  2. Announcements
  • b0rmannB b0rmann
    what's about RS485 transport on raspberry pi? especially from wired RS485 mysensors network to MQTT
    marceloaqno
    Code Contributor
    @b0rmann I could add support for RS485, but I'll need your help to test because I don't have the hardware.
    b0rmannB 1 Reply Last reply
    • DrJeffD
      DrJeffD
      DrJeff
      The line above
      ./examples_linux/mysGatewaymsyGateway -h
      needs to be corrected to
      ./examples_linux/mysGateway -h
      Thanks for all the hard work! Awesome!
      • DrJeffD DrJeff
        The line above
        @DrJeff Thanks for noticing. It should be fixed now.
        • M marceloaqno
          b0rmannB
          b0rmannB
          b0rmann
          @marceloaqno
          i am ready. after compiled and upload example node sketch i have on rs485 to usb convertor (/dev/ttyUSB0) output nice mysensors data:
          01 FF 00 58 07 02 FF FF - FF 02 03 07 FF 03 66 04
          testing playground photo: 0_1476563966730_playground.jpg
            mvader
            wrote on last edited by mvader
            #41
            I noticed the "improve rf24" section was added. and it mentioned high cpu.
            i set mine up a few weeks ago and am not using an interrupt on my radio.
            my cpu is only 2-3%
            I'm curious if the high cpu problem is seen by many?
            also a 2nd question.
            if i were to add an interrupt. how can i "re-configure" my setup to include that new -switch
            or do i have to remove everything and re-clone from git hub and start over?
            • shfgS
              shfgS
              shfg
              Thanks for this excellent port. I'm having an issue running it as an MQTT gateway on the RPi (Model A). It compiles without hassles, but cant make a successful MQTT connection. I get the following:
              mysGateway: Starting gateway...
              mysGateway: Protocol version - 2.0.1-beta
              mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
              mysGateway: TSF:LRT:OK
              mysGateway: TSM:INIT
              mysGateway: TSM:INIT:TSP OK
              mysGateway: TSM:INIT:GW MODE
              mysGateway: TSM:READY
              mysGateway: MCO:REG:NOT NEEDED
              mysGateway: MCO:BGN:STP
              mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
              mysGateway: Attempting MQTT connection...
              mysGateway: connected to 127.0.0.1
              ... those attempts recurring every 15 seconds or so, and in that time, no other activity is processed.
              From the code, I would have expected 'MQTT connected' rather than 'connected to 127.0.0.1'?
              I have mosquitto running on the pi in this case - which is working perfectly in other tests. Both serial and ethernet gateway modes compile and run perfectly, only the mqtt mode not working.
              Has anyone else had a similar issue?
              • E
                E
                ericvdb
                @marceloaqno what about gpio interrupts, is that supported?
                I'm thinking to use a RPi as a pulse counter for water, electricity and gas with no radio, just ethernet or mqtt.
                In combination with a I2C display, this could be a nice project ;)
                Greetz,
                Eric
                • Christian SimonsenC
                  Christian SimonsenC
                  Christian Simonsen
                  I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. And I have followed the steps under "install and build", which seem to have worked fine. I didn't make any changes to the conf file. However now Im stuck. How do I setup the Raspberry Pi with the NRF24L01+ as a gateway in the MyController Gateway setup page in Safari?
                  • shfgS shfg
                    marceloaqno
                    Code Contributor
                    wrote on last edited by marceloaqno
                    #45
                    @shfg There were some reports about this problem in the past, do you see any error messages in your mosquitto log?
