  3. Use of BH1750 light sensor in low power node
16 Posts 8 Posters 10.3k Views 9 Watching
  • Nca78N Nca78
    I'm making a node powered with a CR2032 cell using a BME 280 and a BH1750 to measure pressure, temperature, humidity and light level in a tiny cube enclosure (from a cheap <2$ mp3 player, 3x3x3cm).
    Main points :
    • I use a 8MHz pro mini, I didn't change the frequency just updated the fuses to set BOD at 1.8V
    • I'm using the BH1750 from MySensors libraries (and Sparkfun library for BME280)
    • I do not shut down the sensors, I use their sleep modes and the power consumption is low enough for me (18uA in total when node is sleeping)
    • Every five minutes I measure and send changed values
    It's doing the job, low power and sending the values... but the light measurements are erratic as can be seen in the Domoticz graph. I have no idea how I should make the measurement to have a reliable value and save battery at the same time. My only viable option is to use the "one time" measurement modes so the sensor will go back to sleep after the measurement, but it seems the duration after which I read the value after starting the measurement is important. So, has someone managed to use the BH1750 in a very low power mode and succeeded in getting reliable data ? I have of course tried without the enclosure just in case and I have the same results.
    Thank you in advance for any help/suggestions/test cases. Below are the obviously non-final sketch, the graph from Domoticz and... a picture of the sensor :)
       REVISION HISTORY
       Based on Henrik Ekblad pressure sensor (using BMP085)
       Version 0.1 - Changed to environment sensor using BME280 and BH1750
       DESCRIPTION
       Pressure, Temperature, Humidity, Light level sensor using BME280 + BH1750
       http://www.mysensors.org/build/pressure
                           SENSOR CONFIGURATION
    // Comment if you are not running on battery/coin cell/... but on main power
    #define BATTERY_SENSOR
    // Enables/disables sleeps between sendings to optimize for CR2032 or similar coin cell, if you are not using AA/AAA battery this is not necessary
    #define USE_COIN_CELL
    //. If you don't want to manage weather forecasting, comment line below
    #define WEATHER_FORECAST_ENABLED
    // Time between sending of data to the gateway/controller.
    // If WEATHER_FORECAST_ENABLED is defined then the sending will be done in round minute intervals, as the forecast algorithm checks
    #define SLEEP_TIME_BETWEEN_DATASEND 300000 // (value is in ms)
    #include "SparkFunBME280.h"
    // Necessary to read Vcc (only for battery)
    #ifdef BATTERY_SENSOR
    #include <SystemStatus.h>
    // Parameters for VCC measurement
    const int VccMin        = 2400;  // Minimum expected Vcc level, in Volts. At 2V the cell should be dead
    const int VccMax        = 2900;  // Maximum expected Vcc level, in Volts.
    SystemStatus vcc();
    int LastBatteryPercent = 200; // so we are sure to send the battery level at first check
    // Sleep time between reads (in seconds). Do not change this value as the forecast algorithm needs a sample every minute.
    unsigned long SLEEP_TIME = 60000;
    unsigned long SleepTimeSum = SLEEP_TIME_BETWEEN_DATASEND;
    // Configuration for barometric pressure, weather forecast, temperature, humidity
    #define CHILD_ID_BARO 1
    #define CHILD_ID_TEMP 2
    #define CHILD_ID_HUM 3
    const float ALTITUDE = 0; // <-- adapt this value to your own location's altitude.
