                            attachInterrupt(DIGITAL_INPUT_SENSOR, onPulse, FALLING);
                            sendSketchInfo("Water Meter", "1.1");
                            // Register this device as Waterflow sensor
                            present(CHILD_ID, S_WATER);
                            unsigned long currentTime = millis();
                            if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY))
                              lastSend=currentTime;
                              if (!pcReceived) {
                                //Last Pulsecount not yet received from controller, request it again
                                request(CHILD_ID, V_VAR1);
                                return;
                              if (!SLEEP_MODE && flow != oldflow) {
                                oldflow = flow;
                                Serial.print("l/min:");
                                Serial.println(flow);
                                // Check that we dont get unresonable large flow value.
                                if (flow<((unsigned long)MAX_FLOW)) {
                                  send(flowMsg.set(flow, 2));                   // Send flow value to gw
                              // No Pulse count received in 2min
                              if(currentTime - lastPulse > 120000){
                                flow = 0;
                              // Pulse count has changed
                              if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
                                oldPulseCount = pulseCount;
                                Serial.print("pulsecount:");
                                Serial.println(pulseCount);
                                send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
                                double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                                if ((volume != oldvolume)||(!SLEEP_MODE)) {
                                  oldvolume = volume;
                                  Serial.print("volume:");
                                  Serial.println(volume, 3);
                                  send(volumeMsg.set(volume, 3));               // Send volume value to gw
                            if (SLEEP_MODE) {
                              sleep(SEND_FREQUENCY);
                          ./configure --my-debug=enable --my-gateway=ethernet --my-radio=none --my-port=5003
                          [OK] machine detected: SoC=BCM2835, Type=RPi, CPU=armv6l, REV=000e.
                          [OK] init system detected: systemd
                          [OK] Finished.
                          make:
                          root@raspberrypi:/downloads/MySensors# make
                          cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/log.o drivers/Linux/log.c
                          g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/noniso.o drivers/Linux/noniso.cpp
                          g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Print.o drivers/Linux/Print.cpp
                          g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetClient.o drivers/Linux/EthernetClient.cpp
                          g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SerialPort.o drivers/Linux/SerialPort.cpp
                          g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Stream.o drivers/Linux/Stream.cpp
                          g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/IPAddress.o drivers/Linux/IPAddress.cpp
                          g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/compatibility.o drivers/Linux/compatibility.cpp
                          g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SoftEeprom.o drivers/Linux/SoftEeprom.cpp
                          g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetServer.o drivers/Linux/EthernetServer.cpp
                          g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o examples_linux/mysGateway.o examples_linux/mysGateway.cpp
                          examples_linux/mysGateway.cpp: In function âvoid onPulse()â:
                          examples_linux/mysGateway.cpp:96:37: error: âmicrosâ was not declared in this scope
                          examples_linux/mysGateway.cpp: In function âvoid loop()â:
                          examples_linux/mysGateway.cpp:166:41: error: call of overloaded âset(volatile long unsigned int&)â is ambiguous
                          examples_linux/mysGateway.cpp:166:41: note: candidates are:
                          In file included from ./MySensors.h:319:0,
                                           from examples_linux/mysGateway.cpp:60:
                          ./core/MyMessage.cpp:222:12: note: MyMessage& MyMessage::set(const char*) <near match>
                           MyMessage& MyMessage::set(const char* value) {
                          ./core/MyMessage.cpp:222:12: note:   no known conversion for argument 1 from âvolatile long unsigned intâ to âconst char*â
                          ./core/MyMessage.cpp:234:12: note: MyMessage& MyMessage::set(bool)
                           MyMessage& MyMessage::set(bool value) {
                          ./core/MyMessage.cpp:241:12: note: MyMessage& MyMessage::set(uint8_t)
                           MyMessage& MyMessage::set(uint8_t value) {
                          ./core/MyMessage.cpp:256:12: note: MyMessage& MyMessage::set(uint32_t)