                    @ericvdb yes, you can attach a function to handle an interruption like this:
                    uint8_t mode = FALLING;	// Valid options are: CHANGE, FALLING, RISING
                    uint8_t physPin = 16;	// Choose a pin that fits your needs
                    void irqHandler(void)
                    	// Process the interrupt
                    	attachInterrupt(physPin, irqHandler, mode);
                    Support for I2C was added in the latest version.
                    shfgS 2 Replies Last reply
                    • Christian SimonsenC Christian Simonsen
                      marceloaqno
                      Code Contributor
                      @Christian-Simonsen If you are using the default build options for the RPi gateway, in MyController (Resources -> Add gateway) choose Ethernet for the type and enter your RPi ip address in the Host name field.
                      Christian SimonsenC 1 Reply Last reply
                      • T
                        Toyman
                        Is it compatible with pre-2.0 versions eg 1.5?
                        • M marceloaqno
                          Christian SimonsenC
                          Christian SimonsenC
                          Christian Simonsen
                          Thanks that did the trick
                            Christian SimonsenC
                            Christian Simonsen
                            wrote on last edited by Christian Simonsen
                            #49
                            Background: I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. I have also set up the raspberry pi as a gateway in the MyController Gateway setup page in Safari. It found it and it seem to work.
                            However to my question. How do I know if the Raspberry Pi gateway with NRF24L01 work? How can I monitor what the Raspberry Pi gateway receive? Is there a similar way as the "Serial Monitor" that I use in the Arduino application, when accessing Arduino Uno via USB?
                            If there is I need to monitor this via OSX Terminal.
                            jerseyguy1996J 1 Reply Last reply
                            • E
                              E
                              ericvdb
                              @marceloaqno
                              Today i tried to use the sketch Water Meter Pulse Sensor in mysGateway.cpp but i run into alot of errors, you have any idea?
                              mysGateway.cpp:
                               * Created by Marcelo Aquino <marceloaqno@gmail.org>
                               * Copyleft (c) 2016, Marcelo Aquino
                              #include <iostream>
                              #include <cstdio>
                              #include <unistd.h>
                              // For more options run ./configure --help
                              // Config file
                              //#define MY_LINUX_CONFIG_FILE "/etc/mysensors.dat"
                              #define MY_GATEWAY_MAX_CLIENTS 10
                              // Serial config
                              // Enable this if you are using an Arduino connected to the USB
                              //#define MY_LINUX_SERIAL_PORT "/dev/ttyACM0"
                              // Enable this if you need to connect to a controller running on the same device
                              //#define MY_IS_SERIAL_PTY
                              // Choose a symlink name for the PTY device
                              //#define MY_LINUX_SERIAL_PTY "/dev/ttyMySensorsGateway"
                              // Grant access to the specified system group for the serial device
                              //#define MY_LINUX_SERIAL_GROUPNAME "tty"
                              // MQTT options
                              //#define MY_PORT 1883
                              //#define MY_MQTT_CLIENT_ID "mysensors-1"
                              //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
                              //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
                              // Flash leds on rx/tx/err
                              //#define MY_DEFAULT_ERR_LED_PIN 12  // Error LED pin
                              //#define MY_DEFAULT_RX_LED_PIN  16  // Receive LED pin
                              //#define MY_DEFAULT_TX_LED_PIN  18  // Transmit LED pin
                              // Inverse the blinking feature
                              #define DIGITAL_INPUT_SENSOR 26                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
                              #define PULSE_FACTOR 1000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
                              #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
                              #define MAX_FLOW 40                             // Max flow (l/min) value to report. This filters outliers.