    #ifdef WEATHER_FORECAST_ENABLED
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
      STABLE = 0,			// "Stable Weather Pattern"
      SUNNY = 1,			// "Slowly rising Good Weather", "Clear/Sunny "
      CLOUDY = 2,			// "Slowly falling L-Pressure ", "Cloudy/Rain "
      UNSTABLE = 3,		// "Quickly rising H-Press",     "Not Stable"
      THUNDERSTORM = 4,	// "Quickly falling L-Press",    "Thunderstorm"
      UNKNOWN = 5			// "Unknown (More Time needed)
    BME280 bmp;      // Digital Pressure/Temp/Hum Sensor
    float lastPressure = -1;
    float lastTemp = -1;
    byte lastHum = -1;
    int lastForecast = -1;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
    // get kPa/h be dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    bool metric;
    MyMessage pressureMsg(CHILD_ID_BARO, V_PRESSURE);
    MyMessage forecastMsg(CHILD_ID_BARO, V_FORECAST);
    MyMessage tempMsg(CHILD_ID_TEMP, V_TEMP);
    MyMessage humMsg(CHILD_ID_HUM, V_HUM);
    // Light sensor configuration and variables
    #include <BH1750.h>
    BH1750 lightSensor;
    #define CHILD_ID_LIGHT 4
    MyMessage lightMsg(CHILD_ID_LIGHT, V_LEVEL);
    uint16_t lastlux = -1;
    // Sleep between sendings to preserve coin cell
    //  if not using button cell just make sure the #define USE_COIN_CELL is commented at the beginning of the sketch and it will do nothin
    void sleepForCoinCell() {
    #ifdef USE_COIN_CELL
      sleep(400);
      // If we are not using the weather forecast function, then we can override the SLEEP_TIME with SLEEP_TIME_BETWEEN_DATASEND as there is no use for wake ups between data sending
    #ifndef WEATHER_FORECAST_ENABLED
      SLEEP_TIME = SLEEP_TIME_BETWEEN_DATASEND;
      //***Driver settings for BME280 (from I2C_ReadAllData example from Sparkfun ***********************//
      bmp.settings.commInterface = I2C_MODE;
      bmp.settings.I2CAddress = 0x76;   // Address might be 0x77...
      //***Operation settings*****************************//
      //tStandby can be:
      //  0, 0.5ms
      //  1, 62.5ms
      //  2, 125ms
      //  3, 250ms
      //  4, 500ms
      //  5, 1000ms
      //  6, 10ms
      //  7, 20ms
      bmp.settings.tStandby = 0;
      //filter can be off or number of FIR coefficients to use:
      //  0, filter off
      //  1, coefficients = 2
      //  2, coefficients = 4
      //  3, coefficients = 8
      //  4, coefficients = 16
      bmp.settings.filter = 0;
      //tempOverSample can be:
      //  0, skipped
      //  1 through 5, oversampling *1, *2, *4, *8, *16 respectively
      bmp.settings.tempOverSample = 1;
      //pressOverSample can be:
      //  0, skipped
      bmp.settings.pressOverSample = 1;
      //humidOverSample can be:
      //  0, skipped
      bmp.settings.humidOverSample = 1;
      wait(10);  //Make sure sensor had enough time to turn on. BME280 requires 2ms to start up.
    void presentation()  {
      sleepForCoinCell();
      sendSketchInfo("Cube Sensor", "1.1");
      sleepForCoinCell();
      // Register sensors to gw (they will be created as child devices)
      present(CHILD_ID_BARO, S_BARO);
      sleepForCoinCell();
      sleepForCoinCell();
      present(CHILD_ID_HUM, S_HUM);
      sleepForCoinCell();
      lightSensor.begin(BH1750_ONE_TIME_HIGH_RES_MODE);
      sleep(5000); // Sleep 5 seconds if using coin cell
    float pressure;
    float temperature;
    float humidity;
    byte lux;
    bool oneValueSent;  // will tell us if at least one value was sent by the sensor, if not we will send heartbeat to tell controller we are still alive
      oneValueSent = false;
      //runMode can be:
      //  0, Sleep mode
      //  1 or 2, Forced mode
      //  3, Normal mode
      bmp.settings.runMode = 3; //Sleep mode
    #ifdef MY_DEBUG
      Serial.print("Starting BME280... result of .begin(): 0x");
      Serial.println(bmp.begin(), HEX);
      bmp.begin();
      // in all situations, we read the pressure as we need to feed the weather forecast algorithm
      pressure = bmp.readFloatPressure() / 100;
      // if we have reached the configured number of sleeps, we process the other measurements and send values when necessary
