  3. Build a Cheap Z-wave Vibration sensor?
12 Posts 3 Posters 4.0k Views 3 Watching
  • Cassan0vaC Offline
    Cassan0vaC Offline
    Cassan0va
    Anyone been able to accomplish this?
    Couldnt find anything in the listing.
    The idea is that i need a vibration sensor for each step on the stairway because i want to attach it to a LED that would light up each step indvidually as they sense motion / vibration.
    But yet to find a "cheap" way to do this since prebuild vib sensors are like 50$ :/
    Any ideas or tips would be greatly appriciated.
    Cassan0vaC Nca78N 2 Replies Last reply
    • Cassan0vaC Cassan0va
      Cassan0vaC Offline
      Cassan0vaC Offline
      Cassan0va
      Have been thinking if i could connect multiple vib sensors in a serie into a fibaro universal?
      Think that could work?
      • hekH Offline
        hekH Offline
        Why not using MySensors? Using one of these perhaps?
        http://www.ebay.com/itm/1pcs-801S-Vibration-Sensor-Module-vibration-Analog-Output-Sensitivity-s3-/181847025460?hash=item2a56ed6734:g:BggAAOSwDNdVzUKo
        Nca78N 1 Reply Last reply
          Nca78N Offline
          Nca78N Offline
          Hello, there are some very cheap accelerometers that should be able to do this job.
          Check ADXL345 for example they cost 1$ on a breakout board on aliexpress. You should be able to put a few connected to the same pro mini board so you can manage more than one step and save even more.
            Nca78N Offline
            Nca78N Offline
            I've found those to be poor at detecting small vibrations, I doubt they will be reliable to detect someone putting foot on a step.
            • hekH Offline
              hekH Offline
              I haven't tried them myself. Does the piezo variant behave badly as well?
              http://www.ebay.com/itm/Analog-Piezoelectricity-Ceramic-Piezo-Vibration-Sensor-for-Arduino-HM-/182236397646?hash=item2a6e22c04e:g:5kIAAOSw0UdXqVdC
              Nca78N Cassan0vaC 2 Replies Last reply
                Nca78N Offline
                Nca78N Offline
                Haha interesting, never tried it. I'll order one right now to check, thank you for the link !
                  Cassan0vaC Offline
                  Cassan0vaC Offline
                  Cassan0va
                  @hek
                  how many of those do you think ill be able to fit into one board?
                  • hekH Offline
                    hekH Offline
                    You can use all the free analog pins. In total 8 on AtMega328 (where 4 is easily exposed on a nano-board).
                    Cassan0vaC 1 Reply Last reply
                      Cassan0vaC Offline
                      Cassan0vaC Offline
                      Cassan0va
                      @hek
                      well i better get cracking then :) First project of this sort so we will see how it goes.
                        @hek
                        Cassan0vaC Offline
                        Cassan0vaC Offline
                        Cassan0va
                        Also just read up that there is a mysensors plugin for homeseer, thats amazing but does it have to be phyiscally connected to the controller or just same network?
                        • Nca78N Offline
                          Nca78N Offline
                          If it supports ethernet gateway then it's on the same network. Else it's serial gateway and you need to be connected with USB
