  3. Ethernet Gateway problem
93 Posts 18 Posters 61.5k Views 6 Watching
  • Dan S.D
    Dan S.D
    Dan S.
    After 24 hours of continuous operation with the softSPI version of my ethernet shield based gateway with no hiccups, I'm ready to declare victory and move on!! A special thanks to Anitcimex, without whose help it would not have been possible.
    • AnticimexA
      AnticimexA
      Anticimex
      Great news Dan :)
      I have also verified my gw on breadboard and am now working on the final product. I'll publish both HW and SW design on the forum. It will feature a new twist on the gateway I don't think anyone have done before ;)
      • Dan S.D
        Dan S.D
        Dan S.
        Hate to keep this thread going but although I focused mostly on the SPI end of the problem here, I found out I also had a radio problem--in fact all of my problems may have been related to the radio. I thought I was doing good in powering the antenna version of the radio using the AMS117 to supply 3.3 v rather than the board supplied 3.3V. Found out that when I did this the radio would quit working after a while. When connected directly to my UNO 3.3v supply (and the uno has enough power for the radio) it works flawlessly. If anyone has any insights on this would appreciate a response.
        RJ_MakeR 1 Reply Last reply
        • Dan S.D Dan S.
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @Dan-S.
          Noise? Ripple? Overheating? What kind of circuit did you build around it.?
          Looking at the datasheet; pages 4 and 5 may be of some help.
          ds1117.pdf
          RJ_Make
          • Dan S.D
            Dan S.D
            Dan S.
            Using the AMS117 module shown in mysensor store. Vin connected directly to the same power line powering the Uno, ground to uno ground and Vout to the radio whose ground is also to Uno (common ground for uno, AM117 module and radio). Power supplied by 5volt, 2amp wall wart.
            • Dan S.D Dan S.
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              @Dan-S.
              Capacitor across vcc and gnd on the radio?
              RJ_Make
              • RJ_MakeR RJ_Make
                @Dan-S.
                ds1117.pdf
                meanpenugin
                @ServiceXp
                I believe the part that is at the store already has the supporting circuitry on the board as described in those pages. I don't think there is any external components necessary.
                Edward
                • Dan S.D
                  Dan S.D
                  Dan S.
                  I do have a cap on the radio in addition to whatever is onboard the part. Also the UNO power is connected to through the USB connector if that affects anything.
                  • M meanpenugin
                    @ServiceXp
                    Edward
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    @meanpenugin
                    Yep, I thought he was using the chip. :-)
                    RJ_Make
                    • Dan S.D Dan S.
                      RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      @Dan-S.
                      What size cap? In testing I found I needed a pretty big cap (47uF) to get mine working with MySensor version 1.4.
                      RJ_Make
                      • Dan S.D
                        Dan S.D
                        Dan S.
                        Thought about this some more. I supplied power to both the radio and the Uno from the same wall wart 5v power source. But when the Uno is supplied 5v from its USB connector, the power from that connection is not regulated by the UNO. Since the radio has significant fluctuations in power output (and demand) it may cause significant ripples in its power source line--the same one which sources the UNO. Because the UNO is not regulating this power, it may have caused problems with the UNO (not the radio). Perhaps I should have capped the UNO power source also or at least should have had 2 separate power supplies, one for the UNO and one for the radio. Thought I was being clever in using one. At any rate the gateway continues to run with no problems with the radio getting power directly from the UNO's 3.3V output pin. The UNO provides enough power from this pin to power the radio with no issues.
                        • greglG
                          greglG
                          gregl
                          Thanks everyone esp. @Anticimex for your troubleshooting on this.
                          I didnt realise i had an issue with my 1.4 Ethernet GW ( using the iBoard hardware) as i wasn't using it in "production" and since it was just running from my PC's USB port it was restarted each time i woke my PC.
                          Anyway - to bring stability to the Iboard , i just added to the original sketch the line:
                          SPI.setClockDivider(SPI_CLOCK_DIV2); //to assist with gateway stability.
                          eg:
                            gw.begin(RF24_PA_LEVEL_GW, RF24_CHANNEL, RF24_DATARATE, writeEthernet);
                            Ethernet.begin(mac, myIp);
                            // give the Ethernet interface a second to initialize
                              delay(1000);
                              server.begin();
                          Thanks again!
