  3. rs485 on nano
rs485 on nano
44 Posts 14 Posters 25.7k Views 15 Watching
  • skatunS skatun
    @dbemowsk What do you mean by + to + and - to - between nodes.? Isnt that just to power the max 485 chip?
    I do have a usb dongle like u mentioned laying around somewhere, so I can just add that as a 3rd rs485 node, and use arduino serial monitor for it?
    on the gateway i commented all the led and inclusion code, this doesnt effect the rs485 right?
    My setup is shown below:
    @m26872 I have now enabled debug mode, see output below
    consul58C
    consul58C
    consul58
    @skatun
    I have exactly the same output of log. The RS485 modules I use seems to be the same ones. I use 2 Nanos. The RX/TX/Error-LEDs #defines and the Inclusion-mode #defines in the Gateway-/Node-Sketch are not commented.
    How can I get more infos to solve the problem?
    • skatunS skatun
      dbemowskD
      dbemowskD
      @skatun One other thing. I see that one of your boards is an arduino mega. I have never used a mega board, but in some reading that I have done the pins are defined slightly different on those. So the pin numbers you have defined in your sketch may not match correctly to where you have things connected on the mega. Don't quote me 100% on this, but do some searches in the forum for using a mega and you might find the info you are looking for.
      • skatunS
        skatunS
        skatun
        @dbemowsk so i added the usb device, it produces gibberish:
        ~þx
        different baud-rates, gibberish changes.....
        gibberish from the node, but nothing from gateway, I also changed gateway to uno as a test without success, here is the code on gateway which i commented out:
        // Flash leds on rx/tx/err
        //#define MY_LEDS_BLINKING_FEATURE
        // Set blinking period
        // Enable inclusion mode
        //#define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
        //#define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
        dbemowskD consul58C 2 Replies Last reply
        • skatunS skatun
          ~þx
          dbemowskD
          dbemowskD
          @skatun
          When working with serial communication, gibberish means that your nodes are talking at different baud rates. Once you get the same baud on both ends, you should see something readable. What baud rate do you have your node set to for the software serial connection? Whatever that is set to is the baud rate that you need to set the USB device to. Once you get that communicating, then check the software serial baud on the gateway. The problem could be that you have differing baud rates on both. If that is the case, your gateway is seeing similar gibberish that you are seeing on your USB adapter and thus does not know what to do with it.
          Another thing is that if you have your baud rate set too high, even though both sides are using matching baud rates, you can still see gibberish. Try starting everything on a lower baud like 9600. If that works, try the next baud rate, and the next. You may be able to run at 115200, but if you have debugging turned on it may have trouble communicating at that speed.
          Also, don't confuse your hardware serial with your software serial. This is the hardware UART serial baud definition:
          And this is the software serial baud definition:
          RS485Serial.begin(9600);
          These do not necessarily need to match. It is the software serial at all points that need to match.
          Let me know if any of that helps.
          • skatunS skatun
            ~þx
            consul58C
            consul58C
            consul58
            wrote on last edited by consul58
            @skatun
            I found the solution.
            Look at this
            Place the following in your Node-Sketch e.g. for Node ID 23
             #define MY_NODE_ID 23
            and the communication between node and Gateway is ok.
            I hope this works for you.
            bocmauB 1 Reply Last reply
            • P
              P
              pjr
              wrote on last edited by pjr
              @skatun did you got this working?
              I faced similar situation when I was accidentally connected rx & tx wrong way around on my GW. The sensor node was constantly polling for parent but got no response.
              The "gibberish" on RS485 bus might also be the control chars the transport uses.. SOH, STX, ETX and EOT.
              See this post.
              In my GW sketch I have these two enabled:
              skatunS 1 Reply Last reply
              • P pjr
                See this post.
                skatunS
                skatunS
                skatun
                @pjr @consul58 Have been away the last 5 days, will update the thread with the result tomorrow. Can anyone lighten me up on benefit of having inclusion button, and what inclusion time should be set to?
                  The inclusion mode was initially developed for Vera because it had the bad behaviour of needing a restart (of its main process) each time a device was added.
                  It is all a controller-side thing after all (all messages, including presentation is always passed to controller). But the mode can be turned on using a physical button on the gateway device. Which results in a message to controller saying start/stop inclusion mode.
                  • P
                    P
                    pjr
                    Good to know. Think then I can throw that away since I'm using domoticz.
                    • skatunS
                      skatunS
                      skatun
                      Implemented fixed node ID without success, I think maybe the rs485 adapter on gateway is broken, will test more tomorrow
                      wimdW 1 Reply Last reply
                      • skatunS skatun
                        wimdW
                        wimdW
                        wimd
                        @skatun Will join this discussion as well. I have exately the same issue. My set up is a nano as sensor and an uno as gateway.