                              #define CHILD_ID 1                              // Id of the sensor child
                              unsigned long SEND_FREQUENCY = 30000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                              MyMessage flowMsg(CHILD_ID,V_FLOW);
                              MyMessage volumeMsg(CHILD_ID,V_VOLUME);
                              MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
                              double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
                              volatile double flow = 0;
                              bool pcReceived = false;
                              unsigned long oldPulseCount = 0;
                              unsigned long newBlink = 0;
                              double oldflow = 0;
                              double volume =0;
                              double oldvolume =0;
                              unsigned long lastSend =0;
                              unsigned long lastPulse =0;
                              void onPulse()
                                if (!SLEEP_MODE)
                                  unsigned long interval = newBlink-lastBlink;
                                  if (interval!=0)
                                    lastPulse = millis();
                                    if (interval<500000L) {
                                      // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
                                      return;
                                    flow = (60000000.0 /interval) / ppl;
                                  lastBlink = newBlink;
                                pulseCount++;
                                attachInterrupt(DIGITAL_INPUT_SENSOR, onPulse, FALLING);
                                sendSketchInfo("Water Meter", "1.1");
                                // Register this device as Waterflow sensor
                                present(CHILD_ID, S_WATER);
                                unsigned long currentTime = millis();
                                if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY))
                                  lastSend=currentTime;
                                  if (!pcReceived) {
                                    //Last Pulsecount not yet received from controller, request it again
                                    request(CHILD_ID, V_VAR1);
                                    return;
                                  if (!SLEEP_MODE && flow != oldflow) {
                                    oldflow = flow;
                                    Serial.print("l/min:");
                                    Serial.println(flow);
                                    // Check that we dont get unresonable large flow value.
                                    if (flow<((unsigned long)MAX_FLOW)) {
                                      send(flowMsg.set(flow, 2));                   // Send flow value to gw
                                  // No Pulse count received in 2min
                                  if(currentTime - lastPulse > 120000){
                                    flow = 0;
                                  // Pulse count has changed
                                  if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
                                    oldPulseCount = pulseCount;
                                    Serial.print("pulsecount:");
                                    Serial.println(pulseCount);
                                    send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
                                    double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                                    if ((volume != oldvolume)||(!SLEEP_MODE)) {
                                      oldvolume = volume;
                                      Serial.print("volume:");
                                      Serial.println(volume, 3);
                                      send(volumeMsg.set(volume, 3));               // Send volume value to gw
                                if (SLEEP_MODE) {
                                  sleep(SEND_FREQUENCY);
                              ./configure --my-debug=enable --my-gateway=ethernet --my-radio=none --my-port=5003
                              [OK] machine detected: SoC=BCM2835, Type=RPi, CPU=armv6l, REV=000e.
                              [OK] init system detected: systemd
                              [OK] Finished.
                              make:
                              root@raspberrypi:/downloads/MySensors# make
                              cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/log.o drivers/Linux/log.c
                              g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/noniso.o drivers/Linux/noniso.cpp
                              g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Print.o drivers/Linux/Print.cpp
                              g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetClient.o drivers/Linux/EthernetClient.cpp
                              g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SerialPort.o drivers/Linux/SerialPort.cpp
                              g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Stream.o drivers/Linux/Stream.cpp
                              g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/IPAddress.o drivers/Linux/IPAddress.cpp
                              g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/compatibility.o drivers/Linux/compatibility.cpp
                              g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SoftEeprom.o drivers/Linux/SoftEeprom.cpp
                              g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetServer.o drivers/Linux/EthernetServer.cpp
                              g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o examples_linux/mysGateway.o examples_linux/mysGateway.cpp
                              examples_linux/mysGateway.cpp: In function âvoid onPulse()â:
                              examples_linux/mysGateway.cpp:96:37: error: âmicrosâ was not declared in this scope
