  3. Build a Cheap Z-wave Vibration sensor?
12 Posts 3 Posters 4.4k Views 3 Watching
  • Cassan0vaC Offline
    Cassan0vaC Offline
    Cassan0va
    Anyone been able to accomplish this?
    Couldnt find anything in the listing.
    The idea is that i need a vibration sensor for each step on the stairway because i want to attach it to a LED that would light up each step indvidually as they sense motion / vibration.
    But yet to find a "cheap" way to do this since prebuild vib sensors are like 50$ :/
    Any ideas or tips would be greatly appriciated.
    Cassan0vaC N 2 Replies Last reply
    • Cassan0vaC Cassan0va
      Cassan0vaC Offline
      Cassan0vaC Offline
      Cassan0va
      Have been thinking if i could connect multiple vib sensors in a serie into a fibaro universal?
      Think that could work?
      • H Offline
        H Offline
        Why not using MySensors? Using one of these perhaps?
        http://www.ebay.com/itm/1pcs-801S-Vibration-Sensor-Module-vibration-Analog-Output-Sensitivity-s3-/181847025460?hash=item2a56ed6734:g:BggAAOSwDNdVzUKo
        N 1 Reply Last reply
          N Offline
          N Offline
          Hello, there are some very cheap accelerometers that should be able to do this job.
          Check ADXL345 for example they cost 1$ on a breakout board on aliexpress. You should be able to put a few connected to the same pro mini board so you can manage more than one step and save even more.
          • H hek
            N Offline
            N Offline
            I've found those to be poor at detecting small vibrations, I doubt they will be reliable to detect someone putting foot on a step.
            • H Offline
              H Offline
              I haven't tried them myself. Does the piezo variant behave badly as well?
              http://www.ebay.com/itm/Analog-Piezoelectricity-Ceramic-Piezo-Vibration-Sensor-for-Arduino-HM-/182236397646?hash=item2a6e22c04e:g:5kIAAOSw0UdXqVdC
              N Cassan0vaC 2 Replies Last reply
              • H hek
                N Offline
                N Offline
                Haha interesting, never tried it. I'll order one right now to check, thank you for the link !
                • H hek
                  Cassan0vaC Offline
                  Cassan0vaC Offline
                  Cassan0va
                  @hek
                  how many of those do you think ill be able to fit into one board?
                  • H Offline
                    H Offline
                    You can use all the free analog pins. In total 8 on AtMega328 (where 4 is easily exposed on a nano-board).
                    Cassan0vaC 1 Reply Last reply
                    • H hek
                      Cassan0vaC Offline
                      Cassan0vaC Offline
                      Cassan0va
                      @hek
                      well i better get cracking then :) First project of this sort so we will see how it goes.
                        @hek
                        Cassan0vaC Offline
                        Cassan0vaC Offline
                        Cassan0va
                        Also just read up that there is a mysensors plugin for homeseer, thats amazing but does it have to be phyiscally connected to the controller or just same network?
                        • N Offline
                          N Offline
                          If it supports ethernet gateway then it's on the same network. Else it's serial gateway and you need to be connected with USB
                          12.0k