                           MyMessage& MyMessage::set(uint32_t value) {
                          ./core/MyMessage.cpp:263:12: note: MyMessage& MyMessage::set(int32_t)
                           MyMessage& MyMessage::set(int32_t value) {
                          ./core/MyMessage.cpp:270:12: note: MyMessage& MyMessage::set(uint16_t)
                           MyMessage& MyMessage::set(uint16_t value) {
                          ./core/MyMessage.cpp:277:12: note: MyMessage& MyMessage::set(int16_t)
                           MyMessage& MyMessage::set(int16_t value) {
                          examples_linux/mysGateway.cpp:180:25: error: call of overloaded âsleep(long unsigned int&)â is ambiguous
                          examples_linux/mysGateway.cpp:180:25: note: candidates are:
                          In file included from examples_linux/mysGateway.cpp:22:0:
                          /usr/include/unistd.h:444:21: note: unsigned int sleep(unsigned int)
                           extern unsigned int sleep (unsigned int __seconds);
                          In file included from ./MySensors.h:320:0,
                          ./core/MySensorsCore.cpp:543:8: note: int8_t sleep(uint32_t, bool)
                           int8_t sleep(const uint32_t sleepingMS, const bool smartSleep) {
                          Makefile:46: recipe for target 'examples_linux/mysGateway.o' failed
                          make: *** [examples_linux/mysGateway.o] Error 1
                          • E
                            E
                            ericvdb
                            @marceloaqno
                            i was able to get a bit further by replacing all "unsigned long" declarations with "uint"
                            Remains unsolved:
                            examples_linux/mysGateway.cpp:96:28: error: âmicrosâ was not declared in this scope
                                 uint newBlink = micros();
                            examples_linux/mysGateway.cpp:180:25: error: call of overloaded âsleep(uint&)â is ambiguous
                            • T
                              Toyman
                              I probably miss something, but why are trying to compile the arduino sketch on Raspberry Pi???
                                @ericvdb
                                As @Toyman implies, we haven't ported the full Arduino environment here. This should mainly be used for running the Serial/Ethernet gateway directly on your RPi.
                                You cannot just run any MySensors example without risking to make heavy adaptations/implementation on your own.
                                • E ericvdb
                                  @marceloaqno
                                  Remains unsolved:
                                  marceloaqno
                                  Code Contributor
                                  #54
                                  @ericvdb micros() hasn't been ported, use:
                                  millis() /1000;
                                  for sleep(), replace:
                                  with
                                  sleep(SEND_FREQUENCY, false);
                                  Also, if you want to print something don't use Serial.print() or Serial.println(), use printf() or debug().
                                  should be:
                                  debug("l/min: %f\n", flow);
                                  as @hek said, the main focus now is to be used as a gateway, with time adding sensors will become less problematic.
                                  • E
                                    E
                                    ericvdb
                                    @marceloaqno
                                    I have it almost working. Regarding the interrupt, I have to pull-up to 3.3V the io pin through a resistor of 10k?
                                    Right now the interrupt isn't firing
                                    • M marceloaqno
                                      shfgS
                                      shfgS
                                      shfg
                                      @marceloaqno thanks, turned on mosquitto logging and am getting this error on mosquitto:
                                      1476724216: Invalid protocol "MQTT" in CONNECT from 127.0.0.1.
                                      1476724216: Socket read error on client (null), disconnecting.
                                      Tried an alternative mosquitto broker on another server too - same error.
                                      • E
                                        E
                                        ericvdb
                                        @marceloaqno
                                        I have it working :smiley: only need to play with the debounce value
                                        • M marceloaqno
                                          shfgS
                                          shfgS
                                          shfg
                                          @marceloaqno I finally have the MQTT gateway working after upgrading mosquitto to the latest build... I had installed mosquitto with apt-get under Wheezy which apparently pulled an older version. In retrospect probably should have just upgraded to Jessie from the outset! Working perfectly now (still under wheezy though FWIW)... thanks!
