  3. 💬 Mini Relay Box
💬 Mini Relay Box
otaatsha204arelaypower supplyrgbmysensoracdc
20 Posts 12 Posters 9.1k Views 12 Watching
  • TD22057T TD22057
    Very cool. Would you mind adding a pdf of the schematic?
    tonnerre33T
    tonnerre33T
    tonnerre33
    @TD22057 I have exported images from the source files. You can see them here : http://www.photorapide.com/albums/tonnerre33/cemrki/mini-relay-box-by-koresh.html ;)
    • KoreshK
      KoreshK
      Koresh
      Unfortunately I can't open my ebay shop right now. While I'm trying to open it, you can buy this board here: https://www.ebid.net/eu/for-sale/arduino-ide-compatible-220v-10a-switching-relay-with-433-mhz-radio-onboard-156694880.htm
      • KoreshK
        KoreshK
        Koresh
        I forgot to upload the photo of the completed device :smile:
          A Former User
          can i order a 868mhz version? it seems perfect for my home project that is already running 868mhz and if it is working i would order many of them.
          KoreshK 1 Reply Last reply
          • ? A Former User
            KoreshK
            KoreshK
            Koresh
            @Nicola-Muratori thanks for your attention to this project. Yes, I have 433, 868 and 915mhz modules. So I can produce this board with any module. Just write down in PM what quantity you need.
            • Sefi NinioS
              Sefi NinioS
              Sefi Ninio
              wrote on last edited by Sefi Ninio
              @Koresh ,@yury
              Will you also make a nrf version like you did with the wall insertable switch node?
              Sefi
              Sefi NinioS 1 Reply Last reply
                How do you calculate power? Do you have also a voltage measurement in addition to the current sensor?
                • Sefi NinioS Sefi Ninio
                  @Koresh ,@yury
                  Sefi
                  Sefi NinioS
                  Sefi NinioS
                  Sefi Ninio
                  @Sefi-Ninio said in 💬 Mini Relay Box:
                  @Koresh ,@yury
                  Sefi
                  Or maybe we should use the nrf2rfm69 board you are creating?
                  gohanG 1 Reply Last reply
                    @Koresh ,@yury
                    Sefi
                    @Sefi-Ninio for that case it could be an idea to have a second pcb design with nrf24 smd footprint, it should be too difficult. Otherwise it will be a good chance to start using the rfm69, that is not a bad idea 😀
                      Sefi NinioS
                      Sefi NinioS
                      Sefi Ninio
                      @gohan said in 💬 Mini Relay Box:
                      Yes, rmf69 is great. Though most gateway instructions are for the nrf, and me being the newbie I am, I need clear instructions 😬
                        shabba
                        Is it still possible to get this with different freq radio?
                          shabba
                          Ah! I found it on your shop. Thx.
                          • G
                            G
                            Geelbuik
                            wrote on last edited by Geelbuik
                            @Koresh
                            Hi Koresh,
                            I ordered a Mini Relay Box and a Wall Switch Insertable Node and use the two sketches you have provided. Can you help me getting the direct switch node-to- node signing working. I have everything installed, personalised the nodes (AES, HMAC) and loaded the sketches. The messages between the gateway, switch node , the relay node are working perfectly without message signing.
                            When I turn on message signing the messages between gateway - switch node and gateway - relay node are signed and verified correctly. However the switch node does not sign the messages for the relay node. I have tried to add a signerPresentation() to the presentation section of the relay node. Unfortunately this did not provide the solution.
                            Do you perhaps have a sketch for the relay and / or switch node that features the signing of direct node-to-node messages?
                            Regards, Marcel
                            • A
                              anovak
                              Please specify what type of transformer you are using.
                                shabba
                                Hi @koresh - I had a little accident on the AC side :-). I was wondering what values the 2 resistors (TH and SMD) and diode are ? Thanks!
                                12.5k