      if (SleepTimeSum >= SLEEP_TIME_BETWEEN_DATASEND) {
        SleepTimeSum = 0;
        // Measure all other values from BME sensor
        if (metric)
          temperature = bmp.readTempC();
          temperature = bmp.readTempF();
        humidity = bmp.readFloatHumidity();
        // Set BME sensor back to sleep mode as fast as possible
        bmp.settings.runMode = 0; //Sleep mode
        bmp.begin(); // apply new mode
        // Configure sensor to make one measurement in high res mode
        // Get initial time when we configured the BH1750 sensor + add max time of high res measurement (180ms from datasheet)
        // This will be the minimum time before we try to make the measurement
        unsigned long minimumMillisForLightMeasurement = millis() + 200;
        int forecast = sample(pressure);
    #ifdef MY_DEBUG
        Serial.print("Temperature = ");
        Serial.print(temperature);
        Serial.println(metric ? " *C" : " *F");
        Serial.print("Pressure = ");
        Serial.print(pressure);
        Serial.println(" hPa");
        Serial.print("Forecast = ");
        if (temperature != lastTemp)
          oneValueSent = true;
          send(tempMsg.set(temperature, 1));
          sleepForCoinCell();
          lastTemp = temperature;
        if (humidity != lastHum)
          send(humMsg.set(humidity, 1));
          sleepForCoinCell();
          lastHum = humidity;
        if (pressure != lastPressure)
          send(pressureMsg.set(pressure, 0));
          sleepForCoinCell();
          lastPressure = pressure;
        if (forecast != lastForecast)
          send(forecastMsg.set(weather[forecast]));
          lastForecast = forecast;
        // if we have not reached the minimum time before we can read measurement of light, we sleep for the remaining ms
        if (minimumMillisForLightMeasurement > millis()) {
          sleep(minimumMillisForLightMeasurement - millis());
          wait(10);
        lux = lightSensor.readLightLevel();// Get Lux value
        if (lux != lastlux) {
          send(lightMsg.set(lux));
          lastlux = lux;
    #ifdef MY_DEBUG
        Serial.print("Lux = ");
        Serial.println(lux);
        int currentBatteryPercent = SystemStatus().getVCCPercent(VccMin, VccMax);
        if (currentBatteryPercent != LastBatteryPercent) {
          LastBatteryPercent = currentBatteryPercent;
          sendBatteryLevel(currentBatteryPercent);
        // if nothing has been sent, we send heartbeat to tell controller we are still alive
        if (oneValueSent == false) {
          sendHeartbeat();
      else {
      sleep(SLEEP_TIME);
      SleepTimeSum += SLEEP_TIME;
    float getLastPressureSamplesAverage()
      float lastPressureSamplesAverage = 0;
      for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
        lastPressureSamplesAverage += lastPressureSamples[i];
      lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
      return lastPressureSamplesAverage;
    // Algorithm found here
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
      // Calculate the average of the last n minutes.
      int index = minuteCount % LAST_SAMPLES_COUNT;
      lastPressureSamples[index] = pressure;
      minuteCount++;
      if (minuteCount > 185)
        minuteCount = 6;
      if (minuteCount == 5)
        pressureAvg = getLastPressureSamplesAverage();
      else if (minuteCount == 35)
        float lastPressureAvg = getLastPressureSamplesAverage();
        float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
          dP_dt = change * 2; // note this is for t = 0.5hour
          dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
      else if (minuteCount == 65)
          dP_dt = change; //note this is for t = 1 hour
          dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
      else if (minuteCount == 95)
          dP_dt = change / 1.5; // note this is for t = 1.5 hour
          dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
      else if (minuteCount == 125)
        pressureAvg2 = lastPressureAvg; // store for later use.
