  3. 💬 Mini Relay Box
💬 Mini Relay Box
otaatsha204arelaypower supplyrgbmysensoracdc
20 Posts 12 Posters 9.0k Views 12 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/300/Mini-Relay-Box
    • tonnerre33T
      tonnerre33T
      tonnerre33
      Very good project ! Will do you sort an nrf smd version?
      • TD22057T
        TD22057T
        TD22057
        Very cool. Would you mind adding a pdf of the schematic?
        • AchimA
          AchimA
          Achim
          Very nice box for a lot of Projects. Can you please post the buying source,
          • Sander TeunissenS
            Sander TeunissenS
            Sander Teunissen
            @Koresh
            I see so much beautiful stuff coming by. Are you planning on selling this as assemblies like you did with the stable node ?
            Sander.
            • TD22057T TD22057
              tonnerre33T
              tonnerre33T
              tonnerre33
              @TD22057 I have exported images from the source files. You can see them here : http://www.photorapide.com/albums/tonnerre33/cemrki/mini-relay-box-by-koresh.html ;)
              • KoreshK
                KoreshK
                Koresh
                Unfortunately I can't open my ebay shop right now. While I'm trying to open it, you can buy this board here: https://www.ebid.net/eu/for-sale/arduino-ide-compatible-220v-10a-switching-relay-with-433-mhz-radio-onboard-156694880.htm
                • KoreshK
                  KoreshK
                  Koresh
                  I forgot to upload the photo of the completed device :smile:
                    A Former User
                    can i order a 868mhz version? it seems perfect for my home project that is already running 868mhz and if it is working i would order many of them.
                    KoreshK 1 Reply Last reply
                    • ? A Former User
                      KoreshK
                      KoreshK
                      Koresh
                      @Nicola-Muratori thanks for your attention to this project. Yes, I have 433, 868 and 915mhz modules. So I can produce this board with any module. Just write down in PM what quantity you need.
                      • Sefi NinioS
                        Sefi NinioS
                        Sefi Ninio
                        wrote on last edited by Sefi Ninio
                        @Koresh ,@yury
                        Will you also make a nrf version like you did with the wall insertable switch node?
                        Sefi
                        Sefi NinioS 1 Reply Last reply
                          How do you calculate power? Do you have also a voltage measurement in addition to the current sensor?
                          • Sefi NinioS Sefi Ninio
                            @Koresh ,@yury
                            Sefi
                            Sefi NinioS
                            Sefi NinioS
                            Sefi Ninio
                            @Sefi-Ninio said in 💬 Mini Relay Box:
                            @Koresh ,@yury
                            Sefi
                            Or maybe we should use the nrf2rfm69 board you are creating?
                            gohanG 1 Reply Last reply
                              @Koresh ,@yury
                              Sefi
                              @Sefi-Ninio for that case it could be an idea to have a second pcb design with nrf24 smd footprint, it should be too difficult. Otherwise it will be a good chance to start using the rfm69, that is not a bad idea 😀
                                Sefi NinioS
                                Sefi NinioS
                                Sefi Ninio
                                @gohan said in 💬 Mini Relay Box:
                                Yes, rmf69 is great. Though most gateway instructions are for the nrf, and me being the newbie I am, I need clear instructions 😬
                                  shabba
                                  Is it still possible to get this with different freq radio?
                                    shabba
                                    Ah! I found it on your shop. Thx.
                                    • G
                                      G
                                      Geelbuik
                                      wrote on last edited by Geelbuik
                                      @Koresh
                                      Hi Koresh,
                                      I ordered a Mini Relay Box and a Wall Switch Insertable Node and use the two sketches you have provided. Can you help me getting the direct switch node-to- node signing working. I have everything installed, personalised the nodes (AES, HMAC) and loaded the sketches. The messages between the gateway, switch node , the relay node are working perfectly without message signing.
                                      When I turn on message signing the messages between gateway - switch node and gateway - relay node are signed and verified correctly. However the switch node does not sign the messages for the relay node. I have tried to add a signerPresentation() to the presentation section of the relay node. Unfortunately this did not provide the solution.
                                      Do you perhaps have a sketch for the relay and / or switch node that features the signing of direct node-to-node messages?
                                      Regards, Marcel
                                      • A
                                        anovak
                                        Please specify what type of transformer you are using.
                                          shabba
                                          Hi @koresh - I had a little accident on the AC side :-). I was wondering what values the 2 resistors (TH and SMD) and diode are ? Thanks!