                              examples_linux/mysGateway.cpp: In function âvoid loop()â:
                              examples_linux/mysGateway.cpp:166:41: error: call of overloaded âset(volatile long unsigned int&)â is ambiguous
                              examples_linux/mysGateway.cpp:166:41: note: candidates are:
                              In file included from ./MySensors.h:319:0,
                                               from examples_linux/mysGateway.cpp:60:
                              ./core/MyMessage.cpp:222:12: note: MyMessage& MyMessage::set(const char*) <near match>
                               MyMessage& MyMessage::set(const char* value) {
                              ./core/MyMessage.cpp:222:12: note:   no known conversion for argument 1 from âvolatile long unsigned intâ to âconst char*â
                              ./core/MyMessage.cpp:234:12: note: MyMessage& MyMessage::set(bool)
                               MyMessage& MyMessage::set(bool value) {
                              ./core/MyMessage.cpp:241:12: note: MyMessage& MyMessage::set(uint8_t)
                               MyMessage& MyMessage::set(uint8_t value) {
                              ./core/MyMessage.cpp:256:12: note: MyMessage& MyMessage::set(uint32_t)
                               MyMessage& MyMessage::set(uint32_t value) {
                              ./core/MyMessage.cpp:263:12: note: MyMessage& MyMessage::set(int32_t)
                               MyMessage& MyMessage::set(int32_t value) {
                              ./core/MyMessage.cpp:270:12: note: MyMessage& MyMessage::set(uint16_t)
                               MyMessage& MyMessage::set(uint16_t value) {
                              ./core/MyMessage.cpp:277:12: note: MyMessage& MyMessage::set(int16_t)
                               MyMessage& MyMessage::set(int16_t value) {
                              examples_linux/mysGateway.cpp:180:25: error: call of overloaded âsleep(long unsigned int&)â is ambiguous
                              examples_linux/mysGateway.cpp:180:25: note: candidates are:
                              In file included from examples_linux/mysGateway.cpp:22:0:
                              /usr/include/unistd.h:444:21: note: unsigned int sleep(unsigned int)
                               extern unsigned int sleep (unsigned int __seconds);
                              In file included from ./MySensors.h:320:0,
                              ./core/MySensorsCore.cpp:543:8: note: int8_t sleep(uint32_t, bool)
                               int8_t sleep(const uint32_t sleepingMS, const bool smartSleep) {
                              Makefile:46: recipe for target 'examples_linux/mysGateway.o' failed
                              make: *** [examples_linux/mysGateway.o] Error 1
                              • E
                                E
                                ericvdb
                                @marceloaqno
                                i was able to get a bit further by replacing all "unsigned long" declarations with "uint"
                                Remains unsolved:
                                examples_linux/mysGateway.cpp:96:28: error: âmicrosâ was not declared in this scope
                                     uint newBlink = micros();
                                examples_linux/mysGateway.cpp:180:25: error: call of overloaded âsleep(uint&)â is ambiguous
                                • T
                                  Toyman
                                  I probably miss something, but why are trying to compile the arduino sketch on Raspberry Pi???
                                    @ericvdb
                                    As @Toyman implies, we haven't ported the full Arduino environment here. This should mainly be used for running the Serial/Ethernet gateway directly on your RPi.
                                    You cannot just run any MySensors example without risking to make heavy adaptations/implementation on your own.
                                    • E ericvdb
                                      @marceloaqno
                                      Remains unsolved:
                                      marceloaqno
                                      Code Contributor
                                      #54
                                      @ericvdb micros() hasn't been ported, use:
                                      millis() /1000;
                                      for sleep(), replace:
                                      with
                                      sleep(SEND_FREQUENCY, false);
                                      Also, if you want to print something don't use Serial.print() or Serial.println(), use printf() or debug().
                                      should be:
                                      debug("l/min: %f\n", flow);
                                      as @hek said, the main focus now is to be used as a gateway, with time adding sensors will become less problematic.
                                      • E
                                        E
                                        ericvdb
                                        @marceloaqno
                                        I have it almost working. Regarding the interrupt, I have to pull-up to 3.3V the io pin through a resistor of 10k?
                                        Right now the interrupt isn't firing
                                        • M marceloaqno
                                          shfgS
                                          shfgS
                                          shfg
                                          @marceloaqno thanks, turned on mosquitto logging and am getting this error on mosquitto:
                                          1476724216: Invalid protocol "MQTT" in CONNECT from 127.0.0.1.
                                          1476724216: Socket read error on client (null), disconnecting.
                                          Tried an alternative mosquitto broker on another server too - same error.