          dP_dt = change / 2; // note this is for t = 2 hour
          dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
      else if (minuteCount == 155)
          dP_dt = change / 2.5; // note this is for t = 2.5 hour
          dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
      else if (minuteCount == 185)
          dP_dt = change / 3; // note this is for t = 3 hour
          dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
        pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
      int forecast = UNKNOWN;
        forecast = UNKNOWN;
      else if (dP_dt < (-0.25))
        forecast = THUNDERSTORM;
      else if (dP_dt > 0.25)
        forecast = UNSTABLE;
        forecast = CLOUDY;
        forecast = SUNNY;
      else if ((dP_dt > (-0.05)) && (dP_dt < 0.05))
        forecast = STABLE;
        forecast = UNKNOWN;
    #ifdef MY_DEBUG
      Serial.print(F("Forecast at minute "));
      Serial.print(minuteCount);
      Serial.print(F(" dP/dt = "));
      Serial.print(dP_dt);
      Serial.print(F("kPa/h --> "));
      return forecast;
    0_1474559866025_image-0-02-01-2b22b107ca5b14ca5672cacea0cb17fe665beecff0289f848d63c93522998113-V(1).jpg
    @Nca78 I think the answer is right there in your code:
    I think this needs to be done every time the sensor is set to non-sleep mode. The code you have only waits during setup. Try adding a wait in the loop, after bmp.settings.runMode = 3
    The debug output should have told you that the result of begin was bad though, so I might be on the wrong track.
    Nca78N 1 Reply Last reply
      @mfalkvidd thank you for your answer but unfortunately I think that you are on the wrong track yes, as the BME sensor returns perfectly regular results, problem is with the BH1750 :)
      • Nca78N Nca78
        @Nca78 you should get some extra info from the BH1750 lib if you do #define BH1750_DEBUG
        Maybe that can give a clue?
          Unfortunately it's just printing the light level, not very useful in my case :(
          But I'm thinking it might be related to the falling voltage in the CR2032 as I do the data sending from BME280 sensor while the BH1750 is performing the measurement. If Vcc falls in the middle of the measurement process this result could make sense.
          I will power from li-ion battery + regulator and see if it's more stable, then it will mean I need to split the sleeping time in two and process alternatively the BME and BH1750 sensors.
          • Nca78N Nca78
            @Nca78 for debugging, you could try skip sending, to see if the power drain is the problem. Just print the value on serial instead of sending.
              @mfalkvidd
              Have you considered sleeping your sensors rather than turning them off? I measured the standby current on a BME280 to be 148na using a Dave Jones Microcurrent. I don't know what your light sensor would measure out at though, but you may burn less current sleeping your sensors than going through a higher drain startup, depending on how long you sleep them for.
              Have you considered using a simple photo-resistor connected to the ADC on your atmega328?
                @mfalkvidd
                @NeverDie said:
                @mfalkvidd
                The idea of using BH1750 is to have precise lux measurement.
                Didn't have time to test with another sensor but I will do it soon, maybe that one is just faulty as I see no logical reason for it to behave that way, even in continuous measurement mode and battery powered it's doing the same.
                • alexsh1A
                  alexsh1A
                  alexsh1
                  You can measure voltage and see if it drops too much during sending. Unfortunately, CR2032 is not a very powerful power source.
                  Another idea would bee having sensor measurements done desperately. I have several sensors (BH1750 + TSL2561 + VEML6070 UV(coming shortly) MOD-1016 (lightning sensor)) running from a tiny Li-on 3.7v 350mA battery without any issues.
                    It may be a long-shot, but I wonder if in fact your sensor is actually working perfectly and your lighting is the kind that flickers on and off at a very fast rate, tricking your eye into believing that it's continuously on? If your sensor were to sample fast enough, perhaps it is reporting the amount of light that is actually there during each brief sample interval rather than the average that you were expecting.
                    Incidently, how are you liking Domoticz? I'm looking for something that will log and graph my sensor data, and I like how Domoticz appears to do that for everything by default. Is it easy to learn, or is it a steep learning curve?
                    Nca78N AWIA 2 Replies Last reply
                      @NeverDie sampling time for measurement is long (>100ms), flicker in lighting that could influence it would be clearly visible with human eye. It also does the sames with natural light which can vary with cloud coverage but not that wildly :)
                      For Domoticz it's not very difficult to learn I think, but the log for sensor data is not complete. It keeps values at regular intervals (not all values sent): every 5 minutes for the last day by default, it can be increased to 7 days in the configuration but after that it will only keep average and min/max for each day.
                      I'm also a bit frustrated with the limited interface too, I would like to be able to combine switches/selectors/etc into one block (for example all settings to control an AC) but that is not possible.
                        AWIA
                        AWIA
                        AWI
                        @NeverDie we should start a separate thread on controller experiences. But for here, and the way I see it : Domoticz is a do it all, easy to use controller with interface to excellent data handling (influxdb, etc). Works out of the box in most cases. I have recently started to look at mycontroller which is geared to MySensors and is more configurable.
