  3. 💬 Arduino Pro Mini Shield for RFM69(H)W
atmega328patmega328pressureinterstitialhumiditywirelesspcbrfm69hwsensorbme280rfm69temperaturearduinosi7021
53 Posts 13 Posters 18.8k Views 11 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/268/Arduino-Pro-Mini-Shield-for-RFM69HW
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      Are there any more files for this board?
        The files should be accessible now.
        • korttomaK
          korttomaK
          korttoma
          Thank you very much @NeverDie
          Just ordered a batch from dangerousprototypes(dot)com
          • Tomas
          • FotoFieberF
            FotoFieberF
            FotoFieber
            I ordered some OSH park...
            • FotoFieberF FotoFieber
              You're welcome. Because it leverages the Pro Mini, it doesn't require many discrete parts. Also, the soldering is fairly straight forward.
                I just now posted Version 014. The changes are:
                1. I enlarged the pad holes by 0.3mm to make aligning the pins between the Pro Mini and the adapter board easier. The prior version worked, but the alignment was a little tight.
                2. I increaased the board size slightly in order to maintain clearances between the larger holes/pads and the edges of the board.
                3. I added some text to the bottom silk screen which better identifies the board and its version number.
                korttomaK 1 Reply Last reply
                  korttomaK
                  korttomaK
                  korttoma
                  Hi @NeverDie,
                  I just received my batch and they look nice.
                  I noticed that the RFM69 DI00 is routed to Pin 4 on the Pro Mini instead of Pin 2 that I usually use. Does this really work? How did you account for this in your sketch?
                  • Tomas
                  • korttomaK korttoma
                    Hi @NeverDie,
                    @korttoma said:
                    Hi @NeverDie,
                    You are correct. It's a bug. I just now uploaded corrected files.
                    The current version is now Version 15.
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      So what is the easiest way to correct this if the previous PCB is used? Can I change in the sketch so it works anyway or do I need to solder some wire?
                        @Cliff-Karlsson
                        I suppose setting Pin 4 to INPUT after running a wire from Pin 4 to Pin 2 would patch it. Or you could solder bridge between 2 and 3, and then solder bridge again between 3 and 4. In that case, you'd set both Pin 3 and Pin 4 to input, assuming they weren't being used for something else.
                        If you have the boards but haven't yet soldered the headers, then I suggest doing the solder bridges, but don't connect header pins to pins 3 and 4. Then there's no need to set pins 3 and 4 to INPUT. I think that would be the cleanest fix.
                        That said, if the firmware you're running isn't relying on interrupts, then no patch would be needed. For instance, I had previously tested the PCB using lowpowerlab's node and gateway example code, which doesn't use interrupts for send and receive. That's why I didn't notice the bug until it was pointed out by Korttoma.
                          @Cliff-Karlsson
                          Also, I shrunk the board a little bit in Version 15, so it should cost less to get fab'd. On OSH-PARK, for example, it would now cost exactly $4 for 3 boards.
                            For some reason the Version 015 files disappeared after I posted them. So, I re-posted them this morning. Hopefully they stick this time.
                            • A
                              andre_x
                              Hi guys!
                              Thanks to NeverDie, I've just received my first batch!
                              Can anyone post the code for the board with the sensor?
                              Thanks!!!
                              • A
                                andre_x
                                THAAAAAANKS!!!
                                gohanG 1 Reply Last reply
                                • A andre_x
                                  THAAAAAANKS!!!
                                  @andre_x it is pretty straightforward, there are already examples rfm69 examples around the forum: it's basically the node example sketch with added sensor library and a few lines of code to read and send temperature/humidity
                                  • J
                                    J
                                    jeti
                                    Hi Guys,
                                    I am having troubles with the Version 015 ( i have checked that DI00 is routed to PIN2).
                                    My definition for the radio looks like this:
                                    #define MY_RADIO_RFM69
                                    #define MY_IS_RFM69HW
                                    but i still get a error:
                                    !TSM:FPAR:FAIL
                                    Adding a capacitor did nit help either. Does someone have a similar Issue?
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      Hi
                                      Is any chance to also project it for Arduino Pro Mini but for version 5V ?
                                      • pepsonP pepson
                                        Hi
                                        @pepson I guess not since it would need a logic level converter if you don't want to fry the rfm69 module
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          But it is not only other voltage power ? I use it on my Arduino Pro Mini 5V and use reduce power from 5V to 3,3V by stabilizer... But i use version 5V because i use it with sketch to control relay...