                          AnticimexA 1 Reply Last reply
                          • greglG gregl
                            eg:
                                delay(1000);
                                server.begin();
                            Thanks again!
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @gregl You're welcome :)
                            Actually, I read somewhere that SPI.setClockDivider(SPI_CLOCK_DIV2) is a default setting in the device, but maybe various AVRs differ.
                            In any case, I found that when breadboarding, it might actually be needed to lower it to DIV4 as well.
                            Eventually, SPI.setClockDivider(SPI_CLOCK_DIV2) will be executed when SPI is configured in the library, but possibly some SPI calls are made without this call since you notice a difference when adding the call yourself before calling any library function.
                            • Dan S.D
                              Dan S.D
                              Dan S.
                              Still having an issue with my ethernet gateway (Uno plus shield). Works flawlessly for up to 24 hours, then shuts down. When working, responds without fail to every message from my test light sensor, but then fails to respond to any message. If I take the gateway offline, then restart everything it goes through the same process--working for some length of time, then shutting down. Have tried soft spi, separate power for the radio etc., and each time I think I have found the solution till it shuts down again. Any suggestions. Thinking that it is a hardware issue given that it operates fine for hours before stopping.
                              • AnticimexA
                                AnticimexA
                                Anticimex
                                Hm. Perhaps dodgy USB circuitry? (for powering the Arduino that is) assuming you do that. Have you tried alternative power supply for the Arduino as well?
                                Dan S.D 1 Reply Last reply
                                • AnticimexA Anticimex
                                  Dan S.D
                                  Dan S.D
                                  Dan S.
                                  @Anticimex Think I tried more than one power supply, but just to be sure will try again. Also plan on trying another uno board to eliminate that.
                                  • Johnny B GoodJ
                                    Johnny B GoodJ
                                    Johnny B Good
                                    Hey Dan,
                                    Did you got it working ?
                                    Ik had some REALY REALY strange problems here with my MQTT gateway, who hung for the most unexplainable reasons, sometimes it worked a few hours, sometimes a few minutes, sometimes it hung when I added a new node (????) ... so no node worked at all anymore after that ...
                                    I tried a lot of things, I wasn't sure about the power too here so I used a different power circuit with a cheap LD33V for the NRF only, but that didn't help much either :-| (zucht)
                                    I take the project from my hobby-room table to the places it suppose to work and back for some xXx times.
                                    It works well on the table every time, but when installed I got the weirdest problems ... well ...
                                    I'm not sure it's a solution for you too, I can't explain how it helped me, but It's now stable for a time now ...
                                    What did I do ? I just disabled the DEBUG'ing in MyConfig.h O_o for trying out, and it's working for me so far...
                                    Don't ask me how or what, cause I'm not that smart, it was just a desperate try :-D
                                    Maybe the serial was fine when connected to the PC for debugging on the table and was NOT connected when I placed it back, maybe the serial buffer was somehow messed up ... I don't know, maybe the Arduino got just a little bit more memory when debugging is disabled ... really, I can't explain it.
                                    Let's blame it on the ozon and sun flares ... :-D
                                    If you want to know (it wasn't my problem here) how I powered my MQTT, just let me know and I make a Fritz diagram...
                                    And maybe can a more geek then me explain this with this fresh look on the problem.
                                    -= GreetingZzz and may the sensors be with you =-
                                      Enabling DEBUG increases program space. Could be just enough to tip things over.
                                      • N
                                        N
                                        ntruchsess
                                        wrote on last edited by ntruchsess
                                        #68
                                        DEBUG also enables use of Serial which causes the 3.3V Voltage to drop a bit by causing power-consumption of the USB-chip (not relevant when using external power-regulator for the nRF24L01).
                                        • Johnny B GoodJ Johnny B Good
                                          Hey Dan,
                                          Dan S.D
                                          Dan S.D
                                          Dan S.
                                          @Johnny-B-Good I'm pretty sure my problems are power supply/radio related as others have suggested. It doesn't seem to lose connection via the Ethernet with Vera. Its the radio connection to the sensor that eventually fails.
                                          Am now testing with the UNO directly supplied by a 9v power supply which says that it is regulated. Was using 5Vusb input before. We'll see how it goes. I do have a cap on the radio, but if this fails new power supply fails I'll look at other alternatives to help the radio operation be more reliable.
                                          I did have debug turned off when uploaded the Ethernet sketch.