                        • gerritvG
                          gerritvG
                          gerritv
                          Not sure if you ever solved the BH1750 problem. I had same issue, the BH1750 library does not correctly handle the case where One Time is configured as mode. The sensor literally powers down after the command is executed. You would need to wake it up again by issuing a Power On command (0x1) according to data sheet.
                          I switched to using BH1750_CONTINUOUSxxxx but then I am not looking to save the few microA. My attempts to fix the driver library haven't succeeded yet :-( I would prefer it worked properly with BH1750_ONE_TIMExxxx.
                          gerritvG 1 Reply Last reply
                          • gerritvG gerritv
                            gerritvG
                            gerritvG
                            gerritv
                            I submitted an issue on the BH1750 library, which was fixed. So OneTime modes now work as expected.
                            https://github.com/claws/BH1750/issues/17
                            4 1 Reply Last reply
                            • gerritvG gerritv
                              4994james
                              @gerritv
                              I am using v1.3.0 of the BH1750 library which I think is the most recent version on github (updated Jan 22).
                              I had the same issue when using ONE_TIME_HIGH_RES_MODE in that the sensor would return an accurate light level on first power up but then each subsequent read would return the same value regardless of the light level.
                              Reading through the source code (I think) the measureReady statement is still missing a configure statement to re-power up the module.
                              So I put a configure statement in the main loop of the sketch which (I think) powers up the module and then a wait for 200ms to allow enough time before reading.
                              void loop(){
                                  if (!lightSensor.configure(BH1750::ONE_TIME_HIGH_RES_MODE)){
                                  Serial.println("Could not power up light sensor");
                                  wait (200);
                                  if (lightSensor.measurementReady()) {
                                  #ifdef MY_DEBUG
                                  send(msgLight.set(lux, 1));
                              etc...
                              My device is a combination temp/hum sensor using a HTU21 and light sensor using BH1750.
                              I now get accurate light levels each read cycle.
                              In BH1750 continuous mode the current draw was about 0.15mA between reads. In one time mode it is now reading 0.01mA on my ammeter, i.e. almost too small to read.
                              • N
                                N
                                nekitoss
                                @gerritv Thank you for pointing the problem. I was updating my code, while library was updated and found that i had funtion, that does not exists in library - i've added it in local copy in library, then it updated and my local patch was gone.
                                I've investigated previosly mentioned PR - and must admit that later they removed that re-initialisation when reading.
                                I will try a PR to slightly improve that behaviour, but looks like library is becoming abandoned.
                                Now look it should work next way: after previous measurement done you must run lightSensor.configure(ONE_TIME_) so it starts measuring - this is shown in their example BH1750onetime.ino. Then we have to wait, but measurementReady() relies on _delay_ms, which (as i remember) won't tick during sleep so you can't sleep. We can sleep but we can't get exact measurement time for current settings. Soto save battery we sleep max time - which, according to library is 180ms. Then we get reading. On next cycle - repeat.
                                As i understand maximum battery saving code will look like:
                                  Wire.begin(); // Initialize the I2C bus (BH1750 library doesn't do this automatically)
                                  lux_init_status = lightMeter.begin(BH1750::ONE_TIME_LOW_RES_MODE); //init ONE_TIME - at same time it will start measuring, but we will ignore this and double-call start measuring
                                  if (lux_init_status == false) {
                                    send(deb_msg.set("ErrorInitLux")); //notify us about failure
                                  if (lux_init_status) { //making it fail-safe  - if BH1750 brokes then other sensors will still work
                                    lightMeter.configure(BH1750::ONE_TIME_LOW_RES_MODE); //this will start measuring, after it sensor will go into power-down mode
                                    //note, that configure has 10ms sleep built-in
                                    sleep(180); //this is guarantee time in this library with any config. We can't get that externally as for v1.3.0
                                    long lux = lightMeter.readLightLevel(); //actually get results
                                  sleep(SLEEP_TIME);//sleep between measurements
                                note that .configure() that is also called by .begin has built-in 10ms delay