                        I verified correct wiring of RS485 network is correctly doen I used this sketch (swith ReceiveOrSend to RS485Transmit or RS485Receive on both nodes;
                        #include <AltSoftSerial.h>
                        AltSoftSerial altSerial;
                        #define SSerialTxControl 2 //RS485 Direction control
                        #define RS485Transmit HIGH
                        #define RS485Receive LOW
                        bool ReceiveOrSend = RS485Transmit;
                        Serial.begin(9600);
                        Serial.println("AltSoftSerial Test Begin");
                        pinMode(SSerialTxControl, OUTPUT);
                        digitalWrite(SSerialTxControl, RS485Transmit); // Enable RS485 Transmit
                        altSerial.begin(9600);
                        if (ReceiveOrSend ){
                        Serial.println("send mode");
                        } else
                        digitalWrite(SSerialTxControl, RS485Receive); // Enable RS485 Transmit
                        Serial.println("receive mode");
                        char receivedOnRS485;
                        altSerial.println(" Hello world");
                        delay(2000);
                        } else
                        if (altSerial.available()) {
                        receivedOnRS485 = altSerial.read();
                        Serial.print("ontvagen=");
                        Serial.println(receivedOnRS485);
                        dbemowskD 1 Reply Last reply
                        • wimdW wimd
                          Serial.begin(9600);
                          } else
                          delay(2000);
                          } else
                          dbemowskD
                          dbemowskD
                          @wimd As my reply stated in the other thread, it would be helpful to see all sketches being used so we can determine better where the problem may lie.
                          • dbemowskD dbemowsk
                            wimdW
                            wimdW
                            wimd
                            @dbemowsk It are the standard examples.
                            For the gateway (Uno) :
                             * The RS485 Gateway prints data received from sensors on the serial link.
                             * The gateway accepts input on seral which will be sent out on
                             * the RS485 link.
                             * LEDs (OPTIONAL):
                             * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
                             * The gateway uses AltSoftSerial to handle two serial links
                             * on one Arduino. Use the following pins for RS485 link
                             *  Board          Transmit  Receive   PWM Unusable
                             * Teensy 3.0 & 3.1  21        20         22
                             * Teensy 2.0         9        10       (none)
                             * Teensy++ 2.0      25         4       26, 27
                             * Arduino Uno        9         8         10
                             * Arduino Leonardo   5        13       (none)
                             * Arduino Mega      46        48       44, 45
                             * Wiring-S           5         6          4
                             * Sanguino          13        14         12
                            // Enable RS485 transport layer
                            #define MY_RS485
                            // Define this to enables DE-pin management on defined pin
                            #define MY_RS485_DE_PIN 2
                            // Set RS485 baud rate to use
                            // Enable serial gateway
                            #define MY_GATEWAY_SERIAL
                            For the sensor (Nano):
                             * Version 1.0 - Henrik Ekblad
                             * This is an example of sensors using RS485 as transport layer
                             * The transport uses AltSoftSerial to handle two serial links
                             * Wiring-S           5         6          4
                             * Sanguino          13        14         12 *
                            #define MY_RS485
                            // Initialize motion message
                              present(CHILD_ID, S_MOTION);
                              // Read digital motion value
                              Serial.println(tripped);
                            • wimdW wimd
                               * the RS485 link.
                               * LEDs (OPTIONAL):
                               * Wiring-S           5         6          4
                               * Sanguino          13        14         12
                              #define MY_RS485
                               * Wiring-S           5         6          4
                              #define MY_RS485
                              skatunS
                              skatunS
                              skatun
                              @wimd include debug and remove inclusion from the sketches and it should be ok. I have ordered new rs485 shield, i expect that to be the issue..
                              wimdW R 2 Replies Last reply
                              • consul58C consul58
                                @skatun
                                Look at this
                                bocmauB
                                bocmauB
                                bocmau
                                Thanks for the tip now works
                                • skatunS skatun
                                  wimdW
                                  wimdW
                                  wimd
                                  @skatun include debug, removal of inclusion and define MY_NODE_ID enabled communication on the RS485 bus.
                                  • R
                                    R
                                    Reza
                                    • skatunS skatun
                                      R
                                      R
                                      Reza
                                      wrote on last edited by Reza
                                      #24
                                      @skatun my problem is solve . you test this and feedback me. use 3.3v and gnd pins in arduino use for rs485 module.
                                      b0rmannB 1 Reply Last reply
                                      • R
                                        R
                                        Reza
                                        #25
                                        is this wiring true for rs485 ? thank you
                                        also which cable is appropriate for A and B?
                                        • R Reza
                                          b0rmannB
                                          b0rmannB
                                          b0rmann
                                          @Reza
                                          no. rs485 must have LINEAR BUS topology.
